Page 200 of 370 FirstFirst ... 100150190198199200201202210250300 ... LastLast
Results 3,981 to 4,000 of 7394
Like Tree425Likes
Thread: Daewoo fan club
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Daewoo Racer/Cielo Fan Club
    Dear All,
    I am an owner of Daewoo Racer since 1995. It has proven to be a very comfortable and economical car throughout this period. It used to give an average of 13Km/L within city and ~15Km/L on long drives. Here are some pictures:
    Daewoo fan club -479355
    Daewoo fan club -479356
    Daewoo fan club -1050638
    Check the links for my rides
    1. Before 2008 (Racer)
    Daewoo Racer
    2. After Jan 2008 (Cielo)
    Daewoo Cielo
    I would recommend buying this car who want a better car at low budgets!
    Any member having used a Daewoo car must share their experience....(y)
    IMPORTANT: SCANNER Facility is Available at Friends Autos, I-9, Islamabad. [Khalid: 0322-5111110, 0321-9562840]
    Quick Links:
    Parts Dealers/workshops link [Page-3 post #:54]:
    Alloy Rim fitment [Page-15 post #:290]:
    The DOHC engine[Page-30 post #:585]:
    Service Manual/Electrical Diagrams link[Page-30 post #:594]:
    Cielo Conversion [Page-57 post #:1130]:
    How to get Black Bumpers [Page-60 post #:1315]:
    Reading ECM Error Codes [Page-191 post #:3804]:
    Air Conditioner maintenance shops [Page-195 post #:3897]:
    High RPM/Stalling Problem on AC, OK Otherwise[Page-203 post #:4048]:
  2. #3981
    Surd80's Avatar
    Jan 2011
    36
    32
    Quote Originally Posted by testdriver View Post
    Actually you have to consult a rim repair shop, they have free size aluminum rings. They will bore it according to the requirement and fit into the rim.
    OK thanks. I am soon going to convert my racer into Cielo. I find information provided i this forum very use full . Plus i want to plan everything in advance before i start the actual conversion.
  3. #3982
    mrasifrasool's Avatar
    Jun 2006
    Wah cantt
    40
    192
    Default Congratulation for double century of our forum
    Daewoo fan club -242099
  4. #3983
    kamranzafar.ch's Avatar
    Mar 2010
    Rawalpindi
    19
    I asked the questions because usually when a different compressor is installed, there is no switch in it to tell the ECM that the AC compressor is ON, and the radiator fan starts only when the engine get hot. If the compressor is genuine, then you just have to check the cooling system of the engine. Usually when the AC is switched ON, it is quite normal that the engine temperature rises, still if you feel overheating, then radiator seems to have some problem probably some tubes are blocked within it.
    @zeeshan213
    Hope you got your answer.
    Someone also advised me to flush out the whole AC unit and condenser as AC compressor leakage might cause the AC condenser not to work properly.
    I also congratulate you on the double century of this forum. It is indeed a great source of info for any Daewoo lover
  5. #3984
    Mar 2010
    Rawalpindi
    19
    Quote Originally Posted by asad_scorpio21 View Post
    r u sure whether your AC's compressor is periodically getting tripped or constantly running??
    My engine temperature is remain almost same (at white area) with or without AC ,
    REASON:
    1-when i run my car without AC , there is no additional load on engine , so Radiator fan keeps engine temperature as low.
    2-when i switch on AC , there is additional load on engine so technically it should heatup, so AC condenser fan also starts with AC (2 Fan running at the same time , Radiator and condenser fan) but still engine temperature should rise as compare to AC off. but i got installed another additional fan with AC condenser , so at the same time three fans run which keep the engine temperature at white level. so there is no Radiator water reduction issue.
    3-So additional fan is also capable for excellent AC's cooling , although traffic jamming under direct sun in rwp disturbs the AC's cooling (coz car RPM remains at 700 rpm in idling) but engine temperature remains almost low.
    I'm sure my AC compressor is constantly running
    I also congratulate you on the 2nd century of this forum. Indeed you are a very Worthy contributor on this forum.
    How is Asjad Bukhari. Now a days I hardly get any update from him Pay my regards to him and thank you for your interest in this issue
    Regards
    Kamran
  6. #3985
    asad_scorpio21's Avatar
    Mar 2007
    Rawalpindi
    38
    4,537
    Quote Originally Posted by kamranzafar.ch View Post
    Regards
    Kamran
    thanks for ur wishes ,
    Asjad is fine , by the way how do u know him???
  7. #3986
    saadshaukat's Avatar
    Apr 2006
    Taxila
    33
    72
    Unhappy Brakes balance issue
    Assalam o alykum!!
    Mashallah the DFC is evergreen
    @testdriver
    I am having persistant Brakes issue, I get them adjusted and balanced, but after sometime(2mnths) the rear drums mess up again...i even met an accident, thanks to rear brakes not working properly...
    Costing me new bonnet and 15k in total...I swapped the servo back in 2006 to some kabli...any advice??
    Jaza kallah
  8. #3987
    Apr 2006
    Taxila
    33
    72
    Default Get ur daewoo safety inspected!
    Please drive ur daewoos safely...this what happened to mine in March[IMG]www.pakwheels.com/forums/attachment.php?attachmentid=242585&stc=1&d=1305917 849[/IMG]
  9. #3988
    Apr 2006
    Taxila
    33
    72
    Default Should I go for manifold, injector rail and box air filter...
    Should I go for manifold, injector rail and box air filter and ECM for GTi... is it worth anything? This for the 1.5 block ...plz give ur feedback?
  10. #3989
    Mar 2010
    Rawalpindi
    19
    Sorry Bro for the delayed reply. I was excessively busy in office work. I work in Legendware as during last job Asjad was with me
    Kamran
  11. #3990
    Mar 2007
    Rawalpindi
    38
    4,537
    Kamran
    Oh IC , he is now in Al Jazeera TV ,Doha Qatar .
    wat about ur engine heatup issue with AC ,
    i was facing the same problem than got cleaned and washed Radiator and AC Condensor under supervision of Mian Khan , so problem was solved.
  12. #3991
    SalarsCar's Avatar
    Apr 2011
    23
    Thumbs up Found a real Loshey Programm for PC Based Scanner
    Aslamualaikum to all Brothers
    Our PC based scanning tool is ready! Have a look at the snapshots
    Daewoo fan club -243280
    Dashboard View of the Scan tool while the vehicle is running at 33 mph
    Daewoo fan club -243283
    Engine values under idle conditions with AC 'off'
    Daewoo fan club -243284
    Engine values with AC 'on' , note the difference in IAC values
    Daewoo fan club -243285
    Voltage levels of sensors during idle running
    If any body is interested, I would like to post further details as well. Anyways our "Project # 1" is at final stages. Last few milestones left are:-
    a) Active involvement with Daewoo Racers ECM by changing its parameters while the engine is running to test its actuators.
    b) To dump the ECMs memory on PC.
    c) To permanently change the engine performance parameters (trickiest job)
    Plz help me all in doing so. Enjoy this gift for the 200th page.
    Khuda e Paman
    DIFFERENTIATE BETWEEN INFORMATION & KNOWLEDGE, YOU WILL FIND THE DIFFERENCE IN YOUR LIFE
  13. #3992
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by saadshaukat View Post
    Assalam o alykum!!
    @testdriver
    Jaza kallah
    Sorry for the late reply.
    Please elaborate "not working properly". Do they 'jam' or 'frees up'? Which servo you have installed? Did the mechanic changed the brake geometry (Diagonal to Straight)?
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
  14. #3993
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    If your TBI is working perfectly, don't go for the 4 injector (MPFI) manifold. You have to replace the ECM along with routing three more wires for Oxygen sensor and IAT from your existing wiring. Then you have to source Oxygen sensor to get perfect tune. In return you will get lower engine noise by 10% thanks to the resonator.
    Adnan's
  15. #3994
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    @SalarsCar
    Well done bro!
    It was nice meeting you...
    Adnan's
  16. #3995
    Apr 2006
    Taxila
    33
    72
    They neither jam nor free up, the car is moves diagonally when brakes are applied, the Corolla servo is being used perhaps...
  17. #3996
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    By design the Daewoo Racer brake geometry is diagonal. The front right wheel and the rear left wheel are engaged first and then the front left and rear right wheel, thanks to the brake proportionate valve designed to work seamlessly according to the brake geometry. When the master cylinder is changed (off some other make car), the geometry also needs to be changed (since the other master cylinder is designed for straight brake geometry) otherwise the car will tend to move towards right/left during braking.
    Adnan's
  18. #3997
    yousafhussain's Avatar
    Dec 2010
    50
    Dear test driver,
    Assalm-o-alikum i have purchased a woo in a very low budget the machanic first checked the car its engine is in good condition but it needs some work round about 20k in which i have to do the wiring of ECM because the carborator installed in this car is nissan the engine is daewoo 1600cc and five forward gears now my car is on work shop for some starring work and wiring and also the other accessories like the carborator and its sensors and wiring now what you suggest the nissan carborator is working fine but the engine makes some little heavy sound and petrol consumption is to much and on gas its to good approx 220 km in one cylinder in local the mechanic suggests me that i should for its own carborator he has checked all the lines the connections are there for petrol the only thing he has to do is to fix the carborator and its air cleaner and the sensors it will cost round about 6k and you know its a one time cost.
  19. #3998
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by yousafhussain View Post
    Dear test driver,
    Congrats for the purchase! Daewoo engine is 1500cc btw
    If someone has installed a carburetor, he must have altered the intake manifold. If that's the case, just buy a complete kabli intake manifold with sensors. Is the ECM also removed? If yes, buy ECM with engine wiring.
    Adnan's
  20. #3999
    thanda's Avatar
    Dec 2005
    31
    417
    2 Post(s)
    @SALARSCAR
    awsum work bro
    A "cool dude" who says civic is the best car in the universe actually owns a CD 70!
  21. #4000
    Dec 2010
    50
    thanks ECM is there but i think its not working right now because the carborator is changed so waqar has checked the wiring he says that it is repairable he will do it let him fix all the issue then i will acknowledge and i will also upload the snaps of my car.only i have to purchase is the carborator and air cleaner assembly.
