Results 1 to 8 of 8
Thread: Anyone interested to modify there nissan b11 1985 can contact me
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    779
    55 Post(s)
    2 Thread(s)
    Default Anyone interested to modify there nissan b11 1985 can contact me
    contact 03455072961
    For ideas or for complete projects just contact me .
    I have been experimenting on b11 since 2007 and now its a beast
    STYLISH BOYZZZ STYLISH ATTITUDE
    syedsam's Avatar
    Oct 2015
    8
    I am trying on modifying nissan b12 1989..but dont know exactly where to start..
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    779
    55 Post(s)
    2 Thread(s)
    @syedsam you can call me ,i'll guide you all of the mod's according to your budget .
    i've recently swapped a b12 with a 1.8 dohc engine of a friends car from peshawar .
    my number is 03455072961
    asiiffareed's Avatar
    Oct 2014
    Wah cantt
    24
    2 Post(s)
    Default Asif fareed
    Its nice to see that you are willing to help. I got my engine swapped in my B13 seven months ago from Mithu Khan. The engine is QG15DE. I have to discuss some issues with you. If you can be of any help, then please confirm me.
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    779
    55 Post(s)
    2 Thread(s)
    Yeah you can ask me, go ahead.
    Oct 2014
    Wah cantt
    24
    2 Post(s)
    Thanx a lot brother for such a prompt reply. I am facing following problems:
    1. The car starts fine. But if i press accelerator immediately or try to drive it with cold start it shuts off. If i let it start for 10 minutes, it seems fine. but whenever there is a speed breaker or any hurdle ahead and i press brake and clutch, the engine shuts off. No matter how hot the engine is. I have got the MAF sensor cleaned, installed new air filter, installed new spark plugs and got the throttle body cleaned. but the problem persists. Similarly i tried to enhance the rpm of the engine to overcome this problem but after some days i face the same problem.
    2. My rpm meter is not working. from where i can get it worked. It has the original B13 meter.
    3. Through the forums i have learned that the fuel pump should not be directly connected through a wire, it must by connected with the ECU. My fuel pump is direct, whenever i activate the ignition switch the pump gets started. It means it is continuously ON.
    4. When i press the accelerator a bit hard, i can see black smoke emitting from the exhaust pipe. Normally there is smell of unburnt fuel from there.
    5. My fuel gauge is not working at all. I have spent 2000 rupees on it, but still its not working.
    6. I can hear some loud sound (khar khar) form the exhaust point (from where the pipe is joined with the engine) right beneath the head of the engine with silver color cover around it.
    I hope you will consider my request to answer the problems. My engine is QG15DE.
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    779
    55 Post(s)
    2 Thread(s)
    You're from where?
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    779
    55 Post(s)
    2 Thread(s)
    +923455072961
