Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By LordOsama
Thread: W203 Mercedes Benz c180 Kompressor
    shoeblodhi's Avatar
    May 2009
    Rawalpindi
    34
    6
    Default W203 Mercedes Benz c180 Kompressor
    Hey guys,
    I was wondering if any of you ever tried using HIDs with Merc Benz. I am not sure the type which can be used.
    Please se share your experiences...
    __________Lodhi
    nasirkhan110's Avatar
    Jul 2014
    126
    9 Post(s)
    AOA High intensity discharged lamp (HIDs) could be replaced or fixed in any make/model of car's lights, i may suggest u to try LED or SMD these are better in quality, less consume battery and cheaper to HID, go to electronic market n try for 30 watts plus/minus wattage SMD (without housing), ask them to show light intensity to chose/buy satisfactory SMD, use ur own light housing as well lenses, check for some good electrician to fix such SMD in reasonable charges
    hope for better result
    God bless u n all
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    you would need to either reprogram the light control module or get proper xenon OE lights for your car (still requires a different part or rewriting the part), many who have installed HIDs into benz have later faced the "bulb out" warning due to the difference of amps in the circuit.
    umarkhan1's Avatar
    Nov 2010
    Sargodha
    2,309
    6
    8
    51 Post(s)
    4 Thread(s)
    ye fused bulb pe b check engine dete ha kya????
    hitler will be proud of germans
    Just Do It Your Self!!!!!
    LordOsama's Avatar
    Dec 2012
    Darmstadt
    24
    448
    14 Post(s)
    2 Thread(s)
    Quote Originally Posted by umarkhan1 View Post
    Hitler wanted to kill everyone on earth except Aryans (if my memory serves me right) so that only pure breed can live on earth.
    Mercedes is just the same, it doesn't like anything other than OEM quality if not original
    Sent from my GT-I9500 using PW Forums mobile app
    ? Nobody..
