Results 1 to 17 of 17
Like Tree2Likes
  • 1 Post By Xulfiqar
Thread: Daewoo RACER - EPS installation?
    djkid316's Avatar
    Nov 2005
    27
    57
    Default Daewoo RACER - EPS installation?
    I've bought a DAEWOO Racer yesterday but its STEERING is just too hard to control.I would like to install a EPS SETUP on the CAR. Where can i get it done in KARACHI and for how much? :/
    Quick Replies would be much expericiated as I'm going to PLAZA Later Today anyway.
    margallar's Avatar
    Oct 2009
    9,957
    6
    283 Post(s)
    4 Thread(s)
    it will cost max 10k including fitting, can be done at scrap markets
    haters gonna hate, potatoes gonna potate
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    daewoo racer steering hard? you sure. If you are young then please hit the gym. This cars steering is very softly geared already, once the car is creeping I could literally palm the steering of a daewoo racer.
    I would suggest you first check the entire alignment.
    djkid316's Avatar
    Nov 2005
    27
    57
    Its a ISSUE of my CAR. not all cause i've driven DAEWOO RACER before thats why i've gone for it. THE SELLER whom i've bought it from saying k GARI KI SERVICE KARWALO GANDI HORAHI HAI ISLIYE DUST JAMGAYI HOGI. is this correct?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    firstly if you use the original 155 tyres the steering will return to original softness, you should also make sure that the camber is correct and the ball joints are not worn out. The steering gearing ratio is already very high which causes the steering to be soft.
    If you do want power steering in your car then why not go for the complete original hydraulic power steering - there are two shops on Tariq Road who have the entire setup including the pump which mounts on the block and the entire steering rack.
    djkid316's Avatar
    Nov 2005
    27
    57
    Tyres are ALLOW rims with the size of 175/R13-14 i dunno about RIM but size is 175. and for how much can i get this job done from tariq road? and also mention the shop names. and i also have a ISSUE of its GEAR box. its very difficult to change gears.. GEARS jaga pe betthey nahi hain. i mean when i CHANGE the gear from 1 to 2 .. sometimes 4th lagjata hai even though meine 2nd hi lagaya tha :/
    Can i get its GEAR BOX changed to normal one with reserve on the FAR RIGHT side? If yes then how much would it cost me?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    well - they are called alloy and not ALLOW rims, and you should know that you cannot simply bolt on any sort of wheel to a daewoo racer, it needs hubcentric rims (the load on your cars wheel is not on the bolts holding it its on the hub snout. If you install wider rims or even wrong offset you will have a very very hard steering as the wheel geometry becomes garbage and you will end up with a car that has a turning radius of the moon itself.
    The gearbox problem you have is not the gearbox itself, but you need to replace all the bushings of the selector lever, Any mechanic who does Daewoo repairs will fix it, If you go to Tariq Road ask for the Daewoo mechanic - they will guide you correctly.
    And please throw away any wrong "ALLOW" rims that you have - the results are disastrous if the wheel loosens itself (and if its not hubcentric it WILL LOOSEN ITSELF) - Match the offset with the original steel wheels that came with your car and inspect the mounting face too, if its not flat and flush you will also overheat the wheel bearings and brakes.
    Site Banned Follow
    vyrus's Avatar
    Nov 2009
    25
    1,611
    lol faheem seems like your car has a lot of issues . I'd say just get an EPS instead of hydraulic, too much of a hassle. As for the gear box, you're gonna need to see the shift forks, must be grinded.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    nah the ZF brand gearbox this car has is very heavy duty, the shift forks nearly never wear out unless its run with zero gear oil for a long time, the weak link is the gear selector lever and its corresponding arms outside the gearbox. My VW Golf was also set like that, requires a careful hand with a lathe and a stick of teflon to make all the bushings. All 10 of them.
    Newbie Follow
    iq786pk's Avatar
    Jan 2008
    Rawalpindi
    47
    Does any body have Daewoo Racer owner's manual or maintenance manual or from where I can get it?
    djkid316's Avatar
    Nov 2005
    27
    57
    LOL. i know that is alloy. I made a typo thats it bro.
    And what should i do to get rid of hardness of the STEERING. should i go for HPS setup or i need to replace the tires?
  12. #12
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    first inspect your entire suspension and see the wheel offset which is stamped onto the wheels themselves, compare to the spare wheel you have in the boot.
    the number you are looking for is ETxx - see both and post here.
  13. #13
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    Sir it is also stated that we can use 175-70-R13 in our woo's other than 155-80-R13 whats you take on that?
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
  14. #14
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    4 yrs old thread,
    the wider tyres are usable - but with correct wheels only - wheels should be selected according to the technical requirements and not looks and vanity.
  15. #15
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    does daewoo stock engine has power streering I have seen many daewoo but not a single one with stock engine every car was swapped with 2c,1c,e2,cd17 etc
  16. #16
    Sep 2012
    Rawalpindi
    26
    2,488
    59 Post(s)
    Quote Originally Posted by saboor73 View Post
    Sir i have woo in completelt stock state.The original engine was G15SF 1.5L SOHC TBI engine imported in Pakistan as taxi scheme..Later models were not introduced and thus cielo/nexia parts started arriving via torkham(kabuli) G15MF (having MPFI) system,,G16Sf(Lemans/nexia) 1.6L SFI engine.In twin cities there are many woos with stock engine.
    Stock woo has no EPS,it can be upgraded using cielo EPS assebly.Also adding the all the engines stated above are bolt on with no modifications required in chassis.
    People generally swap other engines due to scarce parts and mechanics unavailability.Daewoo should be kept as stock as possible.Swapping other engines are not advised as it effects the integrity of chassis as well as car's balance
  17. #17
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    mechanics usually change the engine because they do not usually use 9,13,15,19,24 and 32mm tools - hence they never buy them. Daewoo Racer has all of them, its a very very very simple engine and extremely easy to work on.
    Problem in Pakistan is that if a mechanic sees that he cannot understand it and make some money in 5 minutes then "bhai injun badli kardo" - that makes them a lot of money initially and also guarantees future income as the owner will need to visit him back every week of his life with the car. You can however buy the rack and pump from scrap and then install it - it fits between the timing belt cover cavity on the block directly. The power assisted rack is geared lower for quick turn.
    Daewoo Racer in taxi form never came with power steering and honestly it never needed it, The steering rack ratio is pretty nice and the car is very easy maneuverable due to that. The problem starts when someone installs stupid wheels on it and also installs junked or welded up shitty parts in the suspension and CV joint area.
