Page 72 of 370 FirstFirst ... 2262707172737482122172 ... LastLast
Results 1,421 to 1,440 of 7394
Like Tree425Likes
Thread: Daewoo fan club
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Daewoo Racer/Cielo Fan Club
    Dear All,
    I am an owner of Daewoo Racer since 1995. It has proven to be a very comfortable and economical car throughout this period. It used to give an average of 13Km/L within city and ~15Km/L on long drives. Here are some pictures:
    Daewoo fan club -479355
    Daewoo fan club -479356
    Daewoo fan club -1050638
    Check the links for my rides
    1. Before 2008 (Racer)
    Daewoo Racer
    2. After Jan 2008 (Cielo)
    Daewoo Cielo
    I would recommend buying this car who want a better car at low budgets!
    Any member having used a Daewoo car must share their experience....(y)
    IMPORTANT: SCANNER Facility is Available at Friends Autos, I-9, Islamabad. [Khalid: 0322-5111110, 0321-9562840]
    Quick Links:
    Parts Dealers/workshops link [Page-3 post #:54]:
    Alloy Rim fitment [Page-15 post #:290]:
    The DOHC engine[Page-30 post #:585]:
    Service Manual/Electrical Diagrams link[Page-30 post #:594]:
    Cielo Conversion [Page-57 post #:1130]:
    How to get Black Bumpers [Page-60 post #:1315]:
    Reading ECM Error Codes [Page-191 post #:3804]:
    Air Conditioner maintenance shops [Page-195 post #:3897]:
    High RPM/Stalling Problem on AC, OK Otherwise[Page-203 post #:4048]:
  2. #1421
    asquare25's Avatar
    Dec 2008
    31
    46
    Salam!!!
    Anyone knows how to start woo in this rainy situation??? I have tried by giving 30 - 40 selfs but didn't started and the battery is going down although the battery is new it is slowing things down that's why I stopped starting it.
    it's not important that you have a ride, important is how you drive it...
  3. #1422
    asad_scorpio21's Avatar
    Mar 2007
    Rawalpindi
    38
    4,537
    @asquare25
    Bro check ur generator , may be rain water touched ur generator and generator was weak,
  4. #1423
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by asquare25
    Salam!!! Anyone knows how to start woo in this rainy situation??? I have tried by giving 30 - 40 selfs but didn't started and the battery is going down although the battery is new it is slowing things down that's why I stopped starting it.
    Seems like electric issue. Check the following:
    NOTE: Before replacing check if water has entered in the identified faulty areas, DRY them first and give them another try. If it start working, then fine otherwise replace
    1. Remove the main coil wire (the wire coming from Main coil to distributor) and try starting the engine. If no spark is generated from coil, it could be due to following reasons:
    a. The main coil current wires have some problem, tighten the harness in place and try again
    b. the 'Module' has become faulty. Check if the wiring harnesses are properly inserted into the distributor. If the problem still exist, 'Module' alongwith the pickup coil needs to be dried/replaced (Module costs around Rs.1200 kabli and pickup coil around Rs.800 New)
    2. If step-1 went OK, put back the main coil wire and now remove the spark plug wires individually, insert a screwdriver in it and place it close to engine's earth (DO NOT MAKE IT TOUCH ENGINE GROUND). Now crank the engine again to see any spark being generated. Using the same technique for all the four plug wires. Check the following:
    a. If spark is present in atleast one wire, the other wires have been short circuited.
    b. If spark is not there, following are possible reasons:
    i) The main coil distributor wire is faulty. Complete plug-wire set will cost around Rs.950 (New)
    ii) The 'Router' is faulty and costs around Rs.500 (New)
    iii) The Distributor Cap is faulty. Distributor cap costs around Rs.650 (New)
    The worst cases has been described above but the problem could even be a disconnected wire.
    If the above 2 steps went well and there is no electric issue at all, the exhaust needs to be inspected if water has been filled in. In that case try pushing your car towards slope so that water can evacuate from exhaust.
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
  5. #1424
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by zeeshan213
    hello , daewoo ka front bumper kaha say milay ga r kia price hay us ki.squar shape wala jo kay yaha par ik white daewoo main laga hua hay.thanx.waiting 4 replies
    Contact Federal Auto I-10 051-4443594 for bumpers.
    Adnan's
  6. #1425
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by nauman
    i need these crome gola's recromed or new if any one know please help
    You can find these chrome mouldings from any Car Decoration Shop.
    Adnan's
  7. #1426
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    @sahhil_22
    ......Too busy these days!
    @asad_scorpio
    You can find some conversion details HERE
    Adnan's
  8. #1427
    assadbukhari's Avatar
    Jun 2008
    Sargodha
    40
    33
    I NEED SOME HELP FROM YOU GUYS. I NEED MAIN HEAD LIGHT COVERS (BOTH LEFT AND RIGHT) AND BACK LIGHT COVERS (BOTH LEFT AND RIGHT) FOR MY DAEWOO CEILO. CAN ANYONE HELP ME FROM WHERE I CAN BUY THEM. I DO NOT NEED WHOLE LIGHT ASSEMBLIES JUST COVERS.
  9. #1428
    Mar 2007
    Rawalpindi
    38
    4,537
    @testdriver
    thanks for detailed replies to all queries,
    @assadbukhari
    u live in sargodha, in rwp/isb lot of shops for daewoo new and old parts.
    Thanks
    S.Asad Bukhari
  10. #1429
    atif11's Avatar
    May 2006
    28
    781
    2 Post(s)
    ASSALAM-O-ALAIKUM
    i have a daewoo racer 97.
    i m suffering from some problems and need every one to suggest specialy test driver.
    1. front left shock absorber is not working and while braking from speed of 80km/h it give jerks very badly . Mr.Ather at central autos told me to change both front shocks and it will resolve the problem . what did u say?
    2. while going at the speed of 50km/h or above it sounds very badly at gives vibrations when holding steering from top and gradual strong vibrations at pedals and the sound is like GHuuuuuuuuuuunnnnnnn and after driving for 10 mins it gives me headache. i think it is some kind of piston problem or tapids. or may b because of alignment. what r ur opinions?
    3. front right axile is to b replaced how much it cost. central autos is giving it for 3800 with lobour new one and from cha sultan 2000 without labour kabli one.
    and shocks at central autos costs 4200 with labour new and at cha sultan he changing kits for 1500 .dont know what kit may b da gaskits for air tightning inside da shocks. what should i go for?
    4. and one wierd problem every month it needs gas adjustment for missing , sulf and consumption problems.
    how this can b permanently solved.
    waiting for ur replies.
    Dream is not what you see while you sleep , it is what that don't let u sleep .
  11. #1430
    Jun 2008
    Sargodha
    40
    33
    KINDLY TELL ME ANY SHOP IN PINDI OR ISB. I LL COLLECT THEM
  12. #1431
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    Asad Scrpio21: I have seen the pics of ur ride, very nice.
    want to know the followings:
    1. your meter has different colour (back colour). Did u changed the plates or? how much it cost you.
  13. #1432
    Mar 2007
    Rawalpindi
    38
    4,537
    @shah73
    thanks , bro i didnt installed that green color lighty dial myself , its already installed by previous owner of my ride. you can get it from any car decoration shop , its like a plastic paper as u seen commonly on different rides on their windscreen near back mirror , wording like
    MASHALLA , ALLAH O AKBAR, BISMILLAH etc, it can easily adjust on your orginal meter dial.
    S.Asad
  14. #1433
    Mar 2007
    Rawalpindi
    38
    4,537
    @shah73
    S.Asad
  15. #1434
    Mar 2007
    Rawalpindi
    38
    4,537
    @shah73
    S.Asad
  16. #1435
    Mar 2007
    Rawalpindi
    38
    4,537
    Daewoo fan club -988357
    Daewoo fan club -988358
  17. #1436
    asquare25's Avatar
    Dec 2008
    31
    46
    @testdriver
    Thanks for the reply ... but it was started the very next morning without doing anything ... started on the first self ... may be it was the bad day for me to go out ... earlier that morning my bike didn't respond and later my woo did the same ... but the next day it was started like nothing happened and the bike also ... I was shocked as it never happened before my bike is half self start and woo takes 2 - 3 selfs but then thought may be it was from ALLAH SIGN not to go out in that rain.
    Well All thanks to ALLAH and you guys.
  18. #1437
    baryar's Avatar
    Mar 2006
    33
    1,186
    @asquare25
    tumharee car pe jin ka saya hai
    you better contact some JINBABA / Peer sb rather than Mechanic
    the baryar
  19. #1438
    welcome786's Avatar
    Jan 2008
    39
    378
    5 Post(s)
    @ baryar
    @ asquare
    yaar aisa jin ya saya to har kisi ki gari par rahe
    bye the way good luck ke start nahi hoi warna barish main logon ke sath kiya howa,
    MONEY IS YOURS BUT RESOURCES BELONG TO THE
    SOCIETY
  20. #1439
    nauman's Avatar
    Feb 2004
    35
    811
    14 Post(s)
    @testdriver
    bro u own certral autos?
    as i saw your car 3 times last week park over there so i was just curious to ask about it,
    @all my daewoo is atlast in workshop.buyed parts
    fingers crossed..letsc what would be the result.
  21. #1440
    nauman's Avatar
    Feb 2004
    35
    811
    14 Post(s)
    @testdriver
    any suggestions bro?
