Results 1 to 14 of 14
Thread: Best ATF fluid for Mercedes 722.6 auto transmissions?
    cruzee's Avatar
    Aug 2010
    227
    8 Post(s)
    Default Best ATF fluid for Mercedes 722.6 auto transmissions?
    salam to all pakwheelrs,
    I want to change my 97 Merc C180, 722.6 trans ATF, don't know what previous owner used, searching best atf for it, 236.10 specs.
    Mercedes genuine atf is available at shahnawaz but very expensive almost 3000/L, other shops selling but don't know is it 1 or 2 no, many other brands available & approved 236.10 specs exp MEGUIN, VAICO LIQUI-MOLY all made in germany, at reasoable price, these brands are available from there orignal importers but don't know about performance, INH also selling VAICO but don't know about it.
    Want advice from experts what will be best, what they using, especially from zulfiqar bhai.
    There's no car like Mercedes-Benz.
    onlyfaith's Avatar
    Sep 2010
    5,934
    8 Post(s)
    dont risk your merc with these cheaper ATF in marketchoose priority wise
    Merc company ATF
    Dexron III by GM. dont knw whether availible here
    Mobil ATF
    top documentaries " Tears of Gaza"
    Teeboyuk's Avatar
    Sep 2012
    Other
    1,608
    8 Post(s)
    Hi..only use mercedes fluid ..go to your local dealer..you'll need a filter as well..and washer ..
    Pakistan.. Toyota hilux..golf mk2 gtd..rolla 2.0d..nissian sunny.. Yamaha pw 50.. Coventry uk....audi v8 d11..golf mk2 rallye..honda crx..evo 8..golf mk2 gtd..Vauxhall insignia..
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,403
    131
    3990 Post(s)
    94 Thread(s)
    6
    the 236.10 datenblatt (data sheet) is old spec, you can substitute it to 236.12 which has FUCHS Titan 3353 ATF, it should be cheaper than OE mb fluid - which should be 20 USD/lit
    the FUCHS should retail close to USD 10/lit - and you need about 8 litres, a new filter, pan gasket - if the connector sleeve is leaking you need a new one and make sure the electrics plate is good - otherwise you need to change that too. btw you need to get a dipstick tool or make one yourself to measure fluid level.
    DO NOT UNDER ANY CIRCUMSTANCES USE DEX3 in it.
    Be careful with the dipstick cover lock, dont break it, new one would be Rs 100 or something though.
    cruzee's Avatar
    Aug 2010
    227
    8 Post(s)
    Xulifiqar bhai FUCHS Titan 3353 ATF is not available here, only Meguin 236.12 & 236.14 available, company says its especially made for MB tranny, can i use it?
    cruzee's Avatar
    Aug 2010
    227
    8 Post(s)
    cruzee's Avatar
    Aug 2010
    227
    8 Post(s)
    where are you Xulfiqar bhai?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,403
    131
    3990 Post(s)
    94 Thread(s)
    6
    looks good on paper - be sure to get a reciept from the seller and ask where he gets this from, send an email to ask the original distributor just for safety sake.
    get new plastic bushings for the select lever too, the original would be crumbled or missing by now.
    cruzee's Avatar
    Aug 2010
    227
    8 Post(s)
    I have checked a original distributor in pakistan from company web site,he is selling original product, i will get it direct from him, plastic bushing is good in condition, i bought new filter and gasket, so i can use it?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,403
    131
    3990 Post(s)
    94 Thread(s)
    6
    yep - good to go, please be very dead on sure that you measure the level of ATF while the engine is running and the transmission temperature is atleast 80*C - the manual recommends to use a thermosensor dipped in the trans, To be safe check it after driving the car really hard for 30 minutes.
    You can make the dipstick tool with some stiff pipe or even some nylon wrapped thick speedo meter or control cable, its supposed to be 1220mm long - longer if you wish as its supposed to bottom out and the leading edge marks should be at 10 and 20 mm for cold and 56-66mm for warm. Only test the level at the warm side - cold side is downright silly.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,403
    131
    3990 Post(s)
    94 Thread(s)
    6
    the mid life 202 came with both 722.5 and 722.6 boxes - nice that you have a 722.6 - its a very strong trans.
  12. #12
    cruzee's Avatar
    Aug 2010
    227
    8 Post(s)
    Thanks Xulfiqar bhai my pressure is relief now, every body miss guide me, actual reason is that i use exact sheet no which is prefer for this trans, orignal ATF is only avail at shahnawaz, others claiming original but i am not sure, thanks for dipstick advice, yes i made a curtain wire dipstick for this by searching at google.
    is exact level 56cm when dipstick touchs bottom of pan? sure in warm.
  13. #13
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,403
    131
    3990 Post(s)
    94 Thread(s)
    6
    56mm which is 5.6cm the entire length from the tip of the fill port to the edge of the stick should be 1220mm which is 122cm
  14. #14
    cruzee's Avatar
    Aug 2010
    227
    8 Post(s)
    Thanx xulfiqar bhai
