Results 1 to 11 of 11
Like Tree5Likes
  • 2 Post By capsat
  • 1 Post By capsat
  • 2 Post By Xulfiqar
Thread: Battery for Mercedes Benz W210
    oklodhi's Avatar
    Oct 2007
    440
    3 Post(s)
    Default Battery for Mercedes Benz W210
    My mercedes benz w210 - E230 1997 model is currently in workshop for some time and the battery died. I have given it to various battery shops but it is not picking up charge. the battery is Hankook MF60038. 12V. 100Ah..Battery is located under the rear passenger seat.
    where are the dry batteries available in Lahore and what are the prices for 100AH battery?
    Secondly can i use normal 100Ah wet battery in the car?
    Range Rover Classic 1986 3.5L Petrol V8
    w202's Avatar
    Oct 2012
    London
    401
    22 Post(s)
    My friend its not problem with the battery check your charger alternator and wiring. To figure out why is it not childing.
    RANASAHAB's Avatar
    Mar 2006
    30
    650
    check pannu battery liberty market for imported batteries
    w202's Avatar
    Oct 2012
    London
    401
    22 Post(s)
    30,000 for dry battery i guess. I would use normal one to be honest
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    Check out Hafeez centre, 18 months back I purchased a Varta [smuggled from kabul ] 100 amp dry battery for Rs. 12000 batch & date of manufacture was same year for a BMW Z coupe. For your MB dimensions are critical liquid battery may give you frequent CEL [check engine] light . I also got 2 VARTA batteries last year from Peshawer again those were from Kabul for my home UPS system. 120 AMP each was under 15000 ea. currency devaluation in view price may be between 18 - 22000 now.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    oklodhi's Avatar
    Oct 2007
    440
    3 Post(s)
    Quote Originally Posted by w202 View Post
    Battery is outside and the car and the charging is being done by the shop. The car alternator is fine.
    oklodhi's Avatar
    Oct 2007
    440
    3 Post(s)
    Have you used a wet battery in mercedes under the rear seat ?
    w202's Avatar
    Oct 2012
    London
    401
    22 Post(s)
    The orginal mercedes battery. U can buy from inh workshop lahore if u look at that place there is a white pipe which connects to the battery and emoves condensation water battery causes. All my mercs had battery located in the boot. Digi mein.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    @oklodhi locate member Haroon_Tarar saheb he can guide you Better for Merc stuff in lahore
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by oklodhi View Post
    No W210 ever used a dry battery, they all had wet cell batteries with a vent tube, the latest upgrade of the batteries are AGM type. btw if your battery is not picking up charge, pop the top plate off and remove some electrolyte to weigh it, its SG should be 1.275 - usual complaint is the water has evaporated out. In some cases you can revive it back. If not then new battery time. You need a 100Ah unit which can supply 900 CCA - the best is the original white MB battery made in Spain.
    bradpit's Avatar
    Nov 2010
    42
    2,064
    87 Post(s)
    2 Thread(s)
    Brother 100AH ACDElco should not cost more than 15K.
    Available in KHI.
    All life is an experiment. The more experiments you make the better.
Tags for this Thread
