Page 329 of 370 FirstFirst ... 229279319327328329330331339 ... LastLast
Results 6,561 to 6,580 of 7393
Like Tree425Likes
Thread: Daewoo fan club
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Daewoo Racer/Cielo Fan Club
    Dear All,
    I am an owner of Daewoo Racer since 1995. It has proven to be a very comfortable and economical car throughout this period. It used to give an average of 13Km/L within city and ~15Km/L on long drives. Here are some pictures:
    Daewoo fan club -479355
    Daewoo fan club -479356
    Daewoo fan club -1050638
    Check the links for my rides
    1. Before 2008 (Racer)
    Daewoo Racer
    2. After Jan 2008 (Cielo)
    Daewoo Cielo
    I would recommend buying this car who want a better car at low budgets!
    Any member having used a Daewoo car must share their experience....(y)
    IMPORTANT: SCANNER Facility is Available at Friends Autos, I-9, Islamabad. [Khalid: 0322-5111110, 0321-9562840]
    Quick Links:
    Parts Dealers/workshops link [Page-3 post #:54]:
    Alloy Rim fitment [Page-15 post #:290]:
    The DOHC engine[Page-30 post #:585]:
    Service Manual/Electrical Diagrams link[Page-30 post #:594]:
    Cielo Conversion [Page-57 post #:1130]:
    How to get Black Bumpers [Page-60 post #:1315]:
    Reading ECM Error Codes [Page-191 post #:3804]:
    Air Conditioner maintenance shops [Page-195 post #:3897]:
    High RPM/Stalling Problem on AC, OK Otherwise[Page-203 post #:4048]:
  2. #6561
    eunuznadim's Avatar
    Jan 2012
    17
    2 Post(s)
    Hi Test Driver,
    What are the check points to review if I'm experiencing lot of missing on CNG and unable to find a competent electrician around?
    Regards,
  3. #6562
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by guybwp View Post
    if thats the case then i did get the car tuned on CNG...but some times while driving the rpm drop when i press the clutch adn car vibrates and shuts down...and if i restart the car with instantly then again the car will keep on shutting down every time i press the clutch on slowing down the car. but when i take out the key from the ignition and reinsert it and then start the car then it doesnt shut down...
    2ndly i dont know if a relay has been put with the compressor or not ...but i do know is that i have sanden compressor in my car ..and also i have noticed these past few weeks that some times during driving the CEL will on and when i restart the car it goes off...
    AoA
    Did you try to read the code? Does the car behave (shut down) same on petrol? Does the CEL apprear when the problem of shut off occur? What if you do not remove the key and start after few seconds(not instantly)?
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
  4. #6563
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by eunuznadim View Post
    Hello Woo Experts!
    Can someone plz guide me which indicator / Brake light-covers fit in Woo? Unfortunately mine are broken and I'm unable to find in Mianwali/Shorkot type areas.
    Regards
    Welcome here!
    Unfortunately no cover will exactly fit but still you can consult a light repair person if he can do something. Alternately, you can consult Korea Autos, Lahore (contact given at page-3), and they can courier it to your place. They do offer easy paisa as a mode of payment.
    Hi Test Driver,
    Regards,
    First of all, check if the car behaves the same on petrol. If you are experiencing the same problems on petrol too, then check for the problems like vacuum leak, distributor problem, main coil current leak, plugs/plug wires. The missing can also be due to valve leakage in engine head. Does the check engine light appear?
    Adnan's
  5. #6564
    madilrana's Avatar
    Mar 2009
    Mian Walli
    48
    5
    please some on guide me. my daewoo racer 92 model was running fine on CNG and patrol. but from some days when it is on petrol it gives kick backs (Jhatkay) in 1st, 2nd and 3rd gear when rpm reaches to about 1900-2000. in 4th gear it works better. but on CNG it shows no prb and runs smoothly without any missing. I live in Mianwali and dont have any Daewoo Mechanic.plz some one guide.
  6. #6565
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by madilrana View Post
    "kick back"
    Missing on petrol and working fine on CNG, the first thing to check is the fuel pump.
    Adnan's
  7. #6566
    madilrana's Avatar
    Mar 2009
    Mian Walli
    48
    5
    @testdriver. got the pump checked and filter cleaned. someone said petrol over ho raha hai. ???????.plz help
  8. #6567
    madilrana's Avatar
    Mar 2009
    Mian Walli
    48
    5
    @eunuznadim.you can contact yasir autos at auto plaza nawan shehar multan. You can also find only covers also from there.
  9. #6568
    overspeed111's Avatar
    Apr 2010
    1,176
    AOA,
    thank you sir for all of ur previous replies,
    now after trying 3-4 times im able to read codes and here they are 33,24,12,21 what to do now? how sensors can be read and to solve these problems?
    other thing is that somewhere you mentioned how to perfectly adjust it on petrol you mentioned CO adjustment so what is this CO and how it can be adjusted in an MPFI engine?
  10. #6569
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    How did your mechanic check if the pump is providing required pressure? Pressure gauge? Also, the filter has a specific age, when did you last change it? Cleaning wont help.
    Do you experience starting problems on petrol? Secondly, whoever did the CNG wiring, how did he provide power to the pump? If it is directly connected to the changeover switch, a relay should be used to power the pump using the wire from changeover switch as remote/signal.
    Adnan's
  11. #6570
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by overspeed111 View Post
    AOA,
    WAS,
    Code 21 will always blink, so keep it aside. The other codes are:
    Code 33: MAP High - MAP voltage not settling below 2V at idle
    Code 24: No VSS signal - VSS/Wiring is faulty or no VSS at all
    Code 21: TPS High - TPS voltage is higher than 1V at idle
    I suggest to settle the VSS issue, and the rest shall be resolved automatically. Idle in terms of ECM means the vehicle engine is running without change in VSS value (shows vehicle movement). If it sense the VSS signal, it will not treat the engine at idle and the other two symptoms shall be automatically resolved. Regarding CO, MPFi engine doesn't have one, so obviously no settings
    Adnan's
  12. #6571
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    Quote Originally Posted by testdriver View Post
    AoA
    Yes the car doesn't display any codes.
    No the car runs totally normal on petrol n doesn't shut down at all
    Yes when the car shuts down all the lights come on including the cel.
    Even if I don't start the car right away with out taking the key out the car behaves the same way.
  13. #6572
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    Another thing for the last two days when I starter the car it won't take sulf. When I put in the key all the lights would lit up but the key moved freely in lock cylinder no matter how much I jiggled it ... It happens only in the morning.. And at noon time the the car started taking sulf again. But again in the morning the same thing happened that key moved free in the lock but once I dhaka start the car in second gear ... The key started engaging n car started taking sulf. I went to mechanic n he removed the ignition switch cleaned it as there was lot of carbon ... N now I'm waiting to see if that was the culprit cox some one said it might be sulf being worn out ....
  14. #6573
    vc_engineer's Avatar
    Feb 2012
    Rawalpindi
    35
    5 Post(s)
    In morning; when it does not take sulf ; does all lights dimms? If yes you need to check sulf.
    Korean car's ignition cylinders are not so good.
    Sent from my SHV-E250K using PW Forums mobile app
  15. #6574
    usman_arooq2's Avatar
    May 2011
    Sialkot
    1,437
    13 Post(s)
    Me and my friend have his daewoo racer at our disposal, its gonna be our project ride, we both have separate cars for daily runners so refrain for discouraging us. first candidate for the project was my khyber but we dropped the idea. now I need suggestions about which engine we should swap in it that'd be easy to mate. my plan is to go with something like people do to spectra(drop in 4efe or some other toyota engine) but my friend wants to go for some d, f or k series by honda. we have stripped out the interior and engine is outta car so quick replies would be appreciated, and pics would be uploaded on a separate thread after the project is mechanically complete.
    some of the priorities are
    1. it should be something with least issues of parts availability.
    2. powerful and something that takes mods happily
    3. easy to swap, I mean making custom mounts isn't a problem but it shouldn't interfere with something under the hood, wanna do it with minimal cutting.
    Bella, You give me everything just by REVing - NEONLIGHT SAGA: NEWTUBE
  16. #6575
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    Quote Originally Posted by vc_engineer View Post
    the lights don't dim ....another story which I like to share ....today as I was going home from lahore to bwp n stopped at a petrol station near mian chanu. The car didn't start again. I kept on applying sulf but it couldn't start I brought some local mechanic ... The current was coming but every time the sulf was applied the lights will go out n car won't start .. so finally opened the steering column n saw that the ignition switch grip was loose some how.. so it was tightened n I also changed the ignition switch with an old one but then out of no where the key won't engage n take sulf n just moved freely. so again started the car thru dhaka. I got home switched off the car n then started again n now it's taking sulf again... now I don't know where the problem lies ... The sulf or the switch ... Please can any body help me out..Also the car was jerking alot on ac esp on 2nd and 3rd gear same as madilrana said... test driver please need ur help ... I will be waiting as these r eid holidays I know u all r holidaying kindly do read n reply after eid
  17. #6576
    asiiffareed's Avatar
    Oct 2014
    Wah cantt
    24
    2 Post(s)
    Testdriver and Shaan are the best guys. I have been following your feedback and am really happy to see that there are people in this world who still are willing to help. i bought Daewoo officer scheme 93 model registred 2001 in 290,000. Its in good condition. I was going to Multani ustad in sadar for some of its work but come to known that there is a mechanic in G8 who is master of Daewoo. My current problem is its giving me good milage on CNG: 120 city and 180 on long route. but on petrol its giving only 7-8 km on long and 6 on local. i have place a new fuel injector. The mechanic has electronically adjusted the fuel injection speed to 1.25 and its pick is gone now. At full acclerator its starts shaking like hell. meanwhile on cng the pick is gone also
  18. #6577
    Feb 2012
    Rawalpindi
    35
    5 Post(s)
    @guybwp its better you change Gutka of ignition switch.
    Change gutka if and only when your ignition switch pin (cylender in good condition) otherwise do some modifications and replace with suzuki ignition switch. Although It is not good approach to change with suzuki ignition but you will feel comfort regarding ignition problems
  19. #6578
    mrasifrasool's Avatar
    Jun 2006
    Wah cantt
    40
    192
    Eid ul Azha Mubarak to all Daewoo Fan Club Family specially Testdriver
  20. #6579
    eunuznadim's Avatar
    Jan 2012
    17
    2 Post(s)
    Thanks Test Driver, the missing is not there on petrol, but on CNG the missing problem is aggravating day by day. Engine check light also does not appear during missing issue.
  21. #6580
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    First of all happy belated eid wishes to all and sorry for late response.
    Quote Originally Posted by usman_arooq2 View Post
    Daewoo Racer has plenty of engine room and it can take majority of engines. I would say go for the Daewoo's own 16v twin cam engine or in extreme case, go for Toyota engine. Honda engine have to be installed the other way round and major fabrication will be needed so avoid them.
    Quote Originally Posted by asiiffareed View Post
    Thanks for nice words.
    Bad pick on both fuels can be due to various factors including
    1. Bad valve timing
    2. Bad engine compression
    3. Plugs problem
    4. Jammed wheels
    I suggest to show your car to Tahir at G-8 for physical checking.
    Adnan's
