Dear sir
Last year I upgraded my system from Girlfriend 7.0 to Wife 1.0 and
noticed that the new program began creating problems within the system
processing and that took up a lot of space and valuable resources.
Wife 1.0 installs itself into all other programs and launches during
system initialization, where it monitors all other system activity.
Applications such as Poker Night 2.3, Girlfriend 3.2 and Saturday
Football 5.0 no longer run, crashing the entire system whenever selected
I cannot seem to keep Wife 1.0 in the background while running my other
favorite applications. Whichever module or software I enter, only Wife
1.0 seems to run and nothing else.
I am thinking about going back to Girlfriend 7.0, but the uninstall from
Wife 1.0 to Girlfriend 7.0 does not work on this program. Can you help
me, please!!!
Thanks,
Shahzad.,
Reply
To: Shahzad.
Dear , Shahzad.
This is a very common problem men users of the Wife 1.0 software complain
about but it is mostly due to a primary misconception of the software.
Many men upgrade from Girlfriend 7.0 to Wife 1.0 with the idea that Wife
1.0 is merely a UTILITIES & ENTERTAINMENT program.
Wife 1.0 is an OPERATING SYSTEM and designed by its creator to run
everything. It is unlikely you would be able to purge Wife 1.0 and still
convert back to Girlfriend 7.0.
Hidden operating files within your system would cause Girlfriend 7.0 to
emulate Wife 1.0 so nothing is gained. It is impossible to uninstall,
delete, or purge the program files from the system once installed !!
You cannot go back to Girlfriend 7.0 because Wife 1.0 is not designed to
do this. Some have tried to install Girlfriend 8.0 or Wife 2.0 but end up
with more problems than the original system. Look in your manual under
"Worries Invited For Ever (Wife 1.0)".
I recommend you keep Wife 1.0 and just deal with the situation. Having
Wife 1.0 installed myself, I might also suggest you read the entire
section regarding general partnership faults (GPFs).
You must assume all responsibility for faults and problems that might
occur, regardless of their cause. The best course of action to solve this
major IT problem of yours will be to enter the command C:\APOLOGIZE.
In any case avoid excessive use of the Esc key because ultimately you
will have to give the APOLOGIZE command before the operating system will
return to normal. The system will run smoothly as long as you take the
blame for all the GPFs.
Wife 1.0 is a great program, but very high maintenance.
Consider buying additional software to improve the performance of Wife
1.0. I recommend you to install the latest gift software like Flowers
2.1, Necklaces 3.2, and Chocolates 5.0.
note: Do not under any circumstances, install Secretary With Skirt 3.3.
This is not a supported application; in fact it is a deadly virus for
Wife 1.0 and is likely to cause irreversible damage to the operating
system.
regards,
Fahad.
