Page 256 of 370 FirstFirst ... 156206246254255256257258266306356 ... LastLast
Results 5,101 to 5,120 of 7393
Like Tree425Likes
Thread: Daewoo fan club
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Daewoo Racer/Cielo Fan Club
    Dear All,
    I am an owner of Daewoo Racer since 1995. It has proven to be a very comfortable and economical car throughout this period. It used to give an average of 13Km/L within city and ~15Km/L on long drives. Here are some pictures:
    Daewoo fan club -479355
    Daewoo fan club -479356
    Daewoo fan club -1050638
    Check the links for my rides
    1. Before 2008 (Racer)
    Daewoo Racer
    2. After Jan 2008 (Cielo)
    Daewoo Cielo
    I would recommend buying this car who want a better car at low budgets!
    Any member having used a Daewoo car must share their experience....(y)
    IMPORTANT: SCANNER Facility is Available at Friends Autos, I-9, Islamabad. [Khalid: 0322-5111110, 0321-9562840]
    Quick Links:
    Parts Dealers/workshops link [Page-3 post #:54]:
    Alloy Rim fitment [Page-15 post #:290]:
    The DOHC engine[Page-30 post #:585]:
    Service Manual/Electrical Diagrams link[Page-30 post #:594]:
    Cielo Conversion [Page-57 post #:1130]:
    How to get Black Bumpers [Page-60 post #:1315]:
    Reading ECM Error Codes [Page-191 post #:3804]:
    Air Conditioner maintenance shops [Page-195 post #:3897]:
    High RPM/Stalling Problem on AC, OK Otherwise[Page-203 post #:4048]:
  2. #5101
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by guybwp View Post
    okies thx....but there is no scanner available in lhr like there in isb for daewoo racer.....n even on manual checkup like u mentioned to read error codes no code shows up for any sensor malfunction except 12 six times.....its an efi car so cant a scanner used to check other efi cars be also used to check daewoo racer aswell like OBD II scanner?
    First of all, I recommend that you go to the person who installed CNG and ask him to bypass the advancer and then check your car for any problem. If your car is giving problem but not registering any code, it means sensors are not faulty. It is just a wiring problem. Regarding your second question, you can't use any other car scanner unless you have universal one.
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
  3. #5102
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    also i wanted to know which radiator is best? the one made of aluminium or copper?? should it be bought from bilal ganj or korean autos montgomery road?
    I am using genuine kabli one. (Aluminum) You can get from anywhere you trust
    Adnan's
  4. #5103
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    i think i can bypass the advancer myself coz there is a connector which CNG guy said to connect incase the advancer malfunctions......
    what about coolant sensor? coz its like this forever means showing erronous reading. do u think its sensor or also just wiring problem....n putting 47ohm resistance will solve it? without changing the sensor....
  5. #5104
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
  6. #5105
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Basically Daewoo has a set of a of coolant sensor and a temperature gauge. There is no relation between the coolant sensor and temperature gauge. The coolant sensor tell the temperature to the ECM only while the temperature gauge provide it's output to the instrument cluster only. The resistance is installed in series to temperature gauge not the coolant sensor (Both have separate wiring). It is obvious that putting the resistance will not solve the issue if the coolant sensor is faulty.
    Adnan's
  7. #5106
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    Quote Originally Posted by testdriver View Post
    wow thx a lot for clearing that up, as for now i was thinking these both r one and the same thing....so i guess the sesnor is not faulty but the temperature gauge is faulty which is not depicting correct reading off the coolant sensor.....will get it checked soon when i return to lhr...
  8. #5107
    asifnadeem1975's Avatar
    Jun 2011
    110
    Dear Test Driver & all DFC members.
    Last week i travelled faisalabad via motorway. while travelling back I met an breakdown. my car stopped between Kallar Kahar & Balkasar. after that the car was not able to start due to heavy cranking. however I called motorway police, they towed my car to nearest autoworkshop (outside balkasar interchange). after investigation it was revealed that the cam shaft was broken. it was astonishing that there was no sound of any breakage during travelling. moreover the oil level was also normal. now a new cam shaft has been installed with lathe work on the tappet cover.
    testdriver and other members are requested to comment on it plz that what should be:-
    (a) Probable reason of this happening
    (b) Any indication of malfunctioning.
    (c) Measures to avoid any re-happening in future
  9. #5108
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by asifnadeem1975 View Post
    (a) Has there been any history of heat up? Probably the cam housing might be out of shape, causing unnecessary load on the cam shaft. From where did the cam shaft break? Middle? Where was the temperature needle while this happened?
    (b) The sound of timing belt can tell you if the engine is running hard in moving the cam shaft. Engine producing more heat than usual.
    (c) Avoid heat-ups by regularly monitoring the cooling system of engine. If there is excessive in the cooling system, get the head checked for it's face and/or air pockets.
    Adnan's
  10. #5109
    ammadusmani1's Avatar
    Jan 2012
    Wah cantt
    35
    BAD News:
    The central automobile is closed and Mr.Athar has been shifted to Karachi. He will come back in May inshaALLAH, said Mr. Athar.
  11. #5110
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    lately i noticed that whenever after driving the car when i open the radiator cap the water level is ok but the color is rusty at ist but after some time when the engine gets cold like 6 or 7 hours later..the water level is decreased but the color is clear? what could be the reason.....
  12. #5111
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    @TESTDRIVER i by passed the advancer and drove all the way from bwp to mul and then from mul to lahore in a day....the car wasnt heating up like it used to before. i think the head is ok coz if i dnt use A.C then there is no heat up issue much but only when i turn the A.C on that there is more load on engine and it gets hot...
    also even after bypassing the advancer i noticed high rpms on long drive and at one time it went so high that i had to pull over n off the engine...
    im now in lahore and will change radiotor ist....should i get the head checked as well? or leave it as such?
  13. #5112
    miankhizer's Avatar
    Aug 2010
    22
    Post Salaaam
    for all DFC members and specially those living in Soan, PWD, NPF, Bahria Town and surroundings.........for ur convenience and satisfactory maintenance of ur woo for every thing at one place go to AL-Imran auto workshop right adjacent to police check post on airport road near karal chowk..........i m going there for the last 2 yrs and satisfied more than anyother including the G-10 (faqir muhammad) and others...........i m not recommending u that workshop coz i used to go there but with the hope that my brothers owning woo will have a good mechanic for each and every part of woo.....i went to other mechanics for various car works but the asked for $ (dollars) but here u will be surprized to hear the rates and work.......
    contact:
    Mr. Shabbir (0300-5041068)
    Mr. Wasif (0342-5019578)
  14. #5113
    Jun 2011
    110
    Thanks for your reply brother. Parawise reply of your questions are here:-
    (a) There is no history of previous heat ups. cam shaft was broken from the middle. The temperature needle was at lowest mark as usual. even at the time of occurrence the needle & engine temp was normal.
    (b) sound of timing belt was normal.
    (c) upon dismentalling the head found deshaped. and head gasket was also found damaged.
    However, I bring my daewoo to Mr. Abdul karim @ I-10. he remove the head and sent to kharadia for lathe work now car is ok.
  15. #5114
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    today i got checked the temperature gauge by two electricians in lahore. one said to change the temperature gauge while the other took it out it was all covered with rust..he removed the rust using ragemar and said it was all ok....now im not sure what to do whether to change it or not....in lahore weather was quite good so car didnt heatup....the air filter was choked so changed it. the guy tempered with distributor and advanced it abit...and now when i turn the A.C on the car vibrates on idle and turns off...speedomater cable is ok as well now...i think its IAC Valve....lets see tomorow...
  16. #5115
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    Quote Originally Posted by miankhizer View Post
    contact:
    I think mechaqnic name is Wajid instead ofd Wasif???
  17. #5116
    Hamza24's Avatar
    Dec 2010
    68
    Smile 0 to 100
    Sal-am Brothers !
    A question came in mind that does Woo have ability to go 0 to 100 in 10 seonds without any supercharger or Nos etc. I tested My woo but On petrol it was doing 0to 100 in 16 sec? i thought Maybe car needs a tuning and some stuff like that? please Guide.
    secondly Plz tell which mechanic is good for Woo Because I went to federal Motors but they don't do a satisfactory work they only charge money.My friend told me that Central Autos is Also good. And Any mechanic near Adyala Road?
    Thanks
    Jazakallah!
  18. #5117
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by Hamza24 View Post
    Sal-am Brothers !
    Thanks
    Jazakallah!
    The stock 1.5 8V engine can do it in 12.5 seconds as per official documentation, but it is not mentioned how they compute 0-100 (specifically weight). I haven't accurately checked for my car, when it had the 8V engine, but on a 16V it was something like 11 seconds.
    For better 0-100 on petrol, you need to remove any alteration done specifically for CNG like Ventury/Nozel, Air Blockage, CNG cylinder and rear packing. Also the spark timing needs to be readjusted.
    Daewoo fan club -395457
    Adnan's
  19. #5118
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    "testdriver@
    my question is other than daewoo, i have changed gearbox of my khyber with the kabli one as previous one was producing enough goonj. now after replacement, it has been majorly reduced but still present therein.
    now there are two options either to replace it again or use some gear oil additive like liquimoly gear oil additive and liquimoly gear protect???
    what do you suggest? is it possible that this goong may be of some other thing. sound reduces in 3rd and 4th gear. in case of wheel bearing, it will not reduce in top gears.
    i used new gear oil of caltex of 90 No in the kabli gear.
    both mechanics were satisfied with the kabli gear quality when it was opened.
  20. #5119
    mrasifrasool's Avatar
    Jun 2006
    Wah cantt
    40
    192
    Default Cam Shaft problem
    A-O-A to testdriver and all Daewoo family.
    i have some problem in my daewoo from last two weeks.
    <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:TrackMoves/> <w:TrackFormatting/> <wunctuationKerning/> <w:ValidateAgainstSchemas/> <waveIfXMLInvalid>false</waveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <woNotPromoteQF/> <w:LidThemeOther>EN-US</w:LidThemeOther> <w:LidThemeAsian>X-NONE</w:LidThemeAsian> <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript> <w:Compatibility> <w:BreakWrappedTables/> <wnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> <wplitPgBreakAndParaMark/> <wontVertAlignCellWithSp/> <wontBreakConstrainedForcedTables/> <wontVertAlignInTxbx/> <w:Word11KerningPairs/> <w:CachedColBalance/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> <m:mathPr> <m:mathFont m:val="Cambria Math"/> <m:brkBin m:val="before"/> <m:brkBinSub m:val="--"/> <m:smallFrac m:val="off"/> <m:dispDef/> <m:lMargin m:val="0"/> <m:rMargin m:val="0"/> <m:defJc m:val="centerGroup"/> <m:wrapIndent m:val="1440"/> <m:intLim m:val="subSup"/> <m:naryLim m:val="undOvr"/> </m:mathPr></w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true" DefSemiHidden="true" DefQFormat="false" DefPriority="99" LatentStyleCount="267"> <w:LsdException Locked="false" Priority="0" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Normal"/> <w:LsdException Locked="false" Priority="9" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="heading 1"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9"/> <w:LsdException Locked="false" Priority="39" Name="toc 1"/> <w:LsdException Locked="false" Priority="39" Name="toc 2"/> <w:LsdException Locked="false" Priority="39" Name="toc 3"/> <w:LsdException Locked="false" Priority="39" Name="toc 4"/> <w:LsdException Locked="false" Priority="39" Name="toc 5"/> <w:LsdException Locked="false" Priority="39" Name="toc 6"/> <w:LsdException Locked="false" Priority="39" Name="toc 7"/> <w:LsdException Locked="false" Priority="39" Name="toc 8"/> <w:LsdException Locked="false" Priority="39" Name="toc 9"/> <w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption"/> <w:LsdException Locked="false" Priority="10" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Title"/> <w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"/> <w:LsdException Locked="false" Priority="11" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtitle"/> <w:LsdException Locked="false" Priority="22" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Strong"/> <w:LsdException Locked="false" Priority="20" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Emphasis"/> <w:LsdException Locked="false" Priority="59" SemiHidden="false" UnhideWhenUsed="false" Name="Table Grid"/> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"/> <w:LsdException Locked="false" Priority="1" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="No Spacing"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 1"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 1"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 1"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"/> <w:LsdException Locked="false" Priority="34" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"/> <w:LsdException Locked="false" Priority="29" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Quote"/> <w:LsdException Locked="false" Priority="30" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 1"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 1"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 2"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 2"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 2"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 2"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 2"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 3"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 3"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 3"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 3"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 3"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 4"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 4"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 4"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 4"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 4"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 5"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 5"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 5"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 5"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 5"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 6"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 6"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 6"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 6"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 6"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/> <w:LsdException Locked="false" Priority="19" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"/> <w:LsdException Locked="false" Priority="21" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"/> <w:LsdException Locked="false" Priority="31" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"/> <w:LsdException Locked="false" Priority="32" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"/> <w:LsdException Locked="false" Priority="33" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Book Title"/> <w:LsdException Locked="false" Priority="37" Name="Bibliography"/> <w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading"/> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size; mso-tstyle-colband-size; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-altin 5.4pt 0in 5.4pt; mso-para-margin-topin; mso-para-margin-rightin; mso-para-margin-bottom:10.0pt; mso-para-margin-leftin; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} </style> <![endif]--> I am using Daewoo from last 6 years. Some month ago I overhauled the engine from Daewoo point Islamabad but after the almost 10,000km running suddenly cam was broken at 95km/h speed.
    I go to my mechanic Daewoo point he change the cam shaft (KABLI) but after the 200km running one day I start my car in morning and after 2 mint cam was broken again. I call the mechanic he advice to change whole head with cam.
    Dear testdriver please guide me and also tell me what problem will occurs in my Daewoo Head. Can my Daewoo head is not repairable?
    Waiting your response.
  21. #5120
    miankhizer's Avatar
    Aug 2010
    22
    Quote Originally Posted by Shah73 View Post
    yes u r right but that was the old workshop headed by mr wajid.....now in the new setup some ppl were changed........try this out
