Description:
Connect your favorite videogame console (or any other video source) to your monitor or LCD with the VGA Box. The VGA Box accepts video signals from any video source through the standard AV port (RCA IN) and the S-Video port. It also has a pass through port for your VGA cable (VGA in & VGA out), so that you don’t need to unplug your PC whenever you are about to use it. This product is recommended for users of TFT monitors and lcd, as it supports higher output resolutions.
http://img42.imageshack.us/img42/8033/pa06196006.jpg
Features:
Connect your video game consoles, DVD player or other AV equipment to your PC monitor
The DEINTERLACE can provide high quality picture, It can give sharp, stable image output to VGA.
Compatible for Multi Signal inputs: Video, S-Video, PC ( bypass ).
PICTURE MODE : SPORT MODE, STATIC MODE.
RESOLUTION : 640*480, 800*600 and 1024*768.
FREQUENCY : 60 Hz and 75 Hz for each resolution.
Built-in microprocessor.
No software driver required. It is applicable to all the O/S.
Input Video system 50-to-60HZ frame rate detection (NTSC/PAL(SECAM) for Video, S-Video).
The DEINTERLACE output mode can be changed from 640*480, 800*600 to 1024*768. ( 60 Hz & 75 Hz )
3D Motion-adaptive interfiled de-interlacing.
Supports function OSD (on screen display) control.
OSD control menu : BRIGHTNESS, CONTRAST, COLOR, HUE, SHARPNESS, SHARPNESS, RESOLUTION, FREQUENCY, WINPROTECT,MONITOR,SOURCE,RESET.
