Page 1 of 3 123 LastLast
Results 1 to 20 of 51
Like Tree4Likes
Thread: Mercedes Benz differential oil periodic change?
    AffaanAlAziz1's Avatar
    Jul 2010
    Rawalpindi
    32
    709
    4 Post(s)
    Default Mercedes Benz differential oil periodic change?
    My brother has a C180 Kompressor Avantgarde 2006 in immaculate condition. The car is near 100k km driven.
    It is Shahnawaz maintained with complete service history. When it was imported from UK complete periodic maintenance was done from Shahnawaz. The other day we were looking at the service history and found out that the rear axle differential oil wasn't replaced. So my brother called Shahnawaz Islamabad and asked what's the periodic replacement schedule for the differential oil, their reply was surprising, ''is your vehicle causing any trouble or noise, he said 'no', it's not periodically replaced rather its lifetime.''
    Then we called Shahnawaz Karachi and got a similar reply.
    I would like to have an expert opinion on this, whether differential oil of this particular model replaced periodically or not?
    If someone has maintenance booklet of the particular model he may share the image please.
    If what Shahnawaz saying is correct, please elaborate the logic/ reason, since my understanding is that as differential is a mechanical part the oil should get dirty with time and also if at all it doesn't get dirty, every oil has a life and after that it looses its chemical properties.
    Please help.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    differential oil change is necessary only if there has been a leak or repair done over the unit. If it is running trouble free stay calm & enjoy the ride
    @Xulfiqar @syncview @SER_GTR @argtr65
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    Quote Originally Posted by AffaanAlAziz1 View Post
    Please help.
    1st Oil Change Was Recommended Quick Change As Per My Understanding....All Metal Breaked Particles Will Be Drained After Initial Change..Then It Was Recommended To Change Around 50k Km
    I Don't Think It Never Need A Change Because Its Oil And Will Eventually Be Running Under Extreme Conditions...Question Is Why Most Of People Fear To Change Diff /Gearbox Oil( Common Desi Myth/Fear)
    Because People Have Changed And Then Horrible Things Have Happened...Why??
    Because People Take Oil As Just OIL .....Using Correct Grade Oil/Viscosity Is The Key Here....If You Go For Wrong One...You Will Mess Up Your Diff Or Gearbox In No Time.....!
    That's Why Oil Change Is Recommended But You Should Get Manufacture Recommended Oil Not Any Chunnu Munnu Mechanic's Expert
    Advice One...!
    LSD Diff Use Special Grade Oil...So Owner Should Make Sure To Know Correct Recommended Oil Grade And Find It....!
    Its A Common Myth To Use Diff Oil/MT Gearbox Oil Till You Wear It Off...Else No Need To Change...!
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    Jul 2010
    Rawalpindi
    32
    709
    4 Post(s)
    Quote Originally Posted by capsat View Post
    Thanks bros. Why doesn't it require periodic replacement like ATF PSF Break oil etc?
    arzaam.bhatti's Avatar
    Jun 2014
    20
    2,469
    6
    87 Post(s)
    i have a w203 and mine is 140k km driven, i had the differential fluid changed at shahnawaz, i think i did it on time as the fluid came out dirty and smelly although mine also had ablsoutley no issues or leaks, the original MB fluid is costly though costed me 15k for 1.2 litre for the job,
    generally on international forums expert says if the car is around 10 year old or approaching 150k its a good idea to change it, just do the job properly.
    i haven't felt much of a difference in drive, maybe a but smoother in application of power when making a Uturn. ill say it s good idea to change it.
    i dont think its a myth, people just dont know about such things and as far as MB goes they even said that there gearboxes are filled for life but we know thats not true. factory filled oil is plain mineral oil in MB differential not even synethhiec, like any oil after many years it is going to break down especially since its mineral but of a very high quality with certain addictives.
    If everything is coming your way, you're in the wrong lane!
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,403
    131
    3990 Post(s)
    94 Thread(s)
    6
    when a geartrain is brand new it will shed the most amount of debris in the first 20,000 kms. MB make really really nice n smooth diffys and fill them with nice oil too - which honestly is overfilled IMO (just like everything on the car, e.g. double the regular quantity of engine oil to a massive starting battery)
    A good idea is to change the oil anytime it gets mixed with water or gets some dirt in it or burns out from overheating (mismatched tires left to right, breather damaged etc). Under good conditions I have seen and serviced a bunch of these cars and the original fill was pretty dark n dirty, MB specify a regular (but heavily dosed) gear oil for their open diffys and after a change - you can inspect it after 50,000 kms - it will be shiny as the day you put it in.
    I personally use a nice synthetic blend gear lube in the USA, In Pakistan I bought Mobil1 gear oil from Mobil Askari lubes. You can choose to buy it from Mercedes Benz (at a price) - but make sure that you are choosing the right oil (sometimes the guys at shahnawaz ltd are also lost in their heads)
    Its a very long specced oil. dont overdo it though.
    addendum - MB do specify a synthetic lube in frigid areas or extreme hot areas (desert) and on some high end cars to quieten gear noise.
    Jul 2010
    Rawalpindi
    32
    709
    4 Post(s)
    Quote Originally Posted by arzaam.bhatti View Post
    Thanks bros.
    Jul 2010
    Rawalpindi
    32
    709
    4 Post(s)
    Thanks bros. Lovely review.
    Jul 2010
    Rawalpindi
    32
    709
    4 Post(s)
    @Xulfiqar @arzaam.bhatti @SER_GTR @capsat
    the car is like new and drives perfect. however it's 9-10 years old, should we go for differential oil replacement?
    a Mercedes mechanic in sadar advised not to change it! and said "GOONJ PAIDA HO JAEY GI".
    what should we do?
    Jul 2010
    Rawalpindi
    32
    709
    4 Post(s)
    I've searched on google, MB maintenance booklets do talk about replacing transmission fluids at 80k miles or 8 years but they are quiet about rear axle differential oil replacement except for AMG versions.
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    what should we do?
    Yes Thats Common As They Fear Abt Not Using Proper Oil Which Result In Mess
    So Your Best Bet Is To Check And Inspect Oil As Xulfi Bhai Said And Decide Accordingly!
    If You Have Complete History You Shld Have Known Abt Its Oil Being Change In Initial Times....If Not Then Its Recommended To Inspect And Change If Necessary....If Its Changed Then You Have Less To Worry About
  12. #12
    Jul 2010
    Rawalpindi
    32
    709
    4 Post(s)
    Quote Originally Posted by SER_GTR View Post
    It's never changed. same original 9+ years old. or the MB diffy oil turns more gold with time
  13. #13
    Jun 2014
    20
    2,469
    6
    87 Post(s)
    what should we do?
    I would say how long do you want to keep the car
    If you want to keep the car for more than two years then replace it,
    It will be good for the car in long run, make sure to use the correct fluid and correct tool to open the fill nut as well as to not damage it then there will be no harm, inspect the new fluid yourself don't blindly rely on Shahnawaz
    If you don't intend to keep the car long then there should be no harm in running the original fluid for now for a year or two
    I intended to keep my car for the long time and went for it, there were no horror stories afterwards. I also heard similar criticism form local so called ustaads
  14. #14
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    I Suggest You Better Check The Oil Condition As Its Never Changed In 100k Km Drive Whereas Its Good To Change In Early 10-20k Km To Clear Any Metal Break If Any....!
  15. #15
    shabbir.53's Avatar
    Jul 2013
    63
    689
    7 Post(s)
    Get the differential opened and oil inspected. If it requires changing, change it.
  16. #16
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    If you have never changed differential oil as yet,then leave it,just check level and top up if required.its my experience replacement of differential oil just for nothing will result in humming noise as ustaad jee said gounge.
    Never loose hope in life,every step gives u something.
  17. #17
    Jul 2010
    Rawalpindi
    32
    709
    4 Post(s)
    Thanks bhai. Now I'm clear headed.
  18. #18
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,403
    131
    3990 Post(s)
    94 Thread(s)
    6
    get some fresh oil and change it. - make sure to do it when the car is level, the diffy is hot (so it can drain faster and carry the debris out too)
    when changing make absolutely 500% sure that you open the fill plug first. If you cannot open the fill plug then dont open the drain plug. you wont be able to get new oil in there without removing the fill plug.
    while at it, check the breather vent on the top. remove and clean it out. Its a little air filter for the differential.
  19. #19
    Jul 2010
    Rawalpindi
    32
    709
    4 Post(s)
    Great help zulfiqar bhai. Thanks.
  20. #20
    tintin1's Avatar
    Jan 2014
    1,842
    8
    61 Post(s)
    2 Thread(s)
    7
    5
    @capsat, @Xulfiqar, @syncview, @SER_GTR, @argtr65
    I am hearing some goonj like Ko’n Ko’n Ko’n Ko’n Ko’n from my car since last 3~4 days. It only comes from speed 45Km/h to 75Km/h. It doesn’t make any sound before and after this speed range.
    Have checked the front wheel bearing to two different mechanics and they confirmed these are OK and its not wheel bearing noise. Because if it, then it has to be continous even at the slow, mid and high speeds.
    Third mechanic advised me to check the differential oil. I said OK but did not let him open it yet. However this thread is so helpful indeed. So i want to discuss my situation.
    Vehicle details are
    Toyota Crown
    JZS143R
    3.0L, 2JZGE I6
    24V, DOHC EFI
    RWD, AT
    Am having this car like 6 months and have not changed the gear oil because its color is still slightly red.
    From ZIC Oil guide, they recommend ZIC G-5, 80W-90 Gear oil, TO USE IN DIFFERENTIAL.
    I checked and availability of this oil is rare. And not sure either that its (ZIC G-5, 80w-90 gear oil) suitable oil for it or not?
    Hence I need your guidance here plz.
    Be Addicted To Help Others.
