Aoa to all pakwheels members.
Deep white smoke coming from exhaust (engine is in final days) and there are some issues with gearbox too so i am planing engine swap.(Engine rebuild not an option). I will run my car on petrol only.
I have around 70 to 80k budget and i need some suggestions
1) Which engine i should swap?
- GA15de and QG15de(complete) are available in sher shah market and shop wala quoting 60k for them
- QG18de also available for 80k
All engines are in pristine condition.
2) What changes will be required if I choose QG15? (I know GA15 will be easiest to swap)
3) Are all the required sensors comes with engine?
4) Some people are saying you have to change your fuel tank for EFI setup and you will need new brake paddle and cluster. Is is true ?
5) If i choose QG18 what changes and alteration will be required
Before swap I will install new Radiator and new wiring
My Car suspension system is new. Recently installed KYB shocks with new coil spring, new swing arm, new tire-rod and reckend. Brakes are in good condition. Recently installed new brake pad and rear drum piston system.
