Users...
I Think The DSL Light Blinking Issue Is Not Due To Modem Heatup....Its Based On your Copper Media From Exchange Till Your Area Main BOX And From Box Till Pole And From Pole Till Your Modem....!!
Get UTP Cable Installed From Pole To Your Modem Without Any Joint In B/w.....If Problem Presist...Ask Your Line Man To Check BOX Till Pole Pair And Replace With Some Good One...If Still problem Remians..Then Its Your Main Pair From Exchange Till Box Which Is Dropping And Loosing Data.....Media Is Dead And You Need Main Pair Replacement Which Is Quiet Some A Hard Job....Mostly Main Pairs Are Not Available Due To Old Underground Copper Lines....!! If Available...Try Replacing That
I Got LDN And It Works With DC's On Initial Months..Now The Main pair Is COmpletely Dead And Is Not passing Data......!! Sometimes Connect..Sometimes.Get Disconnect....!!
LDN Also Simply Stated That Replace Your Main Pair By Contacting PTCL Staff Since PTCL Just Don't Cooperate WIth Them......!! Else..I Can DC Their Service Since They Clearly Said Problem Remains....Till Pair Not Changed.....!! Not This...Any DSL On This Media Won't be Working Wheather PTCL Or LDN Or MAXcom r Any...!!
So Thats The Whole Story of DSL I Get To Know In Last Couple Of Months.....!! If Your Media Is Good..Your DSL Works Awesome..Else You Keep On Facing Modem Unsinking Issue....!!
I Am trying To Get My Pair Changed But No Luck.As They Said No Pair Available.....!! Worldcall Broadband...almost Same Price And Just 128kbps :(.....!!
Wimax Is SomeHow Expensive To Get....!! Internet...Never Been Easy In Pakistan....!!
