Page 12 of 370 FirstFirst ... 210111213142262112 ... LastLast
Results 221 to 240 of 7393
Like Tree425Likes
Thread: Daewoo fan club
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Daewoo Racer/Cielo Fan Club
    Dear All,
    I am an owner of Daewoo Racer since 1995. It has proven to be a very comfortable and economical car throughout this period. It used to give an average of 13Km/L within city and ~15Km/L on long drives. Here are some pictures:
    Daewoo fan club -479355
    Daewoo fan club -479356
    Daewoo fan club -1050638
    Check the links for my rides
    1. Before 2008 (Racer)
    Daewoo Racer
    2. After Jan 2008 (Cielo)
    Daewoo Cielo
    I would recommend buying this car who want a better car at low budgets!
    Any member having used a Daewoo car must share their experience....(y)
    IMPORTANT: SCANNER Facility is Available at Friends Autos, I-9, Islamabad. [Khalid: 0322-5111110, 0321-9562840]
    Quick Links:
    Parts Dealers/workshops link [Page-3 post #:54]:
    Alloy Rim fitment [Page-15 post #:290]:
    The DOHC engine[Page-30 post #:585]:
    Service Manual/Electrical Diagrams link[Page-30 post #:594]:
    Cielo Conversion [Page-57 post #:1130]:
    How to get Black Bumpers [Page-60 post #:1315]:
    Reading ECM Error Codes [Page-191 post #:3804]:
    Air Conditioner maintenance shops [Page-195 post #:3897]:
    High RPM/Stalling Problem on AC, OK Otherwise[Page-203 post #:4048]:
  2. #221
    Proverbial_Slang's Avatar
    May 2005
    3,906
    29 Post(s)
    AoA,
    Can any1 confirm if daewoo racer hubs have pcd of 110? I read somewhere on this thread that Charade rims can be put on Daewoo Racer.
    Death is not the greatest loss in life. The greatest loss is what dies inside us while we live.
  3. #222
    abdulr76's Avatar
    Apr 2005
    41
    149
    5 Post(s)
    Dear All, and (testDrive)
    I am happy to see that now really understand GM EFI.
    Could someone help me in replacement of Daewoo Racer A/C with conventional A/C used in Toyota/Honda/Suzuki etc ..... . The problem I have faced is with high/low pressure switches and ECU signaling while A/C Clutch ON.
    I tried to connect conventional a/c, when it turn ON, idle speed drops or engine stop. However, A/C was working and satisfactory cooling achived.
    I feel, it can be possible to connect a conventional A/C in daewoo Racer if wiring is handle properly. or 12+ will be provided to ECU desired pin.
    Need valuable feed back from all and specially testdrive.
    Regards,
    Abdul Rauf.
    Abdul Rauf
    !!!Save Unimogs……………!!!
  4. #223
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    @shahabrk
    Daewoo has the following sensors.
    1. Throttle Position Sensor (TPS) - attached to throttle body
    2. Coolant Temperature Sensor (CTS) - Under throttle body
    3. Manifold Absoulte Pressure Sensor (MAP Sensor) - Vehicle fire wall
    4. Vehicle Speed Sensor (VSS) - above gear box (leading to Speedo cable)
    In addition to that, it has an Idle Air Control Valve (IAC Valve) to control the Idle engine RPMS....
    @Proverbial_Slang
    Daewoo's hub has PCD of 100 same as that of Charade, so you can fit them interchangeably.
    @abdulr
    The problem seems with the A/C relays in the fuse box. Get your car checked by an electrician. As far as replacement of the A/C system is concerned, you can also replace the whole system, since ECM only provide a signal to the A/C relay, and then it is put forward to the compressor....
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
  5. #224
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    @proverbial_Slang
    Do visit the following Website
    Adnan's
  6. #225
    shahabrk's Avatar
    Nov 2004
    36
    247
    2 Post(s)
    thanks testdriver i needed that sensors list becoz i am in a process of overhaulling the egine and change all the sensors of my car also and also u didnt tell me the phenomena of the car i told u abt wa does it coz to happen that way.
    thanks for the list of sensors again .
    See the dark side
  7. #226
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Actually RPMs are adjusted on the basis of VSS during motion, so this is quite normal, if the RPMs comes down when the car is static. If the RPMs are not coming down, the Idle Screw, TPS or the CTS might be problematic.....
    Adnan's
  8. #227
    May 2005
    3,906
    29 Post(s)
    Thanx a lot testdriver. Really appreciate the answers. The reason I asked this question is that I have a 1985 G11 Charade and the tyre shops tell me I can't fit any other car's rims on it.
    From the link u posted, it seems there r quite a few cars who's PCD matche including ppre 1992 civic and accord.
    Thanx again.
  9. #228
    devilousangel's Avatar
    Aug 2005
    31
    387
    subb ko salam!
    Now, i need sum suggestions from the experts only. I have been playing with daewoo engine for the past 8-9 years. Yes i m the one who turbo chraged daewoo engine. Now i want more power so have planned to get some other engine for ma beast. I HATE HONDAz! so forget about the DOHC thingy. The engine which i m interested in is 4Throttle its a 20v (silver top). Now any one who has good knowledge about the daewoo and this engine can guide me if its suitable for me to swap the engine or not. Ill be greatfull.
    P.S I drive on petrol so dont worry about the CNG problems.
    i am alive... must b da reason y i m king of my castle! must b da reason y i m free in my trapped soul.....
  10. #229
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    @devilousangel
    Why don't you go for the engine like the one in my car? It is producing ~30N.m. more torque and ~20HP more than the TBI engine. You can play around with that engine to produce more HP, like putting a turbo. I think a 1.5L engine with ~140 HP and ~150 N.m torque will serve better. The most important thing is that you don't have to alter anything in the wiring, engine bay, and the current gearbox is bolt-on. Just the engine with ECM and wiring will cost you around Rs.30K.
    If going for any other engine like 20V ST, you have to modify the engine bay, the complete wiring including the entire indash wiring, rear wiring, battery wiring, ignition switch wiring and the fuse-box has to be replaced/altered which needs an expert electrician.....If you can easily manage to do all these things you can go for the swap
    Adnan's
  11. #230
    shahabrk's Avatar
    Nov 2004
    36
    247
    2 Post(s)
    thanks test driver so if i will replace the vss and tps it can solve my problem coz many cars i have seen dont do like this like increase of rpm when putting the gear on nuetral when the speed is high like 100 or 120
    See the dark side
  12. #231
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Hopefully your problem will be resolved (y)
    Adnan's
  13. #232
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Salam All,
    I have a problem with my car... its heater core leaked a year back... and as usual i cut its water supply and left it like that
    now these rains have actually forced me to plan a DIY on this weekend to fix the core leak.
    I know the core's location and am experience in DIY fixes... but handling daewoo's fragile dashboard is not easy
    I need information on this... anything that anyone knows on how to easily get the core out... which dash panels need to be opened... anybody having had similar problem or had seen dashboard dismounting.. HELPPP !!
    I'll post the pics when and if i finish the job...lol...
    75% of earth is covered by water... the rest by Jeep
    www.brokenknucklegarage.com
  14. #233
    beeberg's Avatar
    Mar 2006
    Select City
    33
    4,123
    All daewoo lovers please check this link.
    https://www.pakwheels.com/forumreply...umID!1~pw.html
    @testdriver
    adnan bhai this car is one which i saw earlier and gave token but later file was missing so cancelled the deal. later i saw cielo after discussion with you and dad it is sure that cielo parts would be very hard to find.
    anyways please give comments on above link, how much price should be done for this daewoo?
    life style: pakwheels
  15. #234
    Aug 2005
    31
    387
    helllo guys this is my daewoo deez days am working on a new project ENGINE SWAP am putting in 20v in ma beast...
    Daewoo fan club -686405
    Daewoo fan club -686406
    Daewoo fan club -686407
    Daewoo fan club -686408
    Daewoo fan club -686409
  16. #235
    shaan's Avatar
    Oct 2005
    39
    384
    4 Post(s)
    Thank you everyone for your comments and appreciation.Quite busy since 2months thus couldnt log to Pakwheels.
    Upgraded my vehicle---Replaced bumpers with original Racer one`s,Installed via DIY,rear parking lights in bumper,Got minor dents fixed,Changed battery to Yuasa 66ah original japan,replaced rear springs and shocks,new Rt engine sheet,Corona side view power mirrors.
    Here are the pics:-
    Daewoo fan club -689436
    Daewoo fan club -689437
    Daewoo fan club -689438
    Daewoo fan club -689439
    Life is Precious -- Drive Carefully
  17. #236
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    im now thinking abt the brakes of my daewoo.... i have heard some success stories abt servo/master cylinder replacement with a toyotas... but i want to know more... specially those who have actually that.... are the result worth the effort.
    this next DIY will take place InshAllah soon... im just trying to get the service manual to make things better
    @shaan
    nice car bro.... i really liked that front bumper and grill... where u got these from? custom made? let me know where u got this work done from.
  18. #237
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    changing only the proportionating valve gives same result as a full servo and master cylinder replacement.
    Keep a cool head and wear seatbelts!
  19. #238
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    @shaan
    (y).....Looking nice. These bumpers are of 'Fantasy' and 'Racer GSi'. For how much you got them?
    @Akif
    Change the brake setup if necessary. I upgraded the brake system (servo+mater cylinder) due to a problem. They were not fully supporting the new engine setup, causing brake heat-ups and early pads worn outs.
    I tried the cross-linked servo+master cylinder of Cielo, but the end result was not that good....Now I am quite satisfied with the performance with the new servo I think from Nissan.....(Straigth-linked)
    Adnan's
  20. #239
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    @spectra
    i worked on ur idea... the proportioning value could be a problem... coz while braking the rears never lockup... and its usually the fronts locking up very early resulting in a skid and poor braking.... i use a manual ABS procedure to avoid skids
    i am currently reading abt proportioning valve role and its adjustments etc... will update u guys once i come up with something
    @testdriver
    bhai im looking into all possibilities... i liked spectra's idea... will ask u for details InshAllah
  21. #240
    hammed25's Avatar
    Oct 2004
    33
    219
    well i just want to conform one thing is the daewoo brake problem is genuine.... bcoz its like after every 20 days im going to daewoo workshop for the bleading of the breaks and ofcourse i have bought new front disk pad and rear drum pad... and now i stoped driving my car in high speed... i have being sick from the breaks and please suggest what should i do its being a problem bcoz im using this as a family car if its for my personal use then i will just go on with the peoblem... as soon as im using it for my family car so i need suggestions on this....
