@testdriver:
VSS of my car is broken. new and kabli, both are avilable in the market. which one shold be opted for good performance? I have learnt that signal codes of new VSS are more compatible with the new daewoo computers/ecm and some times it mismatch with the daewoo racer computer? is it the case? pl guide.
Dear sir,I am seriously thinking to install STAP 56 as advised.The above details if translated in lay man's language describe that STAP 56 is a device which can store timings for CNG and pet and can provide ideal timings for bi fuel vehs(may be).
I had gone to best CNG mech aval in HYD yesterday.He again started the old logics and tried to convince that a relay with both ECM and CNG kit will manage the affair.
I am planning to go to KCI on coming FRI for this job.Actually in my pers opinion this aspect has attained a very imp status owing to CNG fuel shortage problem.
Sir, if you kindly give ur expert instructions with regards to connections,this will be a great help to people with less knowledge and residents of non Daewoo cities.Illustration or diagrams will be of great help.
Testdvr sir I also request to deal the issue in ur flawless and peculiar style taking lead from my problem.Thx
Sir yesterday I changed gear oil ZIC(430 Rs/lit),2lits.The problem has been solved thx alot.
Didn't get kindly check.fslrao@yahoo.co.uk THX
Testdvr to initiate the discussion pls
I haven't heard of any mismatch, though the VSS came in automatic transmission is different. The VSS should work well if the product code matches with the original one.
2.The relay mentioned by your mechanic will be a replacement of emulator, though the switching between the fuels will be quite noticeable.
Please proceed with the installation if you are using your car regularly on both fuels.
You can download directly from the link mentioned in the main post on the top.
I am really sorry, it will be a very hectic and time consuming job. One thing I can do is to mention some important problems in the main post above, and even I already have mentioned few links.
I have thrown away the old vss, can u pl tell me its product code.
The code of VSS is 96190708
Sharing a useful information regarding the engine compression test.
Thx a lot sir I am amply clear and confident to install STAP 56,I seriously hope CNG mech understand the diagram.Any how I am obliged will keep u abreast with the progress.
If u allow me I may under take the editing and put up draft for ur approval.
One thing u may do is to guide me with regards to format.
I think we must give it a try at least.Thx
What is the use of the code?
I've seen woos with out VSS and no CEL displayed.
Thx a lot for sharing such a useful info.Can an ordinary mech perform this procedure?
Can u please explain further the connections of purple wire to be connected to Distributor i-e which wire of Distributor is to be connected with purple wire of STAP 56.Similarly the connection of purple wire to be connected to ECM.Ihope u do not mind my low assimilation of ur simple instrs.
A few days back I noticed spots with rust beneath my car.I washed the car thoroughly with a brush taking care of the black protective coating.
Then I applied the rusted pieces with ordinary spray paint.Have I done right to protect my vehicle or some thing else is suggested.
Please go ahead with editing
It is the product code unique for each part in a equipment and is useful for getting matching replacement part.
Interestingly usually electrician connect the CEL lamp with either Oil indication lamp or the battery indication light, since these two also show up during ignition 'ON' and goes off when the ignition is 'OFF' or engine is 'Started' :). If VSS is not present, a vehicle will exhibit the problem of high idling rpm after every throttle press during motion and engine shutting down at braking.
Please refer to the picture below.
Use Autoshield on the rusted areas on the under cage, while for other areas you can use red oxide as the base and then apply paint.
