Page 269 of 370 FirstFirst ... 169219259267268269270271279319369 ... LastLast
Results 5,361 to 5,380 of 7391
Like Tree425Likes
Thread: Daewoo fan club
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Daewoo Racer/Cielo Fan Club
    Dear All,
    I am an owner of Daewoo Racer since 1995. It has proven to be a very comfortable and economical car throughout this period. It used to give an average of 13Km/L within city and ~15Km/L on long drives. Here are some pictures:
    Daewoo fan club -479355
    Daewoo fan club -479356
    Daewoo fan club -1050638
    Check the links for my rides
    1. Before 2008 (Racer)
    Daewoo Racer
    2. After Jan 2008 (Cielo)
    Daewoo Cielo
    I would recommend buying this car who want a better car at low budgets!
    Any member having used a Daewoo car must share their experience....(y)
    IMPORTANT: SCANNER Facility is Available at Friends Autos, I-9, Islamabad. [Khalid: 0322-5111110, 0321-9562840]
    Quick Links:
    Parts Dealers/workshops link [Page-3 post #:54]:
    Alloy Rim fitment [Page-15 post #:290]:
    The DOHC engine[Page-30 post #:585]:
    Service Manual/Electrical Diagrams link[Page-30 post #:594]:
    Cielo Conversion [Page-57 post #:1130]:
    How to get Black Bumpers [Page-60 post #:1315]:
    Reading ECM Error Codes [Page-191 post #:3804]:
    Air Conditioner maintenance shops [Page-195 post #:3897]:
    High RPM/Stalling Problem on AC, OK Otherwise[Page-203 post #:4048]:
  2. #5361
    seismic's Avatar
    Dec 2009
    Rawalpindi
    37
    73
    Default Information Sharing
    Finally STAP56 is installed. The microswitches are set at 15 degree advance. CNG consumption is on the higher side. I will check on 12 degree.
    Thanks to testdriver.
  3. #5362
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    Quote Originally Posted by testdriver View Post
    Is there any intermittent code displayed? If yes, then it seems like VSS problem. If no, you should check IAC. The most simple check of IAC valve is to slowly release the clutch in first gear. If the RPM rises to keep the engine running, then IAC valve is fine, and if the engine stalls, the IAC valve is faulty.
    If the problem is only on CNG, you should service the kit and clean the cylinder from any residual oil.
    there is no code displayed at all.....
    i will surely check the way u wrote here...one more thing which i wana narrate here is that when ever i run the car to the speed of 60 or above and then i apply breaks suddenly the RPM never returns with the with the speed needle and takes extra time to return to normal level...and this vibration thing is more pronounced on CNG but it also happens on Petrol some times...it was so much on CNG that a month i jsut rode my car on petrol but then on my last trip from my home town this vibration thing started happening on petrol as well when i was coming back to lhr....the engine would sufocate when i would apply break and the pick will go dead in 2nd to 3rd gear but picks up at 60km/p....the mechanic services all parts..washed everything with PEtrol.. the vss sensor the iac valve and TPS injector....everything..and adjusted the filter box opening...now pick is ok ......im running the car on CNG...but some times the when i apply clutch the car vibrates untill i ve to stop the car and let the rpm adjust themselves and when car is ok i move it forward and this happens....
  4. #5363
    Javaid35's Avatar
    May 2007
    Rawalpindi
    44
    54
    salam !
    i m gonna buy a daewoo isb registered 93
    i have a querry regarding AC compressor and its piping along with condenser, dryer unit and off course the freezer
    r the genuine new ones available in the market?? if yes then i ll appreciate if some one can quote the shop and prices and best rates/ place to buy
    thnx in advance
  5. #5364
    azkhan's Avatar
    Mar 2004
    28
    517
    20 Post(s)
    @javaid35 I have changed my compressor with SANDEN one and quite satistied with it as original ones are found used and known to last atmost two seasons. In any case contact ABubaker (Universal car AC) 03335527356.Regards
    //.....Don't bully Korean cars.......//
  6. #5365
    fslrao's Avatar
    Aug 2011
    Kharian
    99
    AoA I wanted to ask about the air filter.My mech advised me to change air filter with Khyber (nimda type not of paper)as it is best for CNG and accurately fit in woo air cleaner.Expert advice pls
  7. #5366
    asad_scorpio21's Avatar
    Mar 2007
    Rawalpindi
    38
    4,537
    @Testdriver/Experts
    My ride has problem of RPM dropping down with AC on , i.e without AC RPM remains at 900-1000 but with AC it drops down by 700. wat could be the better solution ,
    thanks in advance
  8. #5367
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    @seimic
    Good work! Thanks.
    Quote Originally Posted by fslrao View Post
    I also have seen many Daewoo with the Khyber air filter. The OEM filter is paper type and is recommended. You can try that air filter as it is not a big deal and report back!
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
  9. #5368
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by asad_scorpio21 View Post
    @Testdriver/Experts
    thanks in advance
    The problem seems to be with the AC signal switch. Ask your electrician to short the 12V wire from high pressure AC switch to the signal wire of AC signal harness.
    Adnan's
  10. #5369
    Mar 2007
    Rawalpindi
    38
    4,537
    thanks for reply , I consulted with Mian Khan , he told me that ACM switch is faulty and need to replaced.
  11. #5370
    fslrao's Avatar
    Aug 2011
    Kharian
    99
    Thx alot IA I'll share the results of Khyber air filter,kindly explain OEM term.More over I've got my AC renewed rather woo fitted with new
    condenser(Japanese original),compressor of Mitsubishi Lancer (2007) rotary type rest woo original parts.Cooling is good car feels absolutely no load, gas consumption is comparatively low.Fitting done in a very professional way even better than original.Cost eff:-
    a. Compressor Rs 7000
    b. Condenser Rs 6000
    c. Mounting, lines and lab Rs 1500
    d. Gas charges Rs 1500
    Total: Rs 16000
    Expert comments pls
  12. #5371
    asifnadeem1975's Avatar
    Jun 2011
    110
    Default Air cond problem
    Dear test driver and other members:
    The pick of daewoo decreases with ac on. Otherwise engine power is ok. Is it ok?
  13. #5372
    fslrao's Avatar
    Aug 2011
    Kharian
    99
    Its a question about CO manual adjustment, can we adjust CO on CNG or it has to be done on pet.
    Regarding air filter, there is minor diff in the make, woo original comes with rim collars for sealing but the Khyber filter is not provided with the same.
  14. #5373
    fslrao's Avatar
    Aug 2011
    Kharian
    99
    Quote Originally Posted by asifnadeem1975 View Post
    The pick decrease is normal in my opinion but it can be reduced to 50% as compared to original compressor if u install a rotary type of compressor.
  15. #5374
    Jun 2011
    110
    thanks brother
  16. #5375
    fslrao's Avatar
    Aug 2011
    Kharian
    99
    thanks brother
    Always welcome dear,any knowledge regarding original ac compressor of Woo,is it piston type or rotary one?
  17. #5376
    fslrao's Avatar
    Aug 2011
    Kharian
    99
    Dear members and Mentor DFC (testdriver),any knowledge regarding presence of a small filter in ac pipes joint located adjacent to fire wall of the veh. Please explain its role and functions.
    1. Any knowledge regarding original ac compressor of Woo,is it piston type or rotary one?
    2. Its a question about CO manual adjustment, can we adjust CO on CNG or it has to be done on pet.
  18. #5377
    zeeshan213's Avatar
    May 2008
    31
    222
    2 Post(s)
    @ Test driver bhai and other woo experts.....is there any valve present in AC unit.....if present then where it is located and if it is not working then frm where it is available....also whatis its function........plzzz required ur sugestions n replies....
  19. #5378
    tweetykiller's Avatar
    Jan 2007
    Sambrial
    44
    73
    Assalam-o-Alaikum!
    Respected Members of DFC
    I am from Sialkot, and bought a daewoo racer for family use but I read this forum that mostly parts are available in Pindi and upwards.
    Cars engine need work as it gives white smoke and its chamber leaks as well, gear box does not hold Oil, engine gets very hot, may be its due to the radiator.
    I want to change its engine and gearbox to a system which parts can be easily avalable . What type of engine is good for it? with less price
    Or
    Shall I have to go to Rawalpindi for overhauling?
    Which is best and cheap option for me in these days?
    I hope to reaceive a positive and encouraging advice from the DFC members.
    It is never late to learn.
  20. #5379
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Expansion Valve/ Orifice tube
    @fslrao
    As generally expansion valve in air conditioning does, it converts high pressure liquid refrigerant to low pressure mist causing it to get extremely cool. Regarding CO, no it is not used in cng tuning.
    @all
    Expansion valve for daewoo is available with Javaid Sons, I&T Centre, G-9 (051-2260121)
    Adnan's
  21. #5380
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    @tweety
    Better try your luck at Lahore as there are plenty of daewoo parts and mechanics there. Few contacts can be found on page 3 of this forum.
    For engine compatibilty go for 2E or 4AFE toyota engine in petrol or CD17 Nissan in diesel.
