What about inside the room? Noted any difference...?
well kafi farq ha yar-ab phatkary ac wla maza to dne se rhi
Thank you very much, I will try
Yes But if that heat coming from roof/fan is reduced, than it has done the job. Real problem in these days is the extreme heat of roof and walls due to which fans is working like Heater ..
can you tell me that how much temp has deceased ?
one marla is 15 X 15 feet?
great, you can add some more water to use the same quantity for one marla.when its wet, it seems that it is enough, but once it dries out, it becomes more and more white
one marla is 250 square feet, like 25 X 50 = 1250 feet = 5 marla,,, in old day 1.marla is equal to 272 square feet.
