Page 1 of 5 123 ... LastLast
Results 1 to 20 of 94
Like Tree12Likes
Thread: Best Performance Engine for Nissan B12
    FBB
    FBB is offline
    FBB's Avatar
    Sep 2015
    Peshawar
    39
    525
    14 Post(s)
    Default Best Performance Engine for Nissan B12
    Hi guys,
    I recently purchased Nissan Sunny B12 with GA15DE engine. The engine is slightly weak and giving some sound from connecting rod. I am planning to swap the engine, but with some performance engine like SR16VE type.
    Did anybody experienced this engine swap in B12? Following is the image of that engine.
    Best Performance Engine for Nissan B12 - 77816e1c2c45a2c3cc95a6b5df68e033
    Sent from my QMobile i12 using Tapatalk
    FBB
    FBB is offline
    FBB's Avatar
    Sep 2015
    Peshawar
    39
    525
    14 Post(s)
    Any idea where to find this? I already searched in Shoba Bazar Peshawar but did not found.
    cyrius's Avatar
    Jul 2010
    34
    735
    14 Post(s)
    2 Thread(s)
    It is Sr series engine hard to find last time saw one in Lahore best in its class but hard to find go for beams
    Sent from my D6503 using Tapatalk
    Mohsin Rana
    FBB
    FBB is offline
    FBB's Avatar
    Sep 2015
    Peshawar
    39
    525
    14 Post(s)
    Thanks for your reply @cyrius. About how long ago that you seen this engine and can you give me exact location of the shop?
    FBB
    FBB is offline
    FBB's Avatar
    Sep 2015
    Peshawar
    39
    525
    14 Post(s)
    @cyrius what do you mean by beams?
    cyrius's Avatar
    Jul 2010
    34
    735
    14 Post(s)
    2 Thread(s)
    It was last year I saw one but with out wiring and ecu if you really Want then you have to place order for it but the model you posted up came in b15 jdm
    Mohsin Rana
    cyrius's Avatar
    Jul 2010
    34
    735
    14 Post(s)
    2 Thread(s)
    The Toyota beams search it on net you will find info this one very easy to get
    Mohsin Rana
    FBB
    FBB is offline
    FBB's Avatar
    Sep 2015
    Peshawar
    39
    525
    14 Post(s)
    Thanks cyrius
    yaboi1da's Avatar
    Sep 2015
    27
    Ga16de is an easy fit don't know about its availability tho. Seen some people do a CA18DET build but you need some seriously deep pockets.
    Quote Originally Posted by cyrius View Post
    You can do that O_o. What would be done to fit one in?
    supraman2jz's Avatar
    Jun 2008
    33
    2,700
    76 Post(s)
    Quote Originally Posted by qamarahmad.awan View Post
    Hi guys,
    If you cannot take care of a vanilla GA15DE, please don't venture into anything complicated than that. The SR engines are, for the most part, performance oriented engines, if you do not know how to work on your own car, do not go for engines like these.
    FYI, all "used" engines are "slightly weaker" than when new. And if that sound was from the conrod, you wouldn't be driving that thing. It's probably from worn big end bearings in the crank, caused by low oil pressure. get your oil checked.
    "Being between arabs, you call it "Jimmss Yukaan Sagheer", or GMC yukon." - Xulfiqar.
    FBB
    FBB is offline
    FBB's Avatar
    Sep 2015
    Peshawar
    39
    525
    14 Post(s)
    Thanks for your kind suggestions. The engine is also burning oil now, i m currently using 20/50 and almost half tank burns on highway afyer 300km. @supraman2jz
  12. #12
    Jun 2008
    33
    2,700
    76 Post(s)
    Half at the dip stick right? That does not translate to half the oil in the pan. That roughly means a liter of oil. Get your compression checked, and have someone take a look at the valve stem seals. Does the car lose power uphillls?
    Also, check for the originality of the oil that you are using.
  13. #13
    FBB
    FBB is offline
    FBB's Avatar
    Sep 2015
    Peshawar
    39
    525
    14 Post(s)
    @supraman2jz nope car does not loose power uphills. With that engine i recently dare to went for a trip to the steep mountains where 2015 model toyota was unable to go my Nismo was on the fly.
  14. #14
    Jun 2008
    33
    2,700
    76 Post(s)
    Then check for the things I have mentioned.
  15. #15
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    First double confirm if the engine is Really weak.
    If swap is absolutely necessary, best bet would be:
    1. Just replace the assembly of GA15. That would cost only around 25K. No ECU/Wiring mess.
    2. Put a QG15DE (which I swapped into my B13). It's a "power machine". Fun to drive with huge low end torque, and giving 16kpl on GT Road.
    Btw, QG15DE is powerful enough, yet if you want even more power (almost sheer power), then QG18DE would be the better option. Easily available and it's a monster low end torque with still excellent consumption. Be sure to upgrade the suspension and braking system though.
  16. #16
    FBB
    FBB is offline
    FBB's Avatar
    Sep 2015
    Peshawar
    39
    525
    14 Post(s)
    @lsbCap people are saying that qg15de is not a good engine, as we use CNG so it needs computerised tunning all the time and it also misfires on high rpm.
    What do you think about GA16DE? Can i find in local market and any price idea for complete engine?
  17. #17
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Lol at QG15DE not being a good engine. And misfiring at high RPM, really???
    I have been using this engine for last 3 years. Ran it on CNG for a brief period of time. No issues at all.
    For more details, you can check my Engine swap thread:
    https://www.pakwheels.com/forums/nis...nny-1991-b13-2
  18. #18
    FBB
    FBB is offline
    FBB's Avatar
    Sep 2015
    Peshawar
    39
    525
    14 Post(s)
    @IsbCap also tell me that do i need some alterations for engine foundation or it will bolt on ga15de?
  19. #19
    FBB
    FBB is offline
    FBB's Avatar
    Sep 2015
    Peshawar
    39
    525
    14 Post(s)
    @spectra @IsbCap remember i m talking about B12 not B13. Are you sure that we can put QG15 in B12?
  20. #20
    FBB
    FBB is offline
    FBB's Avatar
    Sep 2015
    Peshawar
    39
    525
    14 Post(s)
    I have seen cars B12 with GA16DE but not with QG15/16
