Results 1 to 11 of 11
Like Tree7Likes
  • 1 Post By Xulfiqar
  • 2 Post By Naweed
  • 2 Post By Xulfiqar
  • 2 Post By imrananr
Thread: Need Help: Daewoo Cielo camshaft broken three times
    alihbadr's Avatar
    Jun 2015
    Default Need Help: Daewoo Cielo camshaft broken three times
    Good day all,
    I've been facing this problem from almost four months, first time I had my camshaft broken, then when I replaced it it worked for about a month and it has been broken again. Replaced it again with making full engine repair (valves, pistons, oil pump) drove the car for 500 km and today when I started the engine and about 2 minutes the engine stopped!. the camshaft has been broken again.
    In the three times the break is at the exact point!!
    Please help what would the problem be?
    Best regards,
    Click here for SOLUTION
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,591
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Put on steel boots, Goto the workshop kick the person under belt twice. make sure his reproductive system become a tube for bladder cleaning only -
    The engine is from OPEL /GM family and camshaft damage is possible for few reasons i can assume, - bad oil pump / sludge in crankcase and or wrong timing belt. once seems bad maintenance, 2nd & 3rd failure is sabotage or surely IDIOT carpenter acting as motor mechanic
    Please share more details of damage
    @syncview @margallar @Naweed
    Quote Originally Posted by alihbadr View Post
    Good day all,
    Best regards,
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Cam break some time due to cam journal seizing it look like your engine is full of slugh or some thing in head is not letting the cam rotate freely
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Daewoo ceilo is DOHC (doo can wala engine) which cam is breaking intake one or exhaust one?
    overspeed111's Avatar
    Apr 2010
    1,176
    change the casing which contains cam shaft. it is very possible that the cam shaft get struck somewhere and result is broken cam. which city ur in?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    if its the original SOHC TBI engine then I salute you for killing it, I have tortured the living daylights out of that engine and it still was running sweetly.
    The only reason the cam can sieze is from wrong bearing journals or severely warped head which has been faced straight on the deck side only.
    When a head warps the whole casting bends in a n shape the cam alignment is completely jacked if the warpage is very high. The cam carrier on your engine is bolted separate to the head, did the mechanic test it for free movement without valves installed? Its standard practice on that opel engine.
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    free floating test of crank shaft is a must and it is the job of machinist ... anyone can fit engine parts but only the free floating test tells u how it has been assembled
    "You have not lived today until you have done something for someone who can never repay you."
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by Naweed View Post
    In this case the cam carrier is bolted on top of the cylinder head, I suspect the head is actually bent out of shape or the carrier pedestals are damaged in some way. Causing the bind, Yes - you are completely right in saying that the mechanic should have confirmed the free float test before starting the install.
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    So he needs a new head for his car
  10. 05-06-2015, 04:10 AM
    Newbie
  11. #10
    imrananr's Avatar
    Jun 2014
    837
    5
    19 Post(s)
    Quote Originally Posted by saboor73 View Post
    Yes, he the mechanic and the car both need new heads.
    Don't leave a highway for a byway....
  12. #11
    alihbadr's Avatar
    Jun 2015
    Thank you all for your replies,
    One thing I forgot to tell that the last time I have changed both the cam and the casing, and the mechanic told me that will be enough and it won't break again!!
    Another problem is that I live in Syria, so the spare parts are very difficult to bring. What would you suggest if I want to buy a new engine for my car, is there any other engine rather than the original one can fit to my car? Or do I have to buy a new cam and casing?
    One more thing, if the timing is not correct, does the engine makes noises or vibrates or something else?
    Sorry for my questions but I'm really having lots of troubles with my car specially after spending about 1000 USD on it in the last month!!!
