Page 78 of 370 FirstFirst ... 2868767778798088128178 ... LastLast
Results 1,541 to 1,560 of 7393
Like Tree425Likes
Thread: Daewoo fan club
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Daewoo Racer/Cielo Fan Club
    Dear All,
    I am an owner of Daewoo Racer since 1995. It has proven to be a very comfortable and economical car throughout this period. It used to give an average of 13Km/L within city and ~15Km/L on long drives. Here are some pictures:
    Daewoo fan club -479355
    Daewoo fan club -479356
    Daewoo fan club -1050638
    Check the links for my rides
    1. Before 2008 (Racer)
    Daewoo Racer
    2. After Jan 2008 (Cielo)
    Daewoo Cielo
    I would recommend buying this car who want a better car at low budgets!
    Any member having used a Daewoo car must share their experience....(y)
    IMPORTANT: SCANNER Facility is Available at Friends Autos, I-9, Islamabad. [Khalid: 0322-5111110, 0321-9562840]
    Quick Links:
    Parts Dealers/workshops link [Page-3 post #:54]:
    Alloy Rim fitment [Page-15 post #:290]:
    The DOHC engine[Page-30 post #:585]:
    Service Manual/Electrical Diagrams link[Page-30 post #:594]:
    Cielo Conversion [Page-57 post #:1130]:
    How to get Black Bumpers [Page-60 post #:1315]:
    Reading ECM Error Codes [Page-191 post #:3804]:
    Air Conditioner maintenance shops [Page-195 post #:3897]:
    High RPM/Stalling Problem on AC, OK Otherwise[Page-203 post #:4048]:
  2. #1541
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    @asad_scorpio
    Thermostat valve helps engine to quickly attain the optimum working temperature during cold starts. That is after cold starts, this valve restricts the flow of water inside the engine that makes it quickly attain the optimum temperature.
    In winters, the valve will obviously open late since engine will need more time to attain certain temperature while in summer, the valve will open quick. Although removal in summer wont harm the engine that much, usually mechanics remove it, which in any case is not good for the engine.
    Regarding the fan speed, it seems that the mechanic has either introduced a relay for the fan, or just bypassed the in-built resistance that allow the fan to revolve in 2 stages- low speed and high speed. Better remove any alterations made to the fan and use only desired fuse location somewhere near to battery, if required.
    Before turning the automatic mode 'ON', get the Coolant Temperature Sensor analysed for any problem and replace if necessary.
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
  3. #1542
    asad_scorpio21's Avatar
    Mar 2007
    Rawalpindi
    38
    4,537
    @testdriver
    thanks for ur detailed reply, u r right , in summer mechanic installed relay which gave extra ordinary speed for rediator fan, now there is no need it so i have to remove alteration in winter, i remember last year in winter fan was automatic but there was some problem in Coolant Temperature Sonsor which didnt give order to turn on the fan in time, in long run there was not problem but in city its boils the water so i convereted to fan direct. Now first i wlll check Coolant Temperature Sensor than will convert its fan director to automatic.
    Asad Shah
  4. #1543
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    @Testdriver:
    I am facing petrol consumption problem again after recent engine tune up. i filled 10 L petrol in empty tank and it lasted for only 60Km within city. Distance covered was a mix up of AC and non AC.
    Engine is not much advanced on CNG. Advise me, whould could be the fault because every ,mechanic has its own reasons particularly in Lahore. They really make other madddddddddddddd.
    While on 8Kg CNG, it covers 100KM approx (while in peak summer, it was 80-90 Km only) with full time AC within city. is it improved due to low environment temperature?
    Waiting for for your response.
    Thanks
  5. #1544
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    @Shah73
    1. Does your car emit black smoke on petrol?
    Ans: If yes, it could be either faulty Coolant Temperature Sensor or CO maladjustment (CO value should be 3.3V on a CNG tuned engine and 3.8V on a Petrol Tuned Engine).
    2. Is there any missing on idle with black smoke?
    Ans: If yes, either MAP sensor vacuum pipe is broken or MAP itself is faulty.
    100Km/8Kg is just fine for city driving. In summers, the CNG filling temperature considerably rise and as a less amount of CNG can be filled in, resulting in less mileage.
    Adnan's
  6. #1545
    mostwanted_legend's Avatar
    Apr 2009
    Rawalpindi
    31
    61
    @ testdriver
    bro, i m facing a serious problem of engine oil consumption from the past 2-3 months with my racer, it consums about 2 litters in 20-25 days and oil pressure light starts to blink, and no white smoke from exhaust, saw some smoke once or twice in these days, i am really confused for this,
    do help me out of this fast bro.
    waiting
    Life is too short and unpredictible, just like a quarter mile drag race!!!
  7. #1546
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    @mostwanted
    1. Are there any engine heat-ups?
    Ans: Most probably the gasket is expired, check the coolant/water for presence of any oil traces. Usually oily bubbles are present in the water/coolant when oil get mixes with it.
    2. Is there any visible oil leakage?
    Ans: Better lift up your car at service station and check for any oil stains underneath the engine/engine bay. The amount of oil consumed shows that probably either the oil filter seat is not uniform causing the oil to leak while engine is running or the cam cover seal is faulty.
    3. Is there any black oily deposit on the tail pipe?
    Ans: If yes, piston rings are worn-out and needs replacement.
    Adnan's
  8. #1547
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    @Testdriver: Thanks for your detailed reply. Mechanic has checked CO adjustmnent acording to your defined specefication.
    He is not aware about MAP sensor vacuum pype (they may call it with diff name). Can you pl tell me its location in a picture.
    Thanks again.
  9. #1548
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    Yes u r right, silencer was black. means dry Kalack (not oily)
    Thanks again.
  10. #1549
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    Thanks again.
  11. #1550
    Apr 2009
    Rawalpindi
    31
    61
    @testdriver
    thanks for reply bro, well there is nothing on the exhaust tail pipe, i havent lift it up yet for visual inspection of leakage but i will, confusing thing is where i park my car outside my home, i didnt saw any oil drops on the road aswell. and there is no issue of heatups.
    wainting for reply
  12. #1551
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by Shah73
    @Testdriver: Thanks for your detailed reply. Mechanic has checked CO adjustmnent acording to your defined specefication. Yes u r right, silencer was black. means dry Kalack (not oily) He is not aware about MAP sensor vacuum pype (they may call it with diff name). Can you pl tell me its location in a picture. Thanks again.
    Daewoo fan club -1005605
    Adnan's
  13. #1552
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by mostwanted_legend
    @testdriver
    wainting for reply
    Better start the engine and keep it started for atleast 5 minutes at the parking, to check for any leakage.
    Adnan's
  14. #1553
    Apr 2009
    Rawalpindi
    31
    61
    @testdriver
    thanks for reply, bro whenever i prepare to leave for office in the morning i keep my car start for least 5 to 10 mins, have done the same check, after moving the car from the parking spot idling for that time, no signs of leaked oil on the floor. do help me out of this man !!!
    regards
  15. #1554
    iagr8's Avatar
    Jul 2008
    Rawalpindi
    41
    175
    2 Post(s)
    Salam Bros. I m also a very big fan of Daewoo Cars. I m enclosing some pics of my ride. I owned this since last six months. I never got a daewoo before this one. I love its ride, comfort and speed. I traveled many cities, like Lahore, Peshawar, Mianwali, Kharian, Gujranwala in this car and never faced any problem Alhamdulillah. B-)
    Daewoo fan club -1007393
    Daewoo fan club -1007394
    Daewoo fan club -1007395
    Daewoo fan club -1007396
    Daewoo fan club -1007397
    .. Dont Walk ..
  16. #1555
    Apr 2009
    Rawalpindi
    31
    61
    iagr8
    nice ride mashallah, bro i m also looking for a digital meter for my racer, kindly guide me to the place and some expert technician to install it well.
    waiting for reply,
  17. #1556
    iagr8's Avatar
    Jul 2008
    Rawalpindi
    41
    175
    2 Post(s)
    @mostwanted
    I got it from Mr Khair Mohammad Ahata Mithu Khan. He imported the same from Dubai thru his brother. It will cost u round about 8 - 10K depending upon the condition of the meter. Mr Akhtar Alam is the right person for its installation. My meter was also installed by Mr Akhtar. His cell No. is 0333-5509919. His workshop is near Kohinoor Mills, Rawalpindi.
    .. Dont Walk ..
  18. #1557
    Mar 2007
    Rawalpindi
    38
    4,537
    @iagr8
    nice ride, digital meter looking cool,
  19. #1558
    iagr8's Avatar
    Jul 2008
    Rawalpindi
    41
    175
    2 Post(s)
    @asad
    thanx bro. I searched for this for almost 2 months then i got this beauty.
    .. Dont Walk ..
  20. #1559
    mayford's Avatar
    Mar 2009
    caloocan
    35
    37
    @iagr8
    nice ride bro! i like your digital meter. does all the indicators on that panel are working just like the stock panels?
  21. #1560
    iagr8's Avatar
    Jul 2008
    Rawalpindi
    41
    175
    2 Post(s)
    @mayford
    Thank u bro. Everything of the meter is working perfectly. All indicators are accurate. Once i checked this meter by racing with a city and found it accurate.
    .. Dont Walk ..
