Results 1 to 5 of 5
Thread: A/C Issue..need troubleshooting advice
    morff14's Avatar
    May 2009
    Rawalpindi
    31
    114
    Default A/C Issue..need troubleshooting advice
    Hi everyone,
    My car's A/C is giving the following problem. The A/C compressor stops working randomly. fan keeps running and blowing warm air. When the A/C is working, it's working perfect. Happens both at high speeds, low speed and even idle.
    If I turn off the AC and back on, compressor still doesn't kick in. But if I switch the ignition off and then back on, compressor starts working and cooling becomes alright. But the same thing happens again in less than 3-4 minutes...and sometimes after 5-10 minutes.
    So basically, the compressor stops spinning and power cycling the ignition brings it back. The AC switch does nothing. I haven't been able to observe any pattern to it except maybe that it's worse at high speed (interval time between two occurrences is less than 2 minutes at times).
    Any ideas?
    Thanks in advance.
    pistonhead's Avatar
    Dec 2009
    86
    1,445
    24 Post(s)
    Which car are you talking about?
    Quis custodiet ipsos custodes?
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    789
    55 Post(s)
    2 Thread(s)
    Firstly have a look at the connection of thermostat.
    And then see by adjusting thermostat you get any better results. After that direct supply to compressor for few seconds ensures if the coil of compressor is working fine. If it's coil then compressor would be fully replaced in case of nissan.
    STYLISH BOYZZZ STYLISH ATTITUDE
    morff14's Avatar
    May 2009
    Rawalpindi
    31
    114
    Update: it's compressor coil was diagnosed to be faulty (have too much gap). The coil was taken off and fixed on a grinder to reduce the gap. The AC started working perfectly but after a trip from lhr the same week, the compressor started making a noise. Replaced the whole compressor and now doing fine.
    For reference, the AC compressor is around Rs. 5000 (kabli). They charge almost the same for the cool only too because without that the compressor becomes useless. However if some shopkeeper has a working coil attached to a faulty compressor, they will charge you around Rs. 2000 for the cool.
    Note: both changing the compressor or the coil required the AC refrigerant Gas to be refilled which costs around Rs. 2000.
    Thanks everyone.
    dani_kk's Avatar
    Jun 2009
    Rawalpindi
    789
    55 Post(s)
    2 Thread(s)
    For the Nissan if you face coil issues get a kabli compressor it costs you around 3k with guarantee
    If it has noise or any other issue it can be changed. To ensure its functionality you've to have a good ac technician. And then you'll get good cooling.
    Sent from my SM-G360H using PW Forums mobile app
