GodswMobile, the makers of SMS Transfer, have released a new application called Pocket Call Blocker.
As the name would suggest, the purpose of the application is to block unwanted incoming calls and sms. Unlike other software available for doing this, they have managed to keep the application as simple as possible. You simply add numbers to the filter list and the program prevents those numbers from calling you. Also unlike other applications available, the software does not simply ignore calls from those numbers – it instantly hangs up the callers. This prevents the unwanted callers from even reaching your voicemail! BTW, it could also used as a sms spam filter.
Key feature description from pocketcallblocker.com
* Multiple filtering rules - filter by specific numbers, wildcard numbers, anonymous and unidentified numbers, groups/categories numbers, contact/non-contact numbers; all numbers.
* Two incoming phone call block actions - hang up and mute;
* Two SMS block actions - delete and mark as read;
* Built-in phone number block log;
* Run on background;
* Easy way to operate and set up filter rules;
The application runs on Windows Mobile Pocket PC 6, 6.1, and 6.5 and is available from pocketcallblocker.com for $19. But I found a discount order link with 50% off.
https://www.regnow.com/softsell/nph-softsell.cgi?ss_coupon=GODS-Q1JP&item=22132-6
Step by Step guide of blocking unwanted incoming calls and sms
How to block phone call, how to block incoming call ? Pocket Call Blocker for Windows Mobile
