Page 8 of 9 FirstFirst ... 6789 LastLast
Results 141 to 160 of 173
Like Tree72Likes
Thread: Nissan Skyline Restoration project
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    Default Nissan Skyline Restoration project
    Asalamo alaikum to everyone,
    as the subject tells this post is all about the restoration of the 4 door Nissan Skyline R32. first i will going to tell you how i got it.
    went to a customs auction where i got a list of items being sold in auction, Guess what, this car was in the list. however as there were no other competitor in the auction for this car, so i won the bid and gave the initial payment at the spot. however dealing with the customs people is nerve wrecking experience and they juice out each and every penny in your pocket when they have to sign any document. well thats a different story. cut short i got the delivery of the car from NLC dry port Thokar niaz baig. upon receiving the documents for registration process i came to know it was previously kept by someone in Iqbal town lahore, not gonna take any names for privacy. maybe someone knows them from here. the car was kept though in very bad condition, custom turbo piping, broken back lights, front light was cracked, well much more rusting and all. however when i received the car it was in pretty bad shape. pretty much everything was jammed, from differential to the Ignition key.
    when i called my mechanic, denter and painter. they were astonished on my decision and it was a big project and gonna cost me a lot. well i told them in reply, SHOK DA KOI MUL NAI.
    well, we started striping the car and anything we touch was rusted.
    the only thing which worked fine was the Engine, we fired up the engine after changing the oils and a little cleaning, and it started on first ignition, however it did made some pretty black smoke on first starting, then in few seconds when the dirt was burned out, it got smooth and run fine.
    took out all the suspension and found out the following.
    1. all bushes are broken
    2. rear shocks are leaked
    3. differential bearings are broken
    4. wheel bearings are worn out
    i sent the suspension to the workshop, opened up each item and ordered new parts.
    1. full suspension bush kit, PROTHANE bush kit (made in usa). imported by Basit( upgrade Motorsports lahore)
    2. set of four racing Tein coilovers bought from Apexi, Blitz, HKS, Nismo, Greddy, Rays and more JDM Parts direct from Japan - Nengun Performance online, and imported by same as above.
    3. differential was serviced, and same bearings were available from lahore, installed new bearing set.
    4. wheel bearings changed.
    5. all four wheels brake disc pads (hawks) imported from USA by upgrade motor sports.
    the disc rotors are in fine condition, just got them a little tool to get rid of all the rusting.
    The engine was coupled to an Automatic transmission, so got rid of the auto tranny and bought manual R154 manual gear from Marij from peshawar, he is a gem of a person and very nice guy, thanks Marij. and yes the Engine in this vehicle is 1JZ- GTE vtti.
    now it has been converted back to manual. the vehicle was originally manual. Thank God the clutch pedal was still there.
    all the manual clutch related stuff:
    1. master clutch cylinder,
    2. Slave cylinder.
    3. clutch fork
    4. stage 3, 6 puk eclustchmaster brand new from USA ( by upgrade Motorsports)
    5. R154 manual gear with lever( courtesy Maarij from Peshawar)
    rear new lights has been imported directly from Thailand from Ebay via Dubai, i personally brought them in my luggage.
    front lights are washed and serviced. the whole car body anti rusting has been done, denting has been done to bits, and now the car is under paint job. there are more stuff going in:
    1. greddy blow off valve
    2. dunlop drag radials semi slicks
    3. new racing radiator
    4. new stainless steel turbo pipping ( bought from upgrade Motorsports)
    5. new front mounted turbo inter-cooler
    6. air filter
    7. all the gauges, oil temp, turbo pressure, oil pressure , water temp etc.
    8. front strut bar
    9. all monograms original imported
    10. imported 3" inlet and 4" outlet Jasma approved exhaust
    now the car has been registered ( which was a hell of a task) and will insha'Allah come on road by the end of march. below are the pictures.
  2. #141
    imbigsmall's Avatar
    Jul 2012
    839
    3 Post(s)
    Quote Originally Posted by shezyworld View Post
    insha'Allah... i will show you two videos.. one of project and one of completed project. just wait a bit more..
    Yesss that would be great! Will be waiting.
  3. #142
    440
    440 is offline
    440's Avatar
    Aug 2007
    Rawalpindi
    23
    2,341
    7 Post(s)
    this is the same car at allmotor?
    honda+toyota+suzuki =440 =D epic yo!!
  4. #143
    mahmer's Avatar
    Nov 2008
    32
    26
    Hi guys.. If any one knows how to enable tiptronic on a 1jzgte vvti on a crown 2002 model, or an expert electrician based in lahore who can do this.. please let me know as im stuck in the middle of my project.
    Thanks
    Work until your signatures become an autograph!
  5. #144
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    Quote Originally Posted by margallar View Post
    maybe i will get in touch sometime then
    you are most welcome sir..
  6. #145
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    Quote Originally Posted by 440 View Post
    yes, its the same one. getting some professional work done from there. now every thing cant be done at home, a big shout out to the AllMotor guys who are doing and giving such professional services in lahore.
  7. #146
    440
    440 is offline
    440's Avatar
    Aug 2007
    Rawalpindi
    23
    2,341
    7 Post(s)
    bhai jaan koi detail pics bhejain ap mazay mein khalal paida na karain
  8. #147
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    Quote Originally Posted by mahmer View Post
    Thanks
    come to Allmotor workshop. i am sure their electrician can do that..
  9. #148
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    sorry for that, i just have to take some good photos for the update. right now i dont have enough material to post here. insha'Allah on this weekend you will find an update. check the thread on Saturday night..
  10. #149
    mahmer's Avatar
    Nov 2008
    32
    26
    Address please?
  11. #150
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    Address please?
    Usman is owner of Allmotor workshop, his number is 0323-4024840 . talk to him about the issue and he will guide you accordingly.
  12. #151
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    sir, would you happen to know of any good welder in lahore. My car needs some metal patch replacement, but all i can find is crappy acetylene gas welders, no one uses MIG.
    haters gonna hate, potatoes gonna potate
  13. #152
    Hassan1991's Avatar
    Mar 2013
    20
    2,267
    37 Post(s)
    Brother I don't think even a single welder knows about MIG welding.
    The first step towards knowledge is to know that WE are IGNORANT
  14. #153
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    contact AllMotor. they can do this.
  15. #154
    shahidkamal23's Avatar
    Sep 2011
    No more updates on the project?
  16. #155
    shaheryar.khokhar's Avatar
    Dec 2013
    1,692
    28 Post(s)
    Its almost close to finish now. Car is on road now and is performing very well, took the very first road test with him and it was scary lol, MashAllah. @shezyworld Congratulations man, you've done it.
    Sent from my SM-J700H using PW Forums mobile app
    - Honda Civic ES, Build Thread. Link ---> http://goo.gl/3SocBg
    - Honda Civic EG - SiR-T F20B Build Thread. Link ---> http://goo.gl/5Y4W9m
  17. #156
    shazo's Avatar
    Aug 2010
    26
    3,418
    240 Post(s)
    7 Thread(s)
    Quote Originally Posted by shaheryar.khokhar View Post
    Hahah i still have your screaming video with me.
    Well final pictures and videos will be disclosed very soon guys. congratulations again shazy
    Sent from my H30-U10 using PW Forums mobile app
  18. #157
    shezyworld's Avatar
    Mar 2009
    34
    489
    6
    3 Post(s)
    thank you guys..
    Alhamdolilah .. Allah ka bohat shukar hey bohat ihsan hey.
    the car is on road, just waiting for few important things to be done, and as Shazo and Khokhar has said, yes the ride is really scary, needs a lot of control nd gutts to pull the car to red line.
    i am just compiling a video and soon will do the editing and upload it. sorry for delays.
    but again, would not have been possible without AllMotor team.
    regards,
    Shehzad
  19. #158
    hash4u's Avatar
    May 2005
    38
    24,367
    18
    404 Post(s)
    13 Thread(s)
    13
    Congrats & b safe !
    Sent from my GT-I9500 using PW Forums mobile app
  20. #159
    Dec 2013
    1,692
    28 Post(s)
    Quote Originally Posted by shazo View Post
    Hahaha screaming videos lol.
  21. #160
    Sep 2011
    The wait is real O_O
