Page 209 of 370 FirstFirst ... 109159199207208209210211219259309 ... LastLast
Results 4,161 to 4,180 of 7393
Like Tree425Likes
Thread: Daewoo fan club
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Daewoo Racer/Cielo Fan Club
    Dear All,
    I am an owner of Daewoo Racer since 1995. It has proven to be a very comfortable and economical car throughout this period. It used to give an average of 13Km/L within city and ~15Km/L on long drives. Here are some pictures:
    Daewoo fan club -479355
    Daewoo fan club -479356
    Daewoo fan club -1050638
    Check the links for my rides
    1. Before 2008 (Racer)
    Daewoo Racer
    2. After Jan 2008 (Cielo)
    Daewoo Cielo
    I would recommend buying this car who want a better car at low budgets!
    Any member having used a Daewoo car must share their experience....(y)
    IMPORTANT: SCANNER Facility is Available at Friends Autos, I-9, Islamabad. [Khalid: 0322-5111110, 0321-9562840]
    Quick Links:
    Parts Dealers/workshops link [Page-3 post #:54]:
    Alloy Rim fitment [Page-15 post #:290]:
    The DOHC engine[Page-30 post #:585]:
    Service Manual/Electrical Diagrams link[Page-30 post #:594]:
    Cielo Conversion [Page-57 post #:1130]:
    How to get Black Bumpers [Page-60 post #:1315]:
    Reading ECM Error Codes [Page-191 post #:3804]:
    Air Conditioner maintenance shops [Page-195 post #:3897]:
    High RPM/Stalling Problem on AC, OK Otherwise[Page-203 post #:4048]:
  2. #4161
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by drahmed111 View Post
    howz da ac of daewoo??
    AC is good! The compressor however creates problem when get older, being a rotary type, majority of mechanics could not service them correctly resulting in poor performance/breakdowns. You can install sanden compressor unit, the result is also very nice, the condenser being big and efficient.
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
  3. #4162
    umerpk's Avatar
    Jun 2011
    8
    Salam all... i have 2 questions
    what is the normal Ac compressor cutout timing? i feel compressor tripping off when i press full accelerator with very low wheel speed ( i think less then 10 kph)... if speed is more or accelerator is not fully pressed the compressor doesnt trip... is it normal??
    secondly, after a recent engine overhaul mechanic has put in 20w50 oil in engine.. i have changed the oil twice after that and he puts in the same oil... what i have read from some previous post is that 10w40 is the recomended oil... i want to know that what is the difference and how will it effect me? can i change the oil from next due date to 10w40 or should i continue with it now...??
  4. #4163
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by umerpk View Post
    There is no such thing as AC compressor cutout timing in Daewoo. The compressor by design decrease the compression upon reaching certain pressure level, so the compressor main shaft still running, it no more compress the refrigerant. There is an additional cut-off feature which activates when the engine is under stress which basically disengage the electric clutch of compressor when the engine requires more power. So the behavior of AC tripping is normal in such conditions.
    Regarding the oil, like other manufacturers, Daewoo was also launched in extreme cold regions to extreme hot ones. The selection of oil basically depends upon the temperature range on certain region. In Pakistan, where the temperature usually does not fall too far below freezing level in majority of the areas except a few, so 20W50 is just the ideal oil selection. See the attached guide from the user manual regarding oil recommendations:
    Daewoo fan club -261421
    Adnan's
  5. #4164
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    Quote Originally Posted by testdriver View Post
    This is not the AC Signal switch, but the low pressure switch. It does not allow the compressor to operate when the gas pressure is low in the lines. The other wire you have witnessed is basically a jump wire to operate the relay for the condenser fan. The AC signal switch is located behind the compressor.
    In my case, these is sanden compressor instead of jenuine one.
    Would it be behind the compresor in case of sanden also??
  6. #4165
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by Shah73 View Post
    Regardless of compressor, the wiring harness (what we call grip) should be there hanging freely since switches are not there in yours case!
    Adnan's
  7. #4166
    nauman's Avatar
    Feb 2004
    35
    811
    14 Post(s)
    Daewoo fan club -261550 Daewoo fan club -261551 Daewoo fan club -261552 Daewoo fan club -261553 Daewoo fan club -261554
  8. #4167
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    @nauman
    Looking nice!
    Adnan's
  9. #4168
    yousafhussain's Avatar
    Dec 2010
    50
    Dear test driver,
    thanks for such a use full information but i cann't understand this chart just tell me one thing in this weather where the temperature is too hot which engine oil is the best for this atmosphere where you have to travel long distances on your daewoo and which engine oil best suits the engine of daewoo please tell me with brand name recently i am using ZIC in yellow....
  10. #4169
    Dec 2010
    50
    @nauman
    yes its really nice....
  11. #4170
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by yousafhussain View Post
    Dear test driver,
    20W50 best suits our temperature range. I have had good experience with Pertomin Ultra7, just go for it.
    Adnan's
  12. #4171
    nauman's Avatar
    Feb 2004
    35
    811
    14 Post(s)
    @thanks adnan bhai
  13. #4172
    Uashah007's Avatar
    Mar 2011
    Peshawar
    309
    8 Post(s)
    Default Test Driver
    Test Driver need your help
    My Woo Is doing Missing from past two Days, Slightly missin when accelerator is pushed, i checked plug wires, rotar and changed distributor cab, but still problem is there
    Let Me tell you bro that their is no cng kit in my car, i am using car on petrol.
    And feel black smoke( Un Burned Fuel)
    Kindly Help Me out Bro, Any One Else is Also Welcome
  14. #4173
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by Uashah007 View Post
    Does the 'Check Engine Light' appear? Any recent work done to your car? What are the CO voltage?
    The problem could be just a vacuum leak...
    Adnan's
  15. #4174
    umerpk's Avatar
    Jun 2011
    8
    @testdriver thnx brother for the detailed reply...
    one thing more.. is there any other safety for engine overheat situation other then temp guage? like missing, engine shutdown, heat inside the car? when driving at high speed with constant RPM...
  16. #4175
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Unfortunately there are least visible signs telling you accurately about heatup except the gauge. Yes one can take precautionary measures to avoid heatup and for that one should have a regular check on the coolant condition & level, radiator fan operation, leaks and worn hoses in the cooling system and proper functioning of the thermostat valve and water pump.
    Adnan's
  17. #4176
    Uashah007's Avatar
    Mar 2011
    Peshawar
    309
    8 Post(s)
    Yes that yellow engine light appers some time.
    Bro recently changed the distributor cup, because mechnic was asking to changed it. and before that i changed the Carborator because previous one was alter for Cng, and AcSwitch was Faulty to, So i bought Kabli One, and installed it.
    Car pick up is good, engine sound is great, and Ac switch is also working in excellent now, but having these problem now.
  18. #4177
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    very nice suggestion indeed, i am also using the same from 4-5 months and results are great as compare to Shell/caltex/PSO etc.
  19. #4178
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    I recommend that you read the error code and reply here. The code reading technique link has been appended to the main post above.
    Adnan's
  20. #4179
    ScOrPeO's Avatar
    May 2008
    Rawalpindi
    38
    38
    Daewoo fan club -262870 Daewoo fan club -262871 Daewoo fan club -262872 Daewoo fan club -262873 Daewoo fan club -262874 Daewoo fan club -262877 Daewoo fan club -262878 Daewoo fan club -262879
    Daewoo RACER 1.5i OHC
  21. #4180
    bilal_masood91's Avatar
    Sep 2010
    Beijing
    937
    4 Post(s)
    Waoow one clean Daewoo RACER!!!!!
    Allah bachaee Har Nazaar Behaya hai!!!!!!!
