Page 242 of 370 FirstFirst ... 142192232240241242243244252292342 ... LastLast
Results 4,821 to 4,840 of 7394
Like Tree425Likes
Thread: Daewoo fan club
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Daewoo Racer/Cielo Fan Club
    Dear All,
    I am an owner of Daewoo Racer since 1995. It has proven to be a very comfortable and economical car throughout this period. It used to give an average of 13Km/L within city and ~15Km/L on long drives. Here are some pictures:
    Daewoo fan club -479355
    Daewoo fan club -479356
    Daewoo fan club -1050638
    Check the links for my rides
    1. Before 2008 (Racer)
    Daewoo Racer
    2. After Jan 2008 (Cielo)
    Daewoo Cielo
    I would recommend buying this car who want a better car at low budgets!
    Any member having used a Daewoo car must share their experience....(y)
    IMPORTANT: SCANNER Facility is Available at Friends Autos, I-9, Islamabad. [Khalid: 0322-5111110, 0321-9562840]
    Quick Links:
    Parts Dealers/workshops link [Page-3 post #:54]:
    Alloy Rim fitment [Page-15 post #:290]:
    The DOHC engine[Page-30 post #:585]:
    Service Manual/Electrical Diagrams link[Page-30 post #:594]:
    Cielo Conversion [Page-57 post #:1130]:
    How to get Black Bumpers [Page-60 post #:1315]:
    Reading ECM Error Codes [Page-191 post #:3804]:
    Air Conditioner maintenance shops [Page-195 post #:3897]:
    High RPM/Stalling Problem on AC, OK Otherwise[Page-203 post #:4048]:
  2. #4821
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by bilalsarwar View Post
    Dear
    i have purchased a daewoo n have some issues with stearing wheel but it is stuked can u please guide me how to remove the stearing wheel
    There are two techniques for extracting steering wheel from the column:
    1. (The Desi Technique) Loose the center nut of steering wheels located beneath the horn pad. The horn pad can be removed by pushing it out by leverage of a screw driver. The nut should be loosened to an extent that it just surfaces the steering shaft screw. Now using your legs as support beneath the steering wheel, apply leg pressure towards yourself just like you are trying to pull it towards chest. Keep it stretched, get a big hammer and strike it on the center of steering nut. After few successive tries, while the legs are still applying pressure on the steering wheel, the steering wheel will be loosened. Once done, remove the center nut completely and then pull out the steering wheel.
    OR
    2. (As per Service Manual) Get a steering wheel puller fabricated/purchased with the following specifications and follow the instructions to remove the steering wheel.
    Daewoo fan club -356980
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
  3. #4822
    asad_scorpio21's Avatar
    Mar 2007
    Rawalpindi
    38
    4,537
    Quote Originally Posted by testdriver View Post
    Welcome back!
    The main difference between option 2 and option 3 is that in case of option 2, only the cabin air is recirculated over the evaporator causing the temperature of too cold since same air is being recirculated while in option 3, the air of cabin is mixed with fresh air from outside, causing the cabin temperature a little better, not too cold.
    thanks for detailed reply
  4. #4823
    asifnadeem1975's Avatar
    Jun 2011
    110
    1. This sound usually comes from relays. Take your car to electrician to diagnose the problem.
    2. No, you don't need to service the A/C for getting warm air, instead you need to:
    a. install the thermostat valve (if removed)
    b. set the radiator fan to automatic (if not already)
    c. remove any bypass from the heater core piping, in case it is bypassed by mechanic during summer for better performance of A/C.
    Thanks a lot Bhai. i will respond you after get rectifications shortly.
  5. #4824
    zawalayat's Avatar
    May 2008
    44
    128
    Default Installation of Advnce to Daewoo Racer Original Engine
    Dear Test driver and other experienced owners/friends,
    Although number of user have already raised this question for installation of advancer (STAP 56 or better option) to get optimum output at petrol as well as on CNG, but I could not get clear answer: My daewoo gives knocking sound while runs on petrol and its performance on petrol is poor than on CNG.
    Could you please advise me on following:
    1. Is it practical to install advancer to get ideal pic on petrol and cng on the same adjustments.
    2. from where i can get it and cost if some knows.
    3. The authentic workshop or professional mechanic, from where i can get it installed.
    4. I hope it will not creat any problem/ of disturb engine wiring /electric system. any precautions for do and donts..
    5. Lastly, should i go for bosh 4 tip plugs for performance and better mileage or any other better option.
    The last thing i am worried about that DFC forum came to number three from number One, in terms of views and replies. I think the members are either busy or not providing their valuable inputs.
    Regards and thanks in advance.
  6. #4825
    bilalsarwar's Avatar
    Nov 2008
    39
    9
    thanks alot dear i wud like to ask more questtions if the problem arises coz its my first experience to have daewoo
  7. #4826
    nomi700's Avatar
    Feb 2006
    39
    14,184
    168 Post(s)
    54 Thread(s)
    wow. Bilal bhai. 1165 days old on pakwheels and just 2 posts. nice
    Please take care of your near and dear ones. Drive safely.
    https://www.facebook.com/naumansheikhpictography
  8. #4827
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by zawalayat View Post
    First of all we are not here to compete other forums, but to discuss and troubleshoot real time issues. Hope you won't mind.
    Regarding your query, here is the summary:
    1. Yes
    2. Ask Pakistan CNG in I-9 (Haroon Zia @03348743643) as he has assured me to arrange and install the same on request.
    3. As above
    4. Any professional CNG installer can do a clean hassle-free install.
    5. There is no harm in putting 4 tips plug, though I am using the OEM recommended single tip plugs of NGK.
    Adnan's
  9. #4828
    zawalayat's Avatar
    May 2008
    44
    128
    Many thanks for reply. Just talked with Haroon Sb. and he said that advancer can be arranged within one week for around Rs. 7500/- which seems on higher side. Whats your opinion on price.
    <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com<img src=" /><o:p></o:p>
    Secondly obviously DFC is not competing with anyone, but there is little decreased involvement of the users in these days.
  10. #4829
    Mar 2007
    Rawalpindi
    38
    4,537
    Default My woo in Murree
    Daewoo fan club -357762
  11. #4830
    Mar 2007
    Rawalpindi
    38
    4,537
    Default My Ride enjoying in murre
    Daewoo fan club -357763
    Daewoo fan club -357764
  12. #4831
    Hamza24's Avatar
    Dec 2010
    68
    Quote Originally Posted by asad_scorpio21 View Post
    wat about ur cylinder capacity , 8 kg or 10 kg ???
    its 8 kg
  13. #4832
    zawalayat's Avatar
    May 2008
    44
    128
    tried to upload pics but not successful
  14. #4833
    Nov 2008
    39
    9
    Dear test driver
    my daewoo is on paint job and i want matching bumpers but painter is not willing to paint them as matching coz as per him the daewoo bumpers cannot b painted but he is willing to make them mate finish paint u r requested to please guide me how can i convince him n what material shuld be used for matching paint
  15. #4834
    Mar 2007
    Rawalpindi
    38
    4,537
    Dear test driver
    Metallic Matching bumper is recommended only for Cielo's bumper. Racer's bumpers having Waxy material which is not suitable for Metallic paint job. Although many racers having matching bumpers but in ruined condition , If you are really interested to have matching bumpers than you have care alot and avoid to hit bumpers any where.
    Better painting method is that first Painter has to apply Plastic Permier and than start Paint Job. Although Metallic bumpers looks far better than Mate Finish , but you have to do special care .
  16. #4835
    Mar 2007
    Rawalpindi
    38
    4,537
    may be ur pic size is bigger than max recommended pic size
  17. #4836
    crystal11's Avatar
    Aug 2010
    158
    2 Post(s)
    dear daewoo owners can we install power windows and power steering in daewoo and who is better installer in this case in rawalpindi thx
  18. #4837
    Nov 2008
    39
    9
    thanks asad actually he told me same as u said but u know in pakistan specially in lahore bumper care is so difficult i think i shuld go for mate finish thanks for ur support God bless u
  19. #4838
    nomi700's Avatar
    Feb 2006
    39
    14,184
    168 Post(s)
    54 Thread(s)
    Bilal bhai rang barangay karwa lay. I mean mixture of colour and Matt. Dual tone. Will look great.
    Sent through Tapatalk
  20. #4839
    Mar 2007
    Rawalpindi
    38
    4,537
    ya mate finish is better , get sprayed first time by professional Painter , with the passage of time , in case of getting fade u can re-spray by your self costing just Rs.150/-
  21. #4840
    Mar 2007
    Rawalpindi
    38
    4,537
    Quote Originally Posted by crystal11 View Post
    Best option to have power windows, is to install complete Door Panals with Motors of Cielo . but it will cost you between 20 to 30 k.Another option is to install Toyota Surf Windows Control Panals with Daewoo Racer/cielo's Motors or some other Car's Motors(with some Alteration ) It will cost u almost 10k to 12K. in this case Electrician must be Expert.
    You can also get installed Cielo Power Steering system in your Racer , I think costing around 10 K but this job needs high skilled Mechanic (Any Daewoo Specialist) coz there is lot of Power Steering Failure Cases happend in Racers.
