Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Xulfiqar
Thread: Mercedes: HID or Philips Extreme
    oklodhi's Avatar
    Oct 2007
    440
    3 Post(s)
    Default Mercedes: HID or Philips Extreme
    Hi
    I recently purchased a Mercedes 1997 model. One of the previous owners had changed the lights to DEPO halogen projecters. The left side has Narva bulb h7 55 watt while right side is Philips h7 55watt. Low and high beams are separate.
    These are the pictures taken from cell phone
    High Beam
    Mercedes HID or Philips Extreme -1141860
    Low Beam
    Mercedes HID or Philips Extreme -1141861
    The light is ok but not very good.
    I am thinking of upgrade to
    1. HIDs temperature of 4300k for low beams only (are HIDs of 4300k legal in Pakistan meaning no challan)
    2. Philips Extreme Vision 55watts bulb
    My primary aim is to increase the light and see better. I am not interesting in blinding other drivers. Sometimes the drivers coming from other side have turned on high beam and you cannot see the road.
    What would be a better option?
    Range Rover Classic 1986 3.5L Petrol V8
    zohhadkhan's Avatar
    Dec 2011
    45
    Bro 4300k hid's have no chalan on them but getting hold of a pair is very difficult and expensive unless you get some of your known persons to get it from abroad. I am currently using Philips Extreme Vision and the result is actually far better than atleast OEM's. So in either way both of your choices are okay and am pretty sure that they are going to satisfy you.
    umer325's Avatar
    Sep 2010
    4,519
    65 Post(s)
    4 Thread(s)
    Bro both are good options but i think you need to adjust your headlamps. They are low from their actual point i think. 1st get your lghts alligned and then think about other options.
    cruzee's Avatar
    Aug 2010
    227
    8 Post(s)
    Lodhi bhai, 1st show pic of what headlight previous owner install? if your MB is w202 then 97 w202s has improved headlights then 94-96, better is install genuine Bosch headlights set (used available from pindi) then install H7 6000k Hid, (mine also), result will brilliant.
    There's no car like Mercedes-Benz.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    what sort of headlamps concentrate the light only on the road - the RHD pattern have it aimed to the left, opposite for LHD.
    oklodhi's Avatar
    Oct 2007
    440
    3 Post(s)
    Quote Originally Posted by Cruze View Post
    Link on Amazon
    Depo 340-1117PXAS Mercedes Benz E Class Chrome Headlight Assembly Projector : Amazon.com : Automotive
    Mercedes HID or Philips Extreme -1142307
    cruzee's Avatar
    Aug 2010
    227
    8 Post(s)
    This W210 depo projectors can be improve installing by H7 HID bulbs, color temp is yours choice.
Tags for this Thread
