Results 1 to 6 of 6
Thread: Sunny 1300 M/T or A/T
    hank007's Avatar
    May 2005
    44
    134
    Default Sunny 1300 M/T or A/T
    Farhan_M3's Avatar
    Jun 2005
    new york
    31
    239
    i say get the manual transmission less probs and the ac doesnt matter in usa mostly it runs with the battery i dont know abt pk
    Sameer_82's Avatar
    Oct 2004
    34
    14
    Simply, AT is high on consumption no matter whichever car you buy. MT is better if your really concerned abt the fuel and pickup.
    No, AC's do not run on battery. The compressor is run by a belt connected to the engine by a pulley. The fuel consumption increases on a perfectly tuned car on average to abt 10%. Considering the traffic conditions and no problem with the fuel you can go for AT.
    sali2002's Avatar
    Feb 2005
    30
    1,077
    hello!
    i suggest to go with manual one.....A/C was not a problem in it...it runs just fine....A/T is little thristy of fuel so i recommend u to go with manual one...and farhan A/C in USA runs on battery ....starnge listening man...how many Volts just ur battery is given to drive ur A/C Compressor.....man its driven by Engine...no battery....its not a 12v Dc motor......its A/C compressor...
    Thanxx
    sheriar's Avatar
    Apr 2005
    Abu Dhabi
    60
    62
    sunny 1.3 with AC is a joke.while you use with AC its power is badly reduced beside EFI system on sunny has genuine fault.Once any of one sensor malfunctions than car will stall and only Company has arrangements to rectify it.If you have to pay than it is quite costly.
    Well I do not discourage the buyers or users but informing about precausions which should be considered.
    BornToRide's Avatar
    Apr 2005
    38
    310
    for FARHAN,
    Can you pls explain how AC works on batteries??????????
    Dolls r Born to be MILD
