Page 358 of 370 FirstFirst ... 258308348356357358359360368 ... LastLast
Results 7,141 to 7,160 of 7394
Like Tree425Likes
Thread: Daewoo fan club
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Daewoo Racer/Cielo Fan Club
    Dear All,
    I am an owner of Daewoo Racer since 1995. It has proven to be a very comfortable and economical car throughout this period. It used to give an average of 13Km/L within city and ~15Km/L on long drives. Here are some pictures:
    Daewoo fan club -479355
    Daewoo fan club -479356
    Daewoo fan club -1050638
    Check the links for my rides
    1. Before 2008 (Racer)
    Daewoo Racer
    2. After Jan 2008 (Cielo)
    Daewoo Cielo
    I would recommend buying this car who want a better car at low budgets!
    Any member having used a Daewoo car must share their experience....(y)
    IMPORTANT: SCANNER Facility is Available at Friends Autos, I-9, Islamabad. [Khalid: 0322-5111110, 0321-9562840]
    Quick Links:
    Parts Dealers/workshops link [Page-3 post #:54]:
    Alloy Rim fitment [Page-15 post #:290]:
    The DOHC engine[Page-30 post #:585]:
    Service Manual/Electrical Diagrams link[Page-30 post #:594]:
    Cielo Conversion [Page-57 post #:1130]:
    How to get Black Bumpers [Page-60 post #:1315]:
    Reading ECM Error Codes [Page-191 post #:3804]:
    Air Conditioner maintenance shops [Page-195 post #:3897]:
    High RPM/Stalling Problem on AC, OK Otherwise[Page-203 post #:4048]:
  2. #7141
    Kamando's Avatar
    Dec 2009
    127
    7 Post(s)
    Try bilal ganj for used parts ...
    New are not available now a days
    And if u visit bilal ganj do update about status of daewoo parts there ....
  3. #7142
    sheri_da_1's Avatar
    Sep 2007
    21
    142
    Sure i will!
    Thanks for a quick reply. But do you know any particular shop?
    Its been so long jab gaya tha last. And also, suspension shocks wegaira mil jayega qabli?
  4. #7143
    Kamando's Avatar
    Dec 2009
    127
    7 Post(s)
    I visited bilal gamj about 5-6 years ago ....
    There were special daewoo houses dealing in full daewoo parts ....
    For shocks and suspensions i will recommend new ...
    Otherwise get ur shocks repaired and replace bushes of suspensions...
  5. #7144
    nakheb's Avatar
    Dec 2004
    Rawalpindi
    35
    95
    2 Post(s)
    @ Testdriver last feb my car's fuel pump stopped working after a long long time. Then one mechanic replaced it with a Qabli one but it didn't work for a week even! Then my mechanic replaced it with some Toyota one & it was working fine till yesterday. I am fed up as it's a serious issue when suddenly you're stranded In the middle of nowhere. I called sohail autos and he said original brand new Daewoo pump is available for Rs 3800. Will that work?
  6. #7145
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by nakheb View Post
    Do you hear the humming from the pump when you put the ignition to "ON" or when the engine is started? When it fails, do you still hear the pump sound?
    If the pump stops or even run intermittent, check the fuel pump relay for any malfunction or the soldering part of wires attached beneath the fuel pump housing? If the relay is faulty(no voltage at pump connector), replace it with another one. If the soldering is bad, get the wires re-soldered by a radiator repair guy for a good quality joint.
    If the pump is bad, I recommend that you should purchase as brand new Bosch (~Rs.2200) or ND(~Rs.2700) pump (motor only) and also keep a spare fuel pump + timing belt in your car. The fuel pump life, depending on condition, varies for 3-5 years provided they must not run empty. Secondly, get the fuel lines and filter checked for any blockage as well as the fuel tank breather pipe.
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
  7. #7146
    nakheb's Avatar
    Dec 2004
    Rawalpindi
    35
    95
    2 Post(s)
    Thx! It turns out that it was never the fuel pump! But good info about having spare pump in car where can I get bosch or ND motor and will it fit in any pump as my Daewoo's pump is of Toyota? Also I see you have not mentioned brand new fuel pump is it not good enough? Anyways my mechanic checked the plugs and replaced them saying that fuel is getting "OVER" & it started instantly but why it happened is the issue... When I depress the accelerator in neutral engine is fine no issue in high rpm but when I am depressing it in any gear the car suddenly stalls feels like no fuel supply & just now coming to is isb I kept the pedal depressed and saw black smoke in rear view mirror. This has never happened before. I had to drive slow max at 60 because pressing it more just stalled the car.
  8. #7147
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    I found the new one costly as it is not Korean but Chinese made and secondly it looses its efficiency after an year. The second problem you mentioned (black smoke/stalling) seems to be due to Map sensor, either it is faulty or the vacuum pipe leading to the sensor is leaky. At idle, the engine runs without any load and hence the problem vanishes.
    Adnan's
  9. #7148
    nakheb's Avatar
    Dec 2004
    Rawalpindi
    35
    95
    2 Post(s)
    Thx again as u've always been very helpful. Finally The problem has been rued out! It was the fuel pump all along after all. Pls let me know where to get genuine new bosch or ND fuel pump motor in RWP? Sohail Autos told me he has Japanese motor for Rs 3300 but he doesn't know which brand...he claims the Rs 3800 pump is genuine Korean...
  10. #7149
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Thanks.
    You can go to Sohail Autos and inspect the motor, but probably that could be a ND one. Also get the fuel lines, breather pipe and fuel filter checked for any problem so that the fuel pump can run freely.
    Adnan's
  11. #7150
    khanz90's Avatar
    May 2009
    Wah cantt
    26
    15
    [COLOR=rgba(0, 0, 0, 0.701961)]Aslam o alikum to all .hope your fine. Me and my friends had trio of racers and da pair of cieloz few years back so i would like to share how was my experince having this car.
    we sold all of them just one friend stil got one and he had few years earlier then us and he had travled from wah cantt to karachi on this car twice with his family and he told that his carz timming belt got broken somwhere on the way and he replaced it himself as he had toolz for it in his car and a spare timming belt as he knew that it can break anytime.
    We had very bad expeirience with this car intialy when we bought except that guy.
    but later we found daewoo mechenics in islamabad and rwp then got peice of mind but stil finnaly and fully we got piece of mind after selling these cars.
    i would like to share with you folks honestly without any fanboyism why we fency this car and why dislike
    first of all we liked this car because of its powerfull engine even on ac it climbs the hills like tiger
    secondly we got to know that it was really cheap price car.obviously you wont get this much powerfull and comfortable car in price tag of 200k to 300 k.
    3. its low cost maintence ( keeping in mind that parts life is longer and proven stronger as compare to similar valued available carz for example mehran khyber and charade ( We used to drive this car very aggresively ,braking hard shifting gears too late and loading whatever we could load on it) However that would be obvious because of its class is higher then that cars but i am taking into account only cars value.
    now i am comming why we disliked this car and sold all of them 3 racers and couple of cieloz
    1 because of mechnics and parts availability only in rwp and isb or taxila and rest of pakistan you wont find anything or somwhere in lahore and peshawar as mentioned by @ testdriver bro.
    we had problems with its starter motor and that took so long to fix.
    [/COLOR][COLOR=rgba(0, 0, 0, 0.701961)]Later we faced horrible trouble on starting on petrol for first time. It gave black smoke clouds on back but we found that it was like uncontrolable roaring lion ( It was good luck for us that engine transmission clutch and pressure plate shocks cv joints etc was in imaculate condition when we got that one car) And drunk petrol like thirsty camel in desert. We had to keep a cane full of petrol with us just we were goin to pindi and comming back and from wah cantt to rwp kachehri chowk and than back to motorway chowk and car went off suddenly ,after checking evrything wires and fuse whetevr we knew about it and then we had to toe the car with a taxi and thanks to that taxi saved us some money took 500 from us for towing the car as he thought we are in trouble and he can charge as much he wants but he didnt know that we spent almost 3500rs on fuel just goin to pindi and then back . But now we are more then half mechencic
    Well now comming back to the point
    2 nd reason was its cheap material made interior and its design.specialy look at its dashboard. Its fine for smooth roads like motorway but it makes such bad sound on bumby roads and on top of that once it need to detache it parts for some kind of reparing like some ac heater speedo meter work and it wont sit back properly and high chances of breaking its hooks and screw places. Only cielo door panels looks good but stil you have to stick with same dash or some litlle changing in other dashboard but no changes in its material. Its interior proven very sensitive.
    so its interior is bad not in just looks but bad as well in terms of recycling or repairing.it could have been alike 88 corrolas or 92 sunny ,lancer .
    3. exterior design is outdated and from first look anybody ( who even dont know about cars) can tell the car isdecades old. But cars body is robust. Anyways if car converted into cielo or lemans shape then Scenerio is diffrent and shape looks great and up to date.
    I had to look for daewoo again just because one of my known person bought this and needed my help so i was googling to look once again somthing about this car and found this forum. I would like your opinion and if agree or disagree with my point of view. Specialy from thread starter @ testdriver bro.
    [/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)]I would sumup and giving my virdict about car that its very good luxury and economical Low price car for one who need to go on long routes and lives in or sorroundings of islamabad and dont care about resale value then daewoo is best option.
    But i would strictly recommend you take your car to only daewoo mechenic for maintenance although you can go to ordinary mechenic for doin hissa work like cv joints, brakes , bearings .
    [/COLOR]
  12. #7151
    xonuhappy's Avatar
    Mar 2015
    29
    "testdrive" I have daewoor racer, not satisfied, too much expensive work, expensive parts, no clue what to do, even not mechanics can work properly. Now i am facing its gear issue, while driving 3rd gear and 4th gear automatically shift down to neutral. a person in saddar mithu khan basement market ask approx 4K, 5k for other replacement only gear box and labor cost is not included. Can any experienced person guide me how can i get it fixed or repaired in least cost, if yes then kindly share place and address. Already spend a lot on it's maintenance... :-(
  13. #7152
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by khanz90 View Post
    [/COLOR]
    [/COLOR]
    In today's era, where the number of EFi cars has vastly increased, on top of that the number of imported cars, you cannot find each and everything in every small city. Now mechanics started knowing about EFi technology and they can diagnose some problems. The only problematic part is the sensors that vary from manufacturer to manufacturer. For Daewoo car owners, the good news is that you can order any faulty part from the Korea Autos Lahore through any online transfer and they courier the part to you, they are good at it.
    As for interior, you are right that it is from 80's era and the plastic items are very fragile and there are no other options than going for some other car's interior like I have seen daewoo cars with toyota and honda dashboards and door cards, since the Cielo dashboard is same style with grey color. Regarding the resale, if you purchase a well kept daewoo racer for 3.5Lac and after sometime you want to sale it in well kept condition, it will not drop its value but it might be take a while to sell.
    Adnan's
  14. #7153
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by xonuhappy View Post
    Where do you take your car for repairs/maintenance? The reliability of repairs greatly depends on the skills of mechanic and the quality of parts. Also those parts that are in pairs should be replaced on the same time since if one part has worn out, the second one is also on brink of wearing out, this will save labor cost.
    As for the gear problem, 4-5K is an excellent quote keeping in view the current situation of kabli part. They usually comes with check warranty for a day or so, but you will have to give labor to your mechanic for each time you are mounting/detaching the gear. It is better that you take along your mechanic to check if the gear you are purchasing is problem free to save on labor cost. If you are going for something like "Least Cost", there are many "Jugaaro" mechanics who can help you in this regard to settle the problem for some time, but it is for sure the problem will re-appear after some time, and is not recommended at all.
    Adnan's
  15. #7154
    nasirtariq's Avatar
    Aug 2007
    Rawalpindi
    30
    32
    New IAC Valve available at a good price. I have 5 pieces with me and can order more from overseas. I am using one in my own Daewoo for about 2 months now without any issues. I ordered the extra pieces to help out any other Daewoo fan with fair price then the rip offs in the market. If anyone is interested or need a new IAC Valve then contact me. My number is 03455114470 (Nasir). Price is Rs.1450 per IAC Valve. Thanks.
  16. #7155
    Kamando's Avatar
    Dec 2009
    127
    7 Post(s)
    Texted u ...reserve one for me ...
  17. #7156
    fslrao's Avatar
    Aug 2011
    Kharian
    99
    Quote Originally Posted by nasirtariq View Post
    Dear pls keep one for me ,can I transfer the amount to your account.
  18. #7157
    nasirtariq's Avatar
    Aug 2007
    Rawalpindi
    30
    32
    I will reserve the pieces for the requests for a week. If you are in Rawalpindi/Islamabad. You can contact me from 1: 00pm - 10: 00pm through sms or call to discuss location for pickup and payment. If you are in other city then contact me to select best method of delivery. Payment will have to be in advance along with extra charges for shipping vis post or TCS will be add to the price if any.
    I will be searching for other parts as well and if i find any that have reasonable price than market then i will share here. Or if you want a specific part then let me know via sms and i will see if it is available and is of good quality and good price to be ordered.
    Thanks
  19. #7158
    zeeshan213's Avatar
    May 2008
    31
    222
    2 Post(s)
    Dear test Driver......during clutch plate set changing mechanic found a too much movement in Crank......he placed a Main Seal with Epoxy glue.....but reaching home from islamabad to wah found about 1 litre mobil oil on floor from Main seal......mechanic said Crank should be repaired.......need ur expert sugestions...thanx..
  20. #7159
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by zeeshan213 View Post
    If the crank has play in it, the thrust bearing has worn out and the best way to sort this issue is lower end overhaul that includes new main and big end bearings along with crank tooling
    Adnan's
  21. #7160
    Kamando's Avatar
    Dec 2009
    127
    7 Post(s)
    got 1 piece not tested yet ....
    thanks any way it was about a year i was looking for a new iac valve
    any luck in finding new heater core ?
