Page 46 of 370 FirstFirst ... 3644454647485696146 ... LastLast
Results 901 to 920 of 7393
Like Tree425Likes
Thread: Daewoo fan club
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Daewoo Racer/Cielo Fan Club
    Dear All,
    I am an owner of Daewoo Racer since 1995. It has proven to be a very comfortable and economical car throughout this period. It used to give an average of 13Km/L within city and ~15Km/L on long drives. Here are some pictures:
    Daewoo fan club -479355
    Daewoo fan club -479356
    Daewoo fan club -1050638
    Check the links for my rides
    1. Before 2008 (Racer)
    Daewoo Racer
    2. After Jan 2008 (Cielo)
    Daewoo Cielo
    I would recommend buying this car who want a better car at low budgets!
    Any member having used a Daewoo car must share their experience....(y)
    IMPORTANT: SCANNER Facility is Available at Friends Autos, I-9, Islamabad. [Khalid: 0322-5111110, 0321-9562840]
    Quick Links:
    Parts Dealers/workshops link [Page-3 post #:54]:
    Alloy Rim fitment [Page-15 post #:290]:
    The DOHC engine[Page-30 post #:585]:
    Service Manual/Electrical Diagrams link[Page-30 post #:594]:
    Cielo Conversion [Page-57 post #:1130]:
    How to get Black Bumpers [Page-60 post #:1315]:
    Reading ECM Error Codes [Page-191 post #:3804]:
    Air Conditioner maintenance shops [Page-195 post #:3897]:
    High RPM/Stalling Problem on AC, OK Otherwise[Page-203 post #:4048]:
  2. #901
    shadowrider's Avatar
    Feb 2009
    26
    71
    n just after stating the car.....a high pitch noise is produced....sum sau dat some "belt" in the engine is loose....wat shud i do wid dat???
  3. #902
    Feb 2009
    26
    71
    n thanxx mayford....
  4. #903
    mayford's Avatar
    Mar 2009
    caloocan
    35
    37
    @ shadowrider
    i think that high pitch noise is just a loose belt.
    if the noise stops after a while, then it must be the belt.
    try 2 adjust all belts then start it again, if it still make sounds
    replace them w/ new ones. im not an expert but i had already encountered that problem on my racer, and just solved them by replacing belts on aircon and alternators/generator.
    bro! wait also for testdriver's suggestions.
  5. #904
    saadshaukat's Avatar
    Apr 2006
    Taxila
    33
    72
    @shan
    welcome back dude
    I have few questions for Daewoo gurus, dudes I am sick/hopless of these problems with my daewoo racer(1,44,xxx kms done rings put in and thinking abt to throw the engine for twin-cam 16v), anyways:
    1. the brake discs need regular tooling (discs surface tooled by khradiya...i 've got it done 2+ times), if I dont get the tooling done, whenever u depress the paddle above 80km/hr it feels as if car has ABS brakes, the steering shakes alongwith badly....Faqeer Mohmd @ Daewoo Pt says "it happens when hot discs touch water and metal is defaced"....do u ppl(da experts) face this issue...?,please advice a solution.. /li
    2. and the damn squeaky-songs of alternator greet you when start the engine and creates such a ruckus that you feel ashamed....mechanic tells "its due to pulleys/belt being dry...so keep spraying WD-40 periodically"..i dont believe this, it due to alternator which is not the daewoo's original asit was smoked/fried.....but i have heard these 'raags'(sounds) from other woos that have a geniune /li
    3. and the gear shift lever feels too hard as if shifted without the clutch being depressed/li
    4. coolant mysteriously disappers within two weeks no visible leaks, pipes checked, head gasket ok tell me solution except changing the radiater as i know it wont leak a pint/li
    awaiting a thorough reply
  6. #905
    kashmir1's Avatar
    Oct 2005
    41
    79
    @shadowrider
    let me share with you my experience of tooling of discs by kharadia. my previous car had some brake problem. i was advised same. and believe me the brakes never ever returned to normal again. i discussed this thing recently with central motors person(as i was advised this again for my daewoo. and i was reluctant) he said that there is special machine for tooling the discs- available in gualmandi only- that grinds the both surfaces eqally. ordinary kharad machines cannot achieve this. i tend to agree with him. (how ever i have no planes for my daewoo)
    water disappearance was also a problem for me. mech. told me that it gaskit problem- the initial stage. so i had it checked and there was problem. so had it changed. now its in follow up period. not in a position to confirm if my problem is solved or not.
    regards
  7. #906
    Feb 2009
    26
    71
    hm...........@kashmir
    bro my prob is nt the brake discs.......mine is dat the car is nt getng its top speed......just reachng around 130-40.....
  8. #907
    asad_scorpio21's Avatar
    Mar 2007
    Rawalpindi
    38
    4,537
    shadowrider
    i touched 170 on CNG on motorway easily, i have sealed engine in my 93 daewoo , wat about ur engine condition, is it still sealed and geniune or reconditioned, coz 150-160 speed for Daewoo on CNG is not a problem.
  9. #908
    Apr 2006
    Taxila
    33
    72
    @shadowrider
    1. I guess you didnt like what Mr.Shaan told, you are asking the same questions again....Visit a good mechanic and your car will be good.....and PLEASE DRIVE SAFELY always with seat belts,?*
    @kashmir1
    1. I think you replied to my questions....thankyou for sharing your opinion. About getting them tooled requires a precise machine maybe there is one in G-10/4 because he takes two good hours of your time.?*
    2. I resolved the DISCs issue by getting the Brand New Discs Set for 3600Rs0..as life is precious and I am a real rash-driver.... and I for careful inspection brought old discs home and boy they are exhausted.
  10. #909
    kashmir1's Avatar
    Oct 2005
    41
    79
    @ shadowrider and saadshaukat
    my bad. new pakwheels format will need little bit of getting used to. and agreed about no compromise on tyres and brakes.
  11. #910
    Javaid35's Avatar
    May 2007
    Rawalpindi
    44
    54
    salam all woo lovers
    h r u all??
    i m already using a daewoo racer 1993
    recently i have sold the car n wanna buy a new one
    i m looking for a well maintained officers scheme daewoo in original condition with no modifications. any one has such daewoo with isb or rwp number can plz contact me. 03335693266
    any one has in khi re also welcome.
  12. #911
    Javaid35's Avatar
    May 2007
    Rawalpindi
    44
    54
    salam guyzz
    i have few questions regarding daewoo stock engine
    1. how the hydraulics (tapets) are serviced while overhauling the engine??
    2. if the bore was on standard but has deeper pits when pistons are taken out then does then increasing the size of bore should be preferred or placing a new entire sleve is workable??
    3. wats the price of following engine items:-
    a. genuine ring set
    b. genuine piston set
    c. main baigons
    d. valve set
    4. thanx in advance all woo lovers
  13. #912
    asad1019's Avatar
    Aug 2008
    38
    34
    Daewoo fan club -936032
    Daewoo fan club -936033
    Daewoo fan club -936034
    Daewoo fan club -936035
    Daewoo fan club -936036
    Hi All,
    Here is my woo cielo more pic would be uploaded soon
  14. #913
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    @kashmir1
    Doctor sahab how is your car's engine working?
    @javaid35
    A: The head will be opened and hydraulic lifters will be removed. If they are in good shape, just washing with petrol will be sufficient. If they are worn-out, they needs to be replaced.
    A: Sleeves are not recommended in the long run, better get it bored. If possible make
    it
    bored according to 1.6 Specs(increase bore from 76.5mm to 79mm) and put Optra's rings and pistons)
    a. genuine ring set
    c. main baigons
    d. valve set
    A: Please refer to https://www.pakwheels.com/forumreply_az_TopicID!24322~ForumID!28~page!3~pw.h tml for contacts.
    @asad1019
    (y) looking nice!
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
  15. #914
    Feb 2009
    26
    71
    salam.....hw r u brozz???my problemzz r solved.....thanx to u guyzz....thank u vry much.......i wantd to ask abt the milage of 1.5 DOHC on cng????once i calculated on my car....275 kmzz in almst 1100 rs.....meanzz almst 4rs per km.....is it normal on highway....i went to lhr....n den came bck.....n spent 1100 on cng....
  16. #915
    Feb 2009
    26
    71
    @asad
    bro i hav d same car ind same colr......r d door sidingzz available in d market???n wat abt d window switchezz???
  17. #916
    Javaid35's Avatar
    May 2007
    Rawalpindi
    44
    54
    @testdriver
    thnx bro for ur valueable suggestions
  18. #917
    asad1019's Avatar
    Aug 2008
    38
    34
    @testdriver
    Thanks
    @shadowrider
    Dear Every thing is available, i installed original Cielo Door along with whole wiring of cielo.
  19. #918
    kashmir1's Avatar
    Oct 2005
    41
    79
    @testdriverB-)
    guru gee. engine going good. but still got problem with water level. had it checked. they think is radiator. some minor leakage. cannot be detected as yet. so employing wait and see policy. and of course carring bottle of water policy too. yesterday had the AC checked. replaced low pressure switch and filled gas. working fine. but then Allah has also opened is vent too.
    regards
  20. #919
    Feb 2009
    26
    71
    @ asad...
    bro wud u tell me abt the pricezz????wat did it cost wen u changed????
  21. #920
    Feb 2009
    26
    71
    Daewoo fan club -936187
    Daewoo fan club -936188
    Daewoo fan club -936189
    Daewoo fan club -936190
    Daewoo fan club -936191
