Page 255 of 370 FirstFirst ... 155205245253254255256257265305355 ... LastLast
Results 5,081 to 5,100 of 7393
Like Tree425Likes
Thread: Daewoo fan club
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Daewoo Racer/Cielo Fan Club
    Dear All,
    I am an owner of Daewoo Racer since 1995. It has proven to be a very comfortable and economical car throughout this period. It used to give an average of 13Km/L within city and ~15Km/L on long drives. Here are some pictures:
    Daewoo fan club -479355
    Daewoo fan club -479356
    Daewoo fan club -1050638
    Check the links for my rides
    1. Before 2008 (Racer)
    Daewoo Racer
    2. After Jan 2008 (Cielo)
    Daewoo Cielo
    I would recommend buying this car who want a better car at low budgets!
    Any member having used a Daewoo car must share their experience....(y)
    IMPORTANT: SCANNER Facility is Available at Friends Autos, I-9, Islamabad. [Khalid: 0322-5111110, 0321-9562840]
    Quick Links:
    Parts Dealers/workshops link [Page-3 post #:54]:
    Alloy Rim fitment [Page-15 post #:290]:
    The DOHC engine[Page-30 post #:585]:
    Service Manual/Electrical Diagrams link[Page-30 post #:594]:
    Cielo Conversion [Page-57 post #:1130]:
    How to get Black Bumpers [Page-60 post #:1315]:
    Reading ECM Error Codes [Page-191 post #:3804]:
    Air Conditioner maintenance shops [Page-195 post #:3897]:
    High RPM/Stalling Problem on AC, OK Otherwise[Page-203 post #:4048]:
  2. #5081
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by guybwp View Post
    how can we be precise what sensor is malfunctioning coz sometimes the symptoms of various faulty sensors overlap.....in my case im experiencing fluctuating speedomater cable but no CEL indication while at the same time when i shift from high to lower gear the rpm doesnt follow the gear...as per net it must be VSS i guess but how to be damn sure about it? also i thought the head was causing all the problem for heat up but last time when i serviced the radiator it was repaired..so i guess the heat up on A.C is due to radiator fault...and i also ve sanden compressor which doesnt have A.C signal switch i guess coz there r no other wire harnesses and the one it does ve i installed relay on it....with A.C on the car vibrates more on idle with high rpms which i guess is due to VSS....kindly what r ur views TESTDRIVER....hope im not too noisy....
    Sometimes there are intermittent error in which the error is corrected before CEL display. You can try reading any error code stored in the ECM.
    One more thing, did this problem occur before the installation of advancer? There is possibility that the advancer wiring is not done correctly, and the ECM is missing the reference signal from the distributor!
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
  3. #5082
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    nops the advancer has been installed for a long time now....and my car was all ok before this head was installed and pistons were changed.....except once when i went to isb...the CEL came on display on my way but mr athar from central autos said vss wire was disconnected so he reconected it back....but after that on my return to lahore....the speedometer cable started fluctuating but as u say the error was INTERMITENT...some times behaving normal and sometimes not.....even i checked the ECM the manual way and there was no error...but the high rpm issue started on my recent trip to my home city and even here.....some times the car is all ok but some times its not...some times even with A.C on the car runs normal but some times it doesnt and exhibits all the symptoms of high rpm and vibrations etc.....
  4. #5083
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    Quote Originally Posted by miankhizer View Post
    actually i wanted to know the purpose of thermostat switch...........plz tell me in details thanks
    if you remember, there had been a thermostat *** on the windows ACs whihc were used earlier in the houses before the emergemnce of splits ACs. This knob either had the numbers from 1 to 5 or cooling levels of Low, medium and HIgh; Purpose being to control the cooling temperatue level in the room.
    Same thermostat switch is also placed in the cars to have thed esired cooling level in the pasenger cabin when AC temperature will reach the desired level it ill trrip the AC compressor.
    In absence of it, compressor will be working contiuously putting continuous load on the egine, hence reducing its performance life.
  5. #5084
    sanerider's Avatar
    Feb 2010
    India
    243
    This will be interesting for Daewoo fans.
    Visit to Daewoo Motors (Argentum) plant, Surajpur, UP(Uttar Pradesh): a Chronicle in Pictures
    Visit to Daewoo Motors (Argentum) plant, Surajpur, UP: a Chronicle in Pictures - Team-BHP
    secularism is the norm.
  6. #5085
    ammadusmani1's Avatar
    Jan 2012
    Wah cantt
    35
    Quote Originally Posted by testdriver View Post
    For suspension/brake work you can contact Tahir @ G-8 (0333-5613924) or Shahid @ G-10 (0346-5041322) whichever person you choose/trust, but remember to get good quality parts. For parts, I recommend Aziz Auto, Saddar Rawalpindi (0333-5171833), who have recently opened their shop at I&T Centre in G-10 too.
    Thank you Adnan Bhai, i will check Aziz Auto and Tahir @G-8.
  7. #5086
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    Quote Originally Posted by sanerider View Post
    Very nice sharing, but is indeed very teasing to see such a big and structured plant in idle position.
    we pray for Its revitalization.
  8. #5087
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    whats the price of kabli radiator and new one and also VSS sensor price as well?
  9. #5088
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    I think it was 2010, when i changed my woo's radiator with the kabli one for Rs4000 in exchenge of mine.
    recently i bought new VSS for Rs 750 but it did nt work well. Now i intend to buy kabli one of Rs 1K approx.
  10. #5089
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    any competent electrician in lahore for sensors check up?.....
  11. #5090
    asad_scorpio21's Avatar
    Mar 2007
    Rawalpindi
    38
    4,537
    Quote Originally Posted by Shah73 View Post
    Price for Kabli Radiator is almost doubled now
  12. #5091
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    my cars tappet cover jain is leaking but im unable to find it in bahawalpur...im coming back to lhr after few days....the question is...is it dangerous to continue driving like dat? can i go on a long drive like this?
  13. #5092
    Jan 2012
    Wah cantt
    35
    Default Wheels Alignment
    @testdriver,
    Please recommend best alignment workshop.
  14. #5093
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    i wana change the radiator....coz the radiator i ve is repaired..i serviced it but still the heat up problem is still there esp at noon time when there is maximum heat and on A.C on....the prices of kabli radiator range from 2500 to 4500 and that of original one is 7000 and the one made in thailand is 6000-6300...which one is best...and how to know if the kabli radiator is alright? is there any way to test it? also the temperature sensor is not working..
  15. #5094
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    You can drive your car but keep an eye on the oil level, and change it as soon as possible.
    Adnan's
  16. #5095
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by ammadusmani1 View Post
    @testdriver,
    I have good experience with Master Wheels in I-9 (opposite Java Hotel)
    Adnan's
  17. #5096
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    dear test driver im going to buy new radiator soon...should i go for one made in thailand or kabli radiator and also ur right should i replace the coolant sensor ist? and what could be the reason for high rpms with fluctuating speedometer? should i replace VSS or TPS or IAC valve? how can i be sure? i think u narrated TPS and IAC valve check few posts back but i kinda lost track of it after reading so many posts...can u tell here once again?
  18. #5097
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    @testdriver,
    Adnan's
  19. #5098
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    I have not so good experience with new radiator especially their plastic tanks. I am currently using kabli radiator, at-least their tanks are available in market. Regarding sensors, don't go for hit and trial, instead get your car scanned and then identify the problem.
    Adnan's
  20. #5099
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    okies thx....but there is no scanner available in lhr like there in isb for daewoo racer.....n even on manual checkup like u mentioned to read error codes no code shows up for any sensor malfunction except 12 six times.....its an efi car so cant a scanner used to check other efi cars be also used to check daewoo racer aswell like OBD II scanner?
  21. #5100
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    also i wanted to know which radiator is best? the one made of aluminium or copper?? should it be bought from bilal ganj or korean autos montgomery road?
