now that the car has crossed 170,000 kms...it was time for some more maintenance...
Clutch Cable replacement for the first time
rocker conver gasket replacement
bottom engine mount replacement
generator belt replacement
antirollbar bush replacement..
new gearoil
front wheel bearing regreasing
CV joint boots replacement
front brake hose replacement
some major parts were imported coz new ones of OEM quality are not available locally (like clutch cable, antirollbar bush, brake hose, rocker cover gasket)
the brake hose, antirollbar bush, and the engine mount
the anirollbar bush..which fits to the wishbone..2 on each side
the clutch cable,,, by Motaquip
the bush
the hose again..
Gr8 job(Y)
anyway how much $$$?
(parts+labour)
good luck(Y)
well the cost is mixed but to an estimate..atleast around 13k rupees have been spent that day in all
Nice janab nice........ btw m amazed at the time the clutch cable was able to bear........
Gud Luck... Mate... Hope everything goes well wdout Ny issues...
@bilalahm
the cable was still working, but it had some friction now.. as the outer cover was damaged from some areas..
however the cable was still functioning fine..
nice....that shows ur love for her.
