Page 95 of 370 FirstFirst ... 45859394959697105145195 ... LastLast
Results 1,881 to 1,900 of 7393
Like Tree425Likes
Thread: Daewoo fan club
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Default Daewoo Racer/Cielo Fan Club
    Dear All,
    I am an owner of Daewoo Racer since 1995. It has proven to be a very comfortable and economical car throughout this period. It used to give an average of 13Km/L within city and ~15Km/L on long drives. Here are some pictures:
    Daewoo fan club -479355
    Daewoo fan club -479356
    Daewoo fan club -1050638
    Check the links for my rides
    1. Before 2008 (Racer)
    Daewoo Racer
    2. After Jan 2008 (Cielo)
    Daewoo Cielo
    I would recommend buying this car who want a better car at low budgets!
    Any member having used a Daewoo car must share their experience....(y)
    IMPORTANT: SCANNER Facility is Available at Friends Autos, I-9, Islamabad. [Khalid: 0322-5111110, 0321-9562840]
    Quick Links:
    Parts Dealers/workshops link [Page-3 post #:54]:
    Alloy Rim fitment [Page-15 post #:290]:
    The DOHC engine[Page-30 post #:585]:
    Service Manual/Electrical Diagrams link[Page-30 post #:594]:
    Cielo Conversion [Page-57 post #:1130]:
    How to get Black Bumpers [Page-60 post #:1315]:
    Reading ECM Error Codes [Page-191 post #:3804]:
    Air Conditioner maintenance shops [Page-195 post #:3897]:
    High RPM/Stalling Problem on AC, OK Otherwise[Page-203 post #:4048]:
  2. #1881
    Newbie Follow
    SODA's Avatar
    Jan 2010
    Rawalpindi
    13
    pls tel me some one good macin in rawalpindi i wont to changes rings
  3. #1882
    sahhil_22's Avatar
    Jun 2008
    Auburn
    722
    2 Post(s)
    Quote Originally Posted by SODA View Post
    visit mian khan at tipu road, opposite PSO petrol pump, near fauji towers....
    1962 Vespa (Project) - 1978 Vespa (Project)- 1995 Daewoo Racer (Project) - 2006 Toyota Yaris - 2003 Suzuki Cultus
  4. #1883
    Ishaq76's Avatar
    Feb 2010
    Peshawar
    39
    7
    U can ask for different body and spare parts of daewoo racer and ceilo from Hameed khan Peshawar
    0301-4782499
    currently he has Steering set, doors set, bonnet, dicky door bothe ceilo and racer, and he can arrange different items on demand
  5. #1884
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by assadbukhari View Post
    Test Driver
    I need your help on following issues
    (a) Want to install radio antenna. Which antenna is good and kindly tell me its location. My cielo is not installed with antenna.
    (b) Engine produces knocking sound. Previously installed CNG kit was removed and there is no hole in the air intake pipe. Kindly tell me how to reduce it. The pick up reduces while accelearting and engine knocks. Technicain told me timing is advanced. Kindly tell me how to fix it.
    (c) On start up the engine is very quite (no noise with open bonnet except tick tick i suspect tapet noise) but it can be heard inside the car. The boot installed on the steering rod is missing and not available here.
    (d) Chinese Brand new AC Compressor (507) costs about Rs 5500/- while kabli ceilo costs about 1800/-. Which one should I prefer?
    (e) While driving ECU lights comes on especially while accelerating after applying brakes and engine knocks. After restart it goes off. Uniform speed does not gove problem but acceleration after decelaration gives problem.
    (f) I bought engine sheet (to avoid engine from road dust) for Rs 1200/- from Lahore. Its in two pieces and dont know how to install it.
    (g) There is play in the gear lever. I installed new lever kit it improved but not eliminated. How can it be eliminated?
    Thanks in advance.
    Assad Abbas
    (a) The FF antenna comes on the rear left fender aligned along the boot area beneath carpet and boot light. I installed Toyota's power antenna as the kabli antenna's for Cielo are usually faulty.
    (b) As suggested by the mechanic, get the timing retard.
    (c) The tick tick sound comes from injectors. The cabin noise you are referring seems like problem with the gear lever rod touching any body/engine part(as you mentioned in (g))
    (d) Kabli compressor usually works for a season or two depending on the condition. Better go for a new one.(Japanese/Chinese)
    (e) Give a reset to the ECM by removing the negative terminal of battery for 10 minutes and then check again. If still the problem exist, get the VSS checked.
    (f) One sheet fits on the left side beneath gear box and one on the right side beneath engine.
    (g) The gear lever's central rubber ring might be worn out and need replacement.
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
  6. #1885
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by instructor View Post
    Salam to All fans of DAEWOO.
    I have been a silent visitor of this thread. THis thread is REALLY as wonderful as WOO itself aur testdriver to jan-e-mehfil hain. I also want to inquire about AC Compressor. I bought Racer two years back. The AC worked very well for two seasons. By the end of last summer, there was a little problem. Whenever I accelerate over 100KM/h, the compressor starts giving a continuous loud sound. Is something wrong with the compressor or there could be some other reason? If its the compressor, then what is the way out? Any repair or replacement? If replacement, then what are the options and pros and cons of these options?
    Welcome to DFC and thanks for compliments!
    Regarding your problem, it seems related to RPM than speed. The A/C clutch has lost it's grip and under stress (more cooling pressure/high RPMs), it tends to slip. Get the A/C clutch system checked by technician. It is an easy replace and will cost you around Rs.1500/=.
    Adnan's
  7. #1886
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Brother thanks a million for such a prompt reply.
    Its like loud Zooommmmm..........
    As far as cooling is concerned, sometimes, after giving good cooling for about an hour, the cooling goes off. I turn off AC and then turn on after some time and then cooling starts. This behavior of AC is not specific to speed. Sometimes, it gives good cooling even beyond 100kmph and sometimes it stops giving cooling.
    Also please advise me about the tyres. Which tyres arethe best. WHere to go for tyre change?
    Regards
    Regarding tyres, I am quite satisfied with Dunlop Lemans series.
    Adnan's
  8. #1887
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by Shah73 View Post
    Testdrive and all others:
    I had the bad experience of installing genuine daewoo AC compressor last year. as there was gas leakage twice and at the end of season compressor was obsolete. otherwise cooling was fine. It is also possible that shopkeeper did not give me good compressor beacause we cant check its quality without installing.
    What do u people suggest now, thsi year should i go for new japanese sandon compressor.
    Here at lahore its total cost comes to approx 11000+2200+1500=14700. what about this cots at RWP/IBD. 11000 is cost of japanese sandon.
    Testdriver, u might have installed sandon in ur woo??? what about its eprformance particularly at slow speed. Shoudl i go for kabli sandon???
    I haven't installed in my car but heard a lot positive about it. Japanese sanden should work good. Daewoo's Kabli compressor usually survive for one or two seasons.
    Adnan's
  9. #1888
    seismic's Avatar
    Dec 2009
    Rawalpindi
    37
    73
    Default Car pull towards left
    dear all,
    My daewoo slightly pull towards left. The wheel adjustment/aligment guy did his operation and remarked, "Its theoretically all ok now" But the problem is still there.
    What should be the possible reasons?
    suggestions/guidance please.
    Regards
  10. #1889
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by zamanother View Post
    Salam to all DFC HOUNORABLE MEMEBERS !
    Please suggest me i wanna upgrade my ceilo engine two type of engine THAT I CHOOSE AND SEE one is "DAEWOO DOHC 16VALVE WITH 5 FORWARD GEARS AND SECOND IS
    "DAEWOO V -TEC DOHC 16VALVE WITH 6 FORWARD GEARS 2008'' NOW PLEASE SUGGEST ME WHICH ONE IS THE BEST RELIABLE AND PERFORMANCE GOOD AND WHAT IS DA DIFFRENCE of these two types PLEASE REPLY I AM ANXIOUSLY WAITIN REPLY?? Specialy Mr. Testdriver and also all dfc honourable members
    Daewoo V-TEC with 6 forward gears????? Can you provide the engine and gear-box code?
    I think the you have seen these two types of engines:
    1. 1.5L DOHC 16v (1500cc) with 5 forward gearbox
    2. 1.6L DOHC 16v (E-Tec II) (1600cc) engine that came in Optra with 5 forward gearbox
    Adnan's
  11. #1890
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Quote Originally Posted by seismic View Post
    dear all,
    Regards
    There might be some play in suspension parts or the car's frame itself. Get it checked.
    Adnan's
  12. #1891
    Shah73's Avatar
    Apr 2009
    43
    538
    4 Post(s)
    10 Thread(s)
    Dear Testdriver:
    thanks for ur quick response for AC. my car starts on 3rds sulf on CNG. If i give high race before (like bus / truck) switching off the car then it normally starts easily on next starting attempt. I feel that Kit does not properly suck CNG while starting????? On petrol its fine.
    Is there any componant in the Kit that sucks CNG for starting. If it is so, it may be faulty. I have gone thru the mechanics but ............ they say change the kit !!!!
    CNG kit is of badini company and ordinary technician does not want to tackle it.
    What do u suggest or guide..
  13. #1892
    seismic's Avatar
    Dec 2009
    Rawalpindi
    37
    73
    Thanks dear testdriver for the quick reply.
    Any suggestion about the concerned expert (isb/pindi) who can exactly diagnose the problem.
    Is it a big problem?
    Please consider i have very little knowledge about vehicles.
  14. #1893
    zamanother's Avatar
    Oct 2009
    Multan
    35
    74
    Quote Originally Posted by testdriver View Post
    sorry for wrong information its a daewoo
    1.6 DOHC E-TEC II-i 16V (1600cc) model 2008 and it've 7speed gearbox means 6 Forward .
    So i want to know if this is reliable technically or not otherwise i go to ordinary dohc what type is better waitin coz i want upgrade engine in this week but only with ur advise what's the best please tell thanx
  15. #1894
    atif11's Avatar
    May 2006
    28
    781
    2 Post(s)
    Salam !
    i've being using senthetic oil and want to get back on mineral , so all i want to know is that is this harmfull or what ?? ?
    coz i've heard that switching to mineral frm senthetic is bad for engine, what should i do to use mineral? ? ? ? ???
    Dream is not what you see while you sleep , it is what that don't let u sleep .
  16. #1895
    hali's Avatar
    Sep 2005
    Rawalpindi
    32
    27
    Hi guys!! Proud daewoo owner .. The car has been in the family since the very start ... sparingly used less than 50,000 Km (genuine mileage) .. wid a v bright green full body color ... I am tempted to sell the car ... ur comments ??? will upload more photos ...
    Daewoo fan club -40425
    Daewoo fan club - 40424 Daewoo fan club -40426
  17. #1896
    asad_scorpio21's Avatar
    Mar 2007
    Rawalpindi
    38
    4,537
    @hali
    best of luck with sale , by the way wats ur demand and year of registration,
  18. #1897
    hali's Avatar
    Sep 2005
    Rawalpindi
    32
    27
    Dude car was from initial yellow cab sceheme. I will have to check for exact year from the book. Initially owned by my grandfather than me.... I would want 3 plus hopefully ...
  19. #1898
    nauman's Avatar
    Feb 2004
    35
    811
    14 Post(s)
    what is the registration number like idg 776, lxg 2045..
  20. #1899
    hali's Avatar
    Sep 2005
    Rawalpindi
    32
    27
    jus checked .... 93 model registered late 95 ... Rwp no.
  21. #1900
    speedy_gonzales's Avatar
    Apr 2009
    31
    45
    hey nice car dude ... proud owner !!
    especially color is awesome
    best of luck with sale !!
