Page 178 of 370 FirstFirst ... 78128168176177178179180188228278 ... LastLast
Results 3,541 to 3,560 of 7393
Like Tree425Likes
Thread: Daewoo fan club
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Daewoo Racer/Cielo Fan Club
    Dear All,
    I am an owner of Daewoo Racer since 1995. It has proven to be a very comfortable and economical car throughout this period. It used to give an average of 13Km/L within city and ~15Km/L on long drives. Here are some pictures:
    Daewoo fan club -479355
    Daewoo fan club -479356
    Daewoo fan club -1050638
    Check the links for my rides
    1. Before 2008 (Racer)
    Daewoo Racer
    2. After Jan 2008 (Cielo)
    Daewoo Cielo
    I would recommend buying this car who want a better car at low budgets!
    Any member having used a Daewoo car must share their experience....(y)
    IMPORTANT: SCANNER Facility is Available at Friends Autos, I-9, Islamabad. [Khalid: 0322-5111110, 0321-9562840]
    Quick Links:
    Parts Dealers/workshops link [Page-3 post #:54]:
    Alloy Rim fitment [Page-15 post #:290]:
    The DOHC engine[Page-30 post #:585]:
    Service Manual/Electrical Diagrams link[Page-30 post #:594]:
    Cielo Conversion [Page-57 post #:1130]:
    How to get Black Bumpers [Page-60 post #:1315]:
    Reading ECM Error Codes [Page-191 post #:3804]:
    Air Conditioner maintenance shops [Page-195 post #:3897]:
    High RPM/Stalling Problem on AC, OK Otherwise[Page-203 post #:4048]:
  2. #3541
    sheikh_wah's Avatar
    Nov 2005
    42
    579
    9 Post(s)
    Quote Originally Posted by Shah73 View Post
    On last sunday, i carried out another task of my car to increase its interior elegance i.e. interior roof poshish.
    previous poshish was of carpet which looked very odd. I was lucky enough to find genuine poshish cloth of cars like suzuki baleno. color matched with the daewoo interior. shopkeeper informed that he bought this cloth very first time in tehy market and was not availabnle in the market earlier.
    he demanded RS 1200 and then settled to 800. but interior now looks ............ MashaAllah.
    Good info shah g, will u plz upload the pictures.
  3. #3542
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    Quote Originally Posted by sheikh_wah View Post
    I will post InshaAllah.
  4. #3543
    ace66's Avatar
    Jun 2007
    Rawalpindi
    38
    63
    Default Daewoo Original Side Mirrors
    @All: Are the original Daewoo side mirrors (complete Assembly) available in market (new/old ??) and for how much? I just need the driver side complete with adjusting mechanism etc.
  5. #3544
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by shadowrider View Post
    salam,
    I am Asbar javaid, i am using daewoo racer model 1992 converted to cielo in 2004, the engine is 1.5 DOHC .
    I am having a problem on petrol and the mechanics are unable to spot it,
    the problem is that, when I switch the car to petrol....it starts missing after 1 to 3 minutes rpm goes down and eventually leading to stop the engine, after that I switch off the car then again turn it on and then start again. then again this cycle repeats.
    now, the fuel pump is working, changing it does not work,i have changed the oil filter.
    what can be the problem,
    please help me.....
    1. Did you mechanic check the fuel lines for choking? If not, get them checked first.
    2. Did you mechanic check the fuel return line? There is possibility of malfunctioning return valve too. To resolve the issue, the return valve needs to be replaced.
    3. The problem can also be due to the fuel pump relay, when it heats up, it looses power. To resolve the issue, the fuel pump relay needs replacement.
    4. Did you CNG installer installed a. emulator b. he put a power T in the fuel line c. Direct connection from CNG switch; to control the petrol supply while the engine is run on CNG?
    a. If emulator is installed, get it checked for malfunctions.
    b. If he put a power T, it will exert too much back pressure on the pump causing it to prematurely fail, and is not at all recommended in an EFi engine. The power T might be faulty. Better install an emulator
    c. Ask an electrician to install a relay to control the fuel pump through CNG switch.
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
  6. #3545
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by ace66 View Post
    Please contact any old parts dealers (link mentioned in the main post above) for availability and pricing.
    Adnan's
  7. #3546
    shadowrider's Avatar
    Feb 2009
    26
    71
    Thank you very much for your response sir,
    the mechanic checked the fuel lines and there is no chocking.
    The mechanic didn't check the return line...i'll get it checked.
    The fuel pump is new and working alright, I changed it to see any betterment but nothing happened.
    the CNG mechanic installed a emulator and its working fine, Mechanic checked it.
    the fuel pump is already connected with the CNG switch
  8. #3547
    Feb 2009
    26
    71
  9. #3548
    Feb 2009
    26
    71
    is fuel pump relay something outside the pump????? because i changed the fuel pump but I dont know about the relay......
  10. #3549
    Feb 2009
    26
    71
    i Found the relay.....i Couldnt understand your last point.....direct switch to control the fuel?
  11. #3550
    sheikh_wah's Avatar
    Nov 2005
    42
    579
    9 Post(s)
    AOA everybody, I m looking for some good wheel cups for stock rims of my daewoo Racer, any suggestions/recommendations and where to find it in Rwp/Isb?
  12. #3551
    welcome786's Avatar
    Jan 2008
    39
    377
    5 Post(s)
    @ i want to know that after overhauling, kiya ye lazmi hay ke kuch time tak tapets ko loz chora jata hay, kuch running karne ke bad phir us ko tight kiya jata hay,
    mera mechanic aise hi keh raha hay, aur engine bay se awaz bohat a rahi hay,
    MONEY IS YOURS BUT RESOURCES BELONG TO THE
    SOCIETY
  13. #3552
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    Quote Originally Posted by welcome786 View Post
    I am not aware about its educated rule, but this practice is common in the market for majority of the cars. I came across the same thing as well after engine overhaul.
  14. #3553
    welcome786's Avatar
    Jan 2008
    39
    377
    5 Post(s)
    to kiya apka engine acha perform kar raha hay abhi ke nahin?
    maine to us ko kaha ke tum khud hi is ki running karo jab dobara tapets tight karne ho to mujhe bata dena aur mere samne karna, us ne kaha thek hay,
    aj us ne kaha hay a jao, main check karta hon ke kiya banaya hay mere woo ka engine ka
    SOCIETY
  15. #3554
    asad_scorpio21's Avatar
    Mar 2007
    Rawalpindi
    38
    4,537
    i think there is no need of re-adjustment of Daewoo's tappets , coz its having hydraulic tappet , i got overhauled my engine in july , after that my mechanic never touched again my engine. its running smooth.
  16. #3555
    welcome786's Avatar
    Jan 2008
    39
    377
    5 Post(s)
    What should i do, i have spent a lot of money on it and fear for a dreadfull overhaul again from some one else.
    SOCIETY
  17. #3556
    Mar 2007
    Rawalpindi
    38
    4,537
    do you observe noise from engine? wat type of noise? may be after first oil change (after 1000km) problem got solved. i felt my engine more smooth and silent after first oil change.
  18. #3557
    welcome786's Avatar
    Jan 2008
    39
    377
    5 Post(s)
    Quote Originally Posted by asad_scorpio21 View Post
    yes it sounds too much, i have seen many daewoos running very smooth with no noise at all.
    temperature is also rising above normal, which i have observed in my woo
    SOCIETY
  19. #3558
    Mar 2007
    Rawalpindi
    38
    4,537
    My details for complete engine overhauling r as followsjul-2010)
    Work completed in 3 days.
    Engine Foundation: 550/-
    Silicon: 180/-
    Kerosine oil , cloths, sand paper: Rs.600/-
    Head valve : 900/-
    Piston: 2600/-
    Rings: 1800/-
    Main Bigun: 1250/-
    Jane Kit: 1850/-
    Kharadia work(9 different jobs) : 4750/-
    Labour Mechanic: 3500/-
    Oil /Filter : 1525/-
    Total : 19505/-
    Now drive is very smooth with less engine noise ,
    awesome pick ,great mileage with no heatup issue, no vibration at all. and i am satisfied
    with all work.
    Mian khan is one of the best Daewoo specialist in town.
    i dont know wat kind of your mechanic is?<!-- / message --><!-- sig -->
  20. #3559
    turabbutt524's Avatar
    Feb 2010
    Rawalpindi
    23
    216
    what is the purpose of this switch
    i hav seen this switch in every daewoo
  21. #3560
    welcome786's Avatar
    Jan 2008
    39
    377
    5 Post(s)
    Silicon: 180/-
    Head valve : 900/-
    Piston: 2600/-
    Rings: 1800/-
    Main Bigun: 1250/-
    Jane Kit: 1850/-
    Total : 19505/-
    with all work.
    you are lucky, i have spend 18,000 last time not more than 4 months ago and now also spent 23,000,
    engine is also getting hotter and stops working on first gear and pick is not good, and when ever i lower gear from 4 to 3 or 3 to 2, i heard jerk sound, as we are driving in wrong gear.
    mechanic is unable to tune it on petrol he says that one of the sensor is not working properly and providing more fuel than normal. which sensor is involved here?
    what MAP sensor do?
    SOCIETY
