Page 245 of 370 FirstFirst ... 145195235243244245246247255295345 ... LastLast
Results 4,881 to 4,900 of 7393
Like Tree425Likes
Thread: Daewoo fan club
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Daewoo Racer/Cielo Fan Club
    Dear All,
    I am an owner of Daewoo Racer since 1995. It has proven to be a very comfortable and economical car throughout this period. It used to give an average of 13Km/L within city and ~15Km/L on long drives. Here are some pictures:
    Daewoo fan club -479355
    Daewoo fan club -479356
    Daewoo fan club -1050638
    Check the links for my rides
    1. Before 2008 (Racer)
    Daewoo Racer
    2. After Jan 2008 (Cielo)
    Daewoo Cielo
    I would recommend buying this car who want a better car at low budgets!
    Any member having used a Daewoo car must share their experience....(y)
    IMPORTANT: SCANNER Facility is Available at Friends Autos, I-9, Islamabad. [Khalid: 0322-5111110, 0321-9562840]
    Quick Links:
    Parts Dealers/workshops link [Page-3 post #:54]:
    Alloy Rim fitment [Page-15 post #:290]:
    The DOHC engine[Page-30 post #:585]:
    Service Manual/Electrical Diagrams link[Page-30 post #:594]:
    Cielo Conversion [Page-57 post #:1130]:
    How to get Black Bumpers [Page-60 post #:1315]:
    Reading ECM Error Codes [Page-191 post #:3804]:
    Air Conditioner maintenance shops [Page-195 post #:3897]:
    High RPM/Stalling Problem on AC, OK Otherwise[Page-203 post #:4048]:
  2. #4881
    sidss's Avatar
    Jan 2012
    Rawalpindi
    5
    Default CARES for Weak Engine
    Quote Originally Posted by testdriver View Post
    It depends on the current status of engine. If just crank has play, then you will need to rebuild the block. It will cost around 20K. For a complete overhaul, @sahhil has given you an estimated cost. Better take your car to mechanic for better opinion.
    My Engine is weak
    How Can I manage 2 make it running for a long time. Give the tips and precautions to drive a car with Weak engine
    the most imp thing!!!!!!!! sumbdy told me to use thick mobil oil like one that is used for diesel engine named Rimula. If i use that thick oil then wat do u think. Will it work or may have sum negative effects
  3. #4882
    asifnadeem1975's Avatar
    Jun 2011
    110
    Total quartz is also a good brand provided you get the original one. I generally recommend any oil in transparent/light yellow color. (as told by an expert, at-least it ensures that the oil is not a recycled one).
    (a) I found Zic A (not A+) in 10w40 and Petromin ultra7 in 20w50 to be better.
    (b) The exact quantity is 3.78 litre with genuine filter and genuine single chamber packing. If using non genuine filter with double chamber packing, the amount may vary. The best practice is to pour 3.5 litre in one go and then check with dip stick unless you get the max mark reached.
    (c) You should change the filter with each oil change.
    Thanx for timely response
  4. #4883
    Jun 2011
    110
    Quote Originally Posted by sahhil_22 View Post
    (a) if its satisfactory for you, its good, else use caltex havoulline
    (b) wha do you mean?
    (c) with every oil change, i change mine after 3K
  5. #4884
    aliusman420's Avatar
    Nov 2006
    6,935
    97 Post(s)
    2 Thread(s)
    Yes you can find one. If you are interested in purchasing one, get in contact with the workshop people (contacts at page 3) first.
    okay. being neutral, how is daewoo as a daily driver car? achi hai?
    8th Gen Mitsubishi Lancer 1.3 GLX 2006; 3rd Gen Toyota Prius 1.8 S-Touring 2010; 11th Gen Toyota Corolla 1.3 GLi AT 2014.
  6. #4885
    hafizsarwar's Avatar
    Dec 2011
    25
    Quote Originally Posted by aliusman420 View Post
    No doubt daewoo is excellant if it is maintained properly. I have a daewoo 2003 Islamabad Registered Officer Scheme, silver metalic with RMP meter. I have recently completed all mechanical work alongwith complete engine overhaul. No mechanical work required at all. You can confirm its mechanical condition from G-8 Markaz Tahir Sb(Daewoo Mechanic) for your satisfaction. I want to sale out and my demand is Rs. 3,45,000/-. For further queries please contact 0344-5155288.
  7. #4886
    asad_scorpio21's Avatar
    Mar 2007
    Rawalpindi
    38
    4,537
    My Daewoo is daily runner since last 4 years , its a trouble free, reliable and comfortable car.
  8. #4887
    thanda's Avatar
    Dec 2005
    31
    417
    2 Post(s)
    Default engine overhaul finally done
    AOA friends
    Last week i finally overhauled my car's engine details are mentioned below for your reference, work is done by Moon (New auto complex) lathe work is done by a baba jee located in I-09 near eye hospital, parts have been purchased from Rajpuut autos gawalmandi. I have lost the receipt of Rajpuut so could'nt give you the detail account, but the total bill of spares was about 10k that included, rings piston, chamber Jain, gaskets, main bigen, valves etc
    Work was done in 5 days approx, twist in the tale came when kharadia told me that head is in a very bad shape and its quite a hassle to fix it and its good if i can arrange a qabli head, I rang ahata mithu khan, talked to khair mohammad and he said that a good head will cost me around 15k, which was way to high than my expectations, through Moon i contacted a scrap dealor of lahore named nadeem and after bargaining made a deal for 8k, transferred the money through easy paisa (used it for the very first tym and found it very useful), nadeem got the money instantly and booked the head with a rivate courier company, head arrived the next morning for Rs 200(a2z couriers) after that work went smoothly and got the car after 5 days here is the expenditure details
    Parts: 10k
    lathe work: 3500
    mechanical labour: 5k
    electrical wiring: 2k
    carpet/engine bay/dashboard cleaning:3k
    petrol used for cleaning of head :1500
    Changed brake servo with corolla: 3k
    around 6k petrol is used during running!!
    After running went again for CNG tuning spark plugs were having some carbon on them so Moon took the qabli head out (it was fixed as it was received, and no work was done) some lathe work was done which took a whole day
    so got the car yesterday and so far car is running good and engine is roaring like a new one, butttt its been a tough month
    I hope this post will be helpful for you guys, though a bit lengthy :p
    A "cool dude" who says civic is the best car in the universe actually owns a CD 70!
  9. #4888
    Nov 2006
    6,935
    97 Post(s)
    2 Thread(s)
    Quote Originally Posted by hafizsarwar View Post
    can you please share some pictures?
  10. #4889
    Jun 2011
    110
    Quote Originally Posted by thanda View Post
    AOA friends
    Parts: 10k
    lathe work: 3500
    Thanx a lot for sharing such valuable information
  11. #4890
    Jun 2011
    110
    Salam to All
    Anyone knows about the difference in the documents of "Taxi Scheme" and "Officer Scheme" Daewoos?
  12. #4891
    sidss's Avatar
    Jan 2012
    Rawalpindi
    5
    Quote Originally Posted by asifnadeem1975 View Post
    Salam to All
    in taxi scheme in the copy "TAXI CAR" will be written and also its reg no will be like, RPT=rwp pblic trnsprt, IDT= isb trnsprt ,LPT=lahore public trnsprt ,LHP ,PH , PT
    for officer scheme "MOTOR CAR" will be written in the copy against car type
  13. #4892
    ammadusmani1's Avatar
    Jan 2012
    Wah cantt
    35
    Default Battery Advised needed please
    Dear Testdriver and All respected members,
    I am very much confused regarding battery installation in Daewoo. If I insert AGS battery in daewoo, than you know that its terminals touches the bonnet because of its size and same for the other batteries like Exide, Phonex etc. Volta company make DIN size batteries which I think suit for Daewoo due to its small size in hight. But my cousin is working there and he told me to avoid Volta in any manner because of its bad quality. Another option is of Hankook Imported battery available in Islamabad battery, Melody BUT I don't know about its quality. Please help me in this regard I am very much obliged.
  14. #4893
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by sidss View Post
    My Engine is weak
    Weak up to which extent? How much oil it consumes? Any sound from the crank or cam?
    You can use any oil in 20w50, try Petromin Ultra7(20W50) or Liquimoly MoS-2 (20W50)[only available at LM franchise]. Also try to avoid revving engine too much (above 2.5K RPMs), if you do not have RPM installed, try changing the gear at every 20Km/H range, like 1st gear up-to 20Km/H, 2nd gear up-to 40Km/H, 3rd gear up-to 60Km/H, 4th up-to 80Km/H(and 5th up-to 100Km/H if you have 5 speed transmission). Keep regular check on the oil level.
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
  15. #4894
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by ammadusmani1 View Post
    You are right, you will need a DIN size battery for you Daewoo as long as you keep everything stock. The battery fitment problem becomes worse for a Cielo. I am currently using Volta DIN55 battery and it is working fine. The good thing is that it is covered by a 6 month replacement warranty. So in case of any problem you can claim another unit from company. The Hankook battery you are referring to, is an imported unit so I think you won't get any warranty unless provided by the shopkeeper on his own.
    If you are willing to do a little modification to the battery tray, you can consult any expert denter. It just needs few hammer hits and a space upto 2 cm can easily be made. I have witnessed a Cielo undergone the same treatment and a regular battery was perfectly in place without any problem.
    Adnan's
  16. #4895
    Jan 2012
    Wah cantt
    35
    Thank you very much for your nice advice
  17. #4896
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    Quote Originally Posted by asad_scorpio21 View Post
    i will not discuss for city drive , i will just talk about long routes (Motorway/G.T road , No Traffic jamming, No signals)
    I got 215 km mileage in 10 Kg cylinder on G.T road , Although my car having 4 Speed transmission , 5 speed Transmission gives better mileage with low engine noise. Mileage is depend upon cng setting and Driving habits. Drive with soft foot (Low RPMs)will definitely gives better mileage.
    Around three weeks back i travelled to pindi; and from LHR to RWP one cylinder gave 180Km mileage, while travelling back to LHR it gave 240 Km mileage. Alhamdolillah.
  18. #4897
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    Nice come back, asadscorpio and sahil. wellcome.
  19. #4898
    Mar 2007
    Rawalpindi
    38
    4,537
    Quote Originally Posted by Shah73 View Post
    Mashallah excellent cng consumption
  20. #4899
    Mar 2007
    Rawalpindi
    38
    4,537
    Default Found this cielo in pakwheels, civic's dashboard looking nice
    Daewoo fan club -365646
  21. #4900
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    wow it is nice.....very kool infact.......
