Page 353 of 370 FirstFirst ... 253303343351352353354355363 ... LastLast
Results 7,041 to 7,060 of 7393
Like Tree425Likes
Thread: Daewoo fan club
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Daewoo Racer/Cielo Fan Club
    Dear All,
    I am an owner of Daewoo Racer since 1995. It has proven to be a very comfortable and economical car throughout this period. It used to give an average of 13Km/L within city and ~15Km/L on long drives. Here are some pictures:
    Daewoo fan club -479355
    Daewoo fan club -479356
    Daewoo fan club -1050638
    Check the links for my rides
    1. Before 2008 (Racer)
    Daewoo Racer
    2. After Jan 2008 (Cielo)
    Daewoo Cielo
    I would recommend buying this car who want a better car at low budgets!
    Any member having used a Daewoo car must share their experience....(y)
    IMPORTANT: SCANNER Facility is Available at Friends Autos, I-9, Islamabad. [Khalid: 0322-5111110, 0321-9562840]
    Quick Links:
    Parts Dealers/workshops link [Page-3 post #:54]:
    Alloy Rim fitment [Page-15 post #:290]:
    The DOHC engine[Page-30 post #:585]:
    Service Manual/Electrical Diagrams link[Page-30 post #:594]:
    Cielo Conversion [Page-57 post #:1130]:
    How to get Black Bumpers [Page-60 post #:1315]:
    Reading ECM Error Codes [Page-191 post #:3804]:
    Air Conditioner maintenance shops [Page-195 post #:3897]:
    High RPM/Stalling Problem on AC, OK Otherwise[Page-203 post #:4048]:
  2. #7041
    Kamando's Avatar
    Dec 2009
    127
    7 Post(s)
    Quote Originally Posted by guybwp View Post
    not the whole switch but just the point where the battery wire is attached to it....its still working but not to its full extent as the car pick is reduced n more load on engine n it heats up more. the car audio player stops functioning....n sometimes i even smel the burning of wire in car cabin....the generator is kabli n its coil has been replaced 2 yrs back...there is no battery issue as i got the battery changed 6 months back....i dont know wat is putting that much load on the switch.
    Wel burnt point is indication for more current flow through wire
    If generator is ok still recommend to get it checked by load meter regarding charging ...[its bush of generators that fails rather coil in my experience and daweoo generator bushes are not replaceable to my knowledge ]
    Check generator wire is not touching body espcially on high rpm [once happened to me and also my audio system was restating at high speeds ]
    Do Install relay for lights ....
    Hope above measures solve ur issue .
  3. #7042
    seismic's Avatar
    Dec 2009
    Rawalpindi
    37
    73
    Default Cooling Fan Operation and A/C Signal Switch Solution ?
    @test driver and all,
    My car cooling fan works at two speed mode even with a/c on it initially work at low speed. Fan keep running for some time even if i switch off the a/c. Is this fan operation normal ? if not then where is the defect ?
    A/C compressor signal switch is faulty. On hard pressing the pedal while standing still, compressor disengages but not in case the car is moving. Is there any good solution for disengagement function without installing a/c signal switch ?
  4. #7043
    zeeshan213's Avatar
    May 2008
    31
    222
    2 Post(s)
    A.o.A...Test Driver and other Daewoo Experts..........is it possible to convert daewoo simple steering into electric power steering........need sugestions.....thank you.....
  5. #7044
    welcome786's Avatar
    Jan 2008
    39
    377
    5 Post(s)
    Quote Originally Posted by zeeshan213 View Post
    yaar daewoo ka original hi bohat acha feel deta hay kiyon convert karwana chahte ho?
    MONEY IS YOURS BUT RESOURCES BELONG TO THE
    SOCIETY
  6. #7045
    zeeshan213's Avatar
    May 2008
    31
    222
    2 Post(s)
    Quote Originally Posted by welcome786 View Post
    brother i am using 185/55/15 rims and tyres.....dats y steering get hard on sharp turn, cutts, specialy in Markets.....
  7. #7046
    devilskreed's Avatar
    Sep 2012
    Rawalpindi
    27
    2,488
    59 Post(s)
    Quote Originally Posted by seismic View Post
    On hard pressing the pedal compressor disengages..It has a clutch system as the compressor puts load over the engine in case when you are climbing cliff/or need more power the compressor will disengage to provide that needed power.Its completely normal.
    I would suggest to get your AC blower serviced.Dust might cause it to work at 2 speeds vs 4.On switching off ac fan is supposed to run as it has to regulate temperature whether ac is on or off.Go to daewoo workshop in gulraiz.they will sort all your problems
    The one thing that unites all human beings, regardless of age, gender, religion, economic status, is that, deep down inside, we all believe that we are above-average drivers.
  8. #7047
    addeology's Avatar
    Apr 2014
    35
    518
    12 Post(s)
    Daewoo Racer Experts!
    Can I change my daewoo race door panel (Gatay) to ceilo power window panel? its bolt on??
  9. #7048
    turabbutt524's Avatar
    Feb 2010
    Rawalpindi
    23
    216
    Quote Originally Posted by devilskreed View Post
    Teaser Trailer
    Daewoo fan club -1592573
    Nice brthr... really want to see the final product
  10. #7049
    addeology's Avatar
    Apr 2014
    35
    518
    12 Post(s)
  11. #7050
    addeology's Avatar
    Apr 2014
    35
    518
    12 Post(s)
    Guys please suggest me engine to swap in my daewoo. must be 1.6 or 1.8 . Automatic is my choice. need an engine with lesser alteration. Ideally toyota or honda engine as daewoo egines are hard to maintain wrt mechanics availability. Thanx in advance
  12. #7051
    z0k
    z0k is offline
    z0k's Avatar
    Feb 2015
    21
    36
    Quote Originally Posted by addeology View Post
    I'd suggest u to go for axio/corolla x 1.5 engine. Very powerful and fuel economical. I drive 4afe a.k.a 16valve its more powerful but not fuel economical.
  13. #7052
    seismic's Avatar
    Dec 2009
    Rawalpindi
    37
    73
    @devilskreed
    Thanks for the reply, I think I couldn't clarify my question, cooling fan means radiator fan, clutch disengagement function only works when the car is standing still and not otherwise. Alternate solution means I need this function but without installing compressor signal switch as it becomes faulty after sometime.
    gulraiz workshop will be my last choice I know them since long.
  14. #7053
    Kamando's Avatar
    Dec 2009
    127
    7 Post(s)
    Guys any info regarding cooling coil of daewoo
    I am looking for original new not kabli one ....
    In Market i could find the china coil
    Do not how reliable is it ....
  15. #7054
    zeeshan213's Avatar
    May 2008
    31
    222
    2 Post(s)
  16. #7055
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    You dont need EPs Daewoo steering is quite decent the problem cames when ppl use wrong spec alloys on daewoo racer
  17. #7056
    z0k
    z0k is offline
    z0k's Avatar
    Feb 2015
    21
    36
    I converted my daewoos steering to power!
  18. #7057
    addeology's Avatar
    Apr 2014
    35
    518
    12 Post(s)
    Quote Originally Posted by z0k View Post
    i converted my daewoos steering to power!
    eps ??
  19. #7058
    z0k
    z0k is offline
    z0k's Avatar
    Feb 2015
    21
    36
    eps ??
    Nope not electronic.
  20. #7059
    addeology's Avatar
    Apr 2014
    35
    518
    12 Post(s)
    EPS stands for Electronic Power Steering ;-) . Anyhow which brand or from which car its taken off.
  21. #7060
    z0k
    z0k is offline
    z0k's Avatar
    Feb 2015
    21
    36
    I know :p theres a difference in electronic power steering and power steering.. if im not wrong
