Page 7 of 9 FirstFirst ... 56789 LastLast
Results 121 to 140 of 173
Like Tree72Likes
Thread: Nissan Skyline Restoration project
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    Default Nissan Skyline Restoration project
    Asalamo alaikum to everyone,
    as the subject tells this post is all about the restoration of the 4 door Nissan Skyline R32. first i will going to tell you how i got it.
    went to a customs auction where i got a list of items being sold in auction, Guess what, this car was in the list. however as there were no other competitor in the auction for this car, so i won the bid and gave the initial payment at the spot. however dealing with the customs people is nerve wrecking experience and they juice out each and every penny in your pocket when they have to sign any document. well thats a different story. cut short i got the delivery of the car from NLC dry port Thokar niaz baig. upon receiving the documents for registration process i came to know it was previously kept by someone in Iqbal town lahore, not gonna take any names for privacy. maybe someone knows them from here. the car was kept though in very bad condition, custom turbo piping, broken back lights, front light was cracked, well much more rusting and all. however when i received the car it was in pretty bad shape. pretty much everything was jammed, from differential to the Ignition key.
    when i called my mechanic, denter and painter. they were astonished on my decision and it was a big project and gonna cost me a lot. well i told them in reply, SHOK DA KOI MUL NAI.
    well, we started striping the car and anything we touch was rusted.
    the only thing which worked fine was the Engine, we fired up the engine after changing the oils and a little cleaning, and it started on first ignition, however it did made some pretty black smoke on first starting, then in few seconds when the dirt was burned out, it got smooth and run fine.
    took out all the suspension and found out the following.
    1. all bushes are broken
    2. rear shocks are leaked
    3. differential bearings are broken
    4. wheel bearings are worn out
    i sent the suspension to the workshop, opened up each item and ordered new parts.
    1. full suspension bush kit, PROTHANE bush kit (made in usa). imported by Basit( upgrade Motorsports lahore)
    2. set of four racing Tein coilovers bought from Apexi, Blitz, HKS, Nismo, Greddy, Rays and more JDM Parts direct from Japan - Nengun Performance online, and imported by same as above.
    3. differential was serviced, and same bearings were available from lahore, installed new bearing set.
    4. wheel bearings changed.
    5. all four wheels brake disc pads (hawks) imported from USA by upgrade motor sports.
    the disc rotors are in fine condition, just got them a little tool to get rid of all the rusting.
    The engine was coupled to an Automatic transmission, so got rid of the auto tranny and bought manual R154 manual gear from Marij from peshawar, he is a gem of a person and very nice guy, thanks Marij. and yes the Engine in this vehicle is 1JZ- GTE vtti.
    now it has been converted back to manual. the vehicle was originally manual. Thank God the clutch pedal was still there.
    all the manual clutch related stuff:
    1. master clutch cylinder,
    2. Slave cylinder.
    3. clutch fork
    4. stage 3, 6 puk eclustchmaster brand new from USA ( by upgrade Motorsports)
    5. R154 manual gear with lever( courtesy Maarij from Peshawar)
    rear new lights has been imported directly from Thailand from Ebay via Dubai, i personally brought them in my luggage.
    front lights are washed and serviced. the whole car body anti rusting has been done, denting has been done to bits, and now the car is under paint job. there are more stuff going in:
    1. greddy blow off valve
    2. dunlop drag radials semi slicks
    3. new racing radiator
    4. new stainless steel turbo pipping ( bought from upgrade Motorsports)
    5. new front mounted turbo inter-cooler
    6. air filter
    7. all the gauges, oil temp, turbo pressure, oil pressure , water temp etc.
    8. front strut bar
    9. all monograms original imported
    10. imported 3" inlet and 4" outlet Jasma approved exhaust
    now the car has been registered ( which was a hell of a task) and will insha'Allah come on road by the end of march. below are the pictures.
  2. #121
    darthcrossfader's Avatar
    Nov 2008
    28
    278
    Quote Originally Posted by shezyworld View Post
    thanks you brother, yes the rims are in my store, just waiting for few things to be finalized before i take it to the tire shop for the wheels change. yes my ETCS-i is now working fine, but the MAF is still giving me tough time. currently in process of finding the correct MAF and its wiring.
    hotwire MAF is very sensitive and its location is also very important make sure you place air intake atleast 6 inches away from maf the car response will chnge even by just rotating the maf. secondly the maf of this later vvti engine is an interchangable part with other toyota engine the MAF pinouts are also change from the previous vvti gte engine. google it
    car history >1995 honda civic d15 >mazda rx8 1jzGTE >jzx110 mark ii fortuna 1jzGTE factory manual >jzx100 mark ii 1jzGTE auto >toyota supra jza80 2jzGTE
  3. #122
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    i have solved the problem. and going to change the engine to twin turbo 1jzgte nonvvti map based engine. and by the way the current engine i have is for sale now for a very good price.
  4. #123
    FBB
    FBB is offline
    FBB's Avatar
    Sep 2015
    Peshawar
    39
    520
    14 Post(s)
    Toyota engine in Nissan?? Dont it will ruin the beauty ?
    Sent from my Z12 using Tapatalk
  5. #124
    Alir1's Avatar
    Aug 2013
    229
    2 Post(s)
    Quote Originally Posted by qamarahmad.awan View Post
    currently its also running toyota engine
    Sent from my GT-I9300 using PW Forums mobile app
  6. #125
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    many people in the world, do these kinds of swap. in my research, JZ engines are more stubborn and torqy than RB engines. and keeping in mind parts and tuning options available in pakistan, JZ was the best option to go for. RB is a rare item to find, keep and tune in pakistan. whereas JZ engines are found almost in every market here.
  7. #126
    Thinking's Avatar
    Jul 2008
    34
    2,300
    62 Post(s)
    Bro interior and rear lights dont add up. see if you can improve them.
    good going nice project.
  8. #127
    mishaqkhan1's Avatar
    Jun 2014
    292
    Good decision. I wondered in the start why would one go with a vvti in an r32. lol. Its a pain in the *** if your wanting to increase the power. Nonvvti is a beast just get a single turbo and your hp's will double and triple. stock Twin's will do for now but justice with this car would be a single turbo 1jzgte.
    Horsepower is how Fast you hit the wall ,
    Torque is how far you take the wall with you -
  9. #128
    urebhasan's Avatar
    Aug 2014
    Good work MA
  10. #129
    afnan.bashir's Avatar
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    So is your car still in limp mode? is it running rich still? Get it hooked to scanner and get if any check engine light. If its running rich check primary oxygen sensor and its graph
    93 Accord CB7 (Sold) / 2005 CL7
  11. #130
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    Quote Originally Posted by afnan.bashir View Post
    no, but now i have a different power goals so i have gone for a different engine setup. i have purchased a MAP based engine and got rid of the MAF and VVTI technology. so i am no longer in that problem.
  12. #131
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Which engine are you now into.
  13. #132
    tayyabbaig's Avatar
    Nov 2008
    Oslo
    34
    2,706
    3 Post(s)
    Ooo Mannn... MashAllah! 👍🏻👍🏻
    Just been to all this thread. Very happy to see such a detailed restoration thread after a long time at pw that costed me Rs. 100 wala Lays. 😊
    Sent from my iPhone using PW Forums mobile app.
  14. #133
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    1JZGTE twin turbo...
  15. #134
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    Quote Originally Posted by tayyabbaig View Post
    Ooo Mannn... MashAllah! 
    Just been to all this thread. Very happy to see such a detailed restoration thread after a long time at pw that costed me Rs. 100 wala Lays. 
    thanks man. i appreciate your interest. stay tunned for the next update in a day or two
  16. #135
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    Sir, the work really looks nice. It probably can't get much better given our resources.
    Back in the day, you used to have a sandblasting facility. Is it still available?
    haters gonna hate, potatoes gonna potate
  17. #136
    imbigsmall's Avatar
    Jul 2012
    839
    3 Post(s)
    Ma Sha Allah awesome project. Hoping for a video soon!
  18. #137
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    Quote Originally Posted by imbigsmall View Post
    insha'Allah... i will show you two videos.. one of project and one of completed project. just wait a bit more..
  19. #138
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    Quote Originally Posted by margallar View Post
    yes, you are right..
    and yes the sandblasting is still available.. its a part of my business, i cant survive my business without sandblasting.. so its there..
  20. #139
    rozzzzz's Avatar
    Oct 2005
    21,924
    12
    140 Post(s)
    5 Thread(s)
    great project ..need for detailed pictures ehre
    MOTOR MANIACS ... An automotive service and repair workshop
    https://www.facebook.com/pages/Motor-Maniacs/721830141231922
  21. #140
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    maybe i will get in touch sometime then
