Page 1 of 3 123 LastLast
Results 1 to 20 of 54
Like Tree19Likes
Thread: All motor experts help needed
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    Default All motor experts help needed
    First ALL MOTOR SETUP in Karachi on a motor bike
    Hv installed wisecohi compression alluminium - forged piston 61mm - 13mm pin
    All motor experts help needed -380301
    hi performance racing cam shaft
    All motor experts help needed -380302
    Hi performance 55mm stroker crank
    All motor experts help needed -380303
    cylinder stud kit
    All motor experts help needed -380304
    hv installed titanium valve springs retainer
    bigger intake and exhaust valve
    30mm intake valve
    24.5 exhaust valve
    5mm valve stem
    ceramic coating alluminium cylinder
    kitaco oil pump kit
    All motor experts help needed -380307
    racing CDI with harness
    All motor experts help needed -380306
    Hv installed silver head gaskit 1mm
    but the problem is tht i cant control its knocking increase head gaskit size to 1.5mm but no result then 1.75mm find result so thought knocking is dere becuase of lean fuel so increase the fuel by havng bigger jets first the jet size was 92 then installed 104.. knocking ends in 1st and 2nd gear in 3rd it do little knocking and in 4th when accelarate it it starts knocking..
    Help advice required plz
    My Vehicle is an ALL MOTOR. Seriously, Who needs a turbo when u have a Stupidly Quick Naturally Aspirated Motor???? Real Motors don't need Forced Induction. EG for life
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    here is my previous setup but now done this setup to a ALL MOTOR
    this setup was with cast piston and silver cylinder wd orignal crank of 150cc
    Piston size was
    54mm
    13mm pin size
    All motor experts help needed -1026391
    All motor experts help needed -1026392
    All motor experts help needed -1026393
    SpoonMotorSports's Avatar
    May 2010
    Peshawar
    1,493
    15 Post(s)
    allmotor cd70?
    ill reply to your question when i wakeup!
    Honda Tuning Solutions
    03468152233
    May 2010
    Peshawar
    1,493
    15 Post(s)
    how do you guys control ignition timing? retard it a bit and add more fuel
    03468152233
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    @spoon motors
    bhae jaldi uth kar rply dein yesh all motor on a CD-70
    Ignition timing is controled by a CDI unit... The CDI which i have Is a fully digital Stage 3 CDI unit. It has 1.65 Degree advance limit and + 800 - 1100 rpm... becuase in these bikes the engine is runing on fixed timing. Only Current timing varies and depends upon CDI UNIT.
    And for adding more fuel... i m already using carburetor of CG-350
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    M using HI OCTANE
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    Hv also changed the DRIVETRAIN PARTS
    6 Disc Clutch kit with KEVLAR REINFORCED CLUTCH DISC for decreasing the final drive ratios
    Transmission also changed
    Old ratios were
    1st-3.272, 2nd-1.937, 3rd-1.350, 4th-1.043
    new ratios are
    1st-2.623, 2nd-1.937, 3rd- 1.437, 4th- 1.300
    Gear shafts are also changed to Nickel Alloy CHP BILLET shafts
    amirhasan's Avatar
    Feb 2012
    23
    166
    bhi aap ko musabit kia pare haa ais chota sa engine me aise bongiya marna kee
    May 2010
    Peshawar
    1,493
    15 Post(s)
    Kelvar and wiseco make products for cd70s?
    cant believe my eyes! plz tell us more about the knock what rpm? and on full throttle? or while cruising?
    03468152233
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    First of all i want to make it clear kay yay engine CD 70 ka nahein hai... i hv swapped an engine of a 150cc DIRT bike in it like people swap B16, H22, etc
    so now its a different story
    @spoon
    it doesnt knock while cruisng on constant rpm lkn jaisy he we gv accelerator it starts knocking... in 1st till 2nd gear knocking bht kum hai lkn from 3rd to 4th gear knocking bht ajati hai Fuel lean and thick sab kar kay dekh liya lkn no result head gaskit .75 say 2mm tak laga kar dekh li thora farq aaya lkn not accurate
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    where are the actual pics of items??
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
  12. #12
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    @levin
    i know sumone will ask i cant believe u telling lie... yay ho ni sakta all motor in this or tht so uill get the pics tomorrow evening
    LIST OF THE ORIGNAL PICS THT WILL BE UPLOADED tomorrow
    Hi-Compression Piston
    Crank shaft
    Gear Transmission
    Cam saft
    Valve retainers
    CDI unit
    Current System
    Cylinder
    Clutch Box
    + bumper offer picture of all these stuff on bike
    and u can chck my history on PW by viewing my past threads and reputation on pw in Bikes 3 wheeler section
    https://www.pakwheels.com/forums/whe...s-175-fan-club
    https://www.pakwheels.com/forums/bik...triumph-thread
  13. #13
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    Here is the comparsion of my bike with orignal 150cc dirt bike engine wd the CD-70 engine
    Mine Engine pics
    All motor experts help needed -380449
    All motor experts help needed -380450
    CD70 engine pictures
    All motor experts help needed -380463
    All motor experts help needed -380464
  14. #14
    May 2010
    Peshawar
    1,493
    15 Post(s)
    Quote Originally Posted by FC View Post
    @spoon
    bro try reducing your timing i dont know how your bike engines work but 1.65degrees or 1000degrees timing should vary depending on engine speed and load and it should be variable try using a step colder plugs
    03468152233
  15. #15
    classickia's Avatar
    Jun 2010
    51
    12
    change the carburetor altogether , which has more space in the float section,or adjust the float level to the maxium, dont' think this carburetor, serves the purpose, needs more and constant flow at high speed, at present its getting starved, also look into the exhaust.....if still no chang than let me know here .will not be available after 12 till 18 march
  16. #16
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    @spoon
    bike runing fit till 2nd gear means PICK ACCELERATION is extra ordinary lkn in 3rd it starts knocking and in 4th gear end up in knocking i chckd out the piston condition it dont get any cieze or sum line or a hair line chckd out the head its all ok Valve spring + rocker all are ok... but cant figure out sum one said kay install a electronic fuel pump in ur bike is that will work ??? i got one LANCER electronic fuel pump vl it surve me ???
    uptill now wht i end up wd the conclusion is she needs rich fuel but aint getting tht as when i changed the jets it improved alot following the threads of N20 and starletgt i chnged up the head gaskits but not find results
    @classickia
    yar hv changed the carbeuretor to KEHIN 2 stroke KE 175 wd SUZUKI GP 100 intake manifold still no results Ke-175 got more space in floating section have also retire advance the pulsar timing still no results in knocking hv searched alot on internet the carbeurator thy are gvng wd dis SETUP are wd d SPECS. of CG200 same same jet sizes + SLIDE PIN
  17. #17
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    @spoon
    colder plugs means m using DENSO IRIDIUM IY24 8mm and 10mm tip iridium plug wht u suggest.. yar these are COLD plugs comparing to platinum as they got high melting points around 1100 or 1200 F
  18. #18
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    @CLASSICKIA
    yar for exhaust m using WOLKSWAGON BRAZIL CYLINCER TIP wd Honda S110 Exhaust manifold i find sum better results
    Exhaust which i used for reults but found no results
    CG125 Genuine Exhaust then customise it
    CD-200 exhaust no results
    CM250 no results
    GT550 exhaust is mein bike ka pressure hi ni araa tha
  19. #19
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    @classickia
    amazing baat yay hai kay the 2 stroke rickshaw carbeuretor gves sum better result but fuel controlling nahein ho ri us par means lean to bht lean thick to itna thick kay idle set ni ho ra
  20. #20
    daniyalahmad's Avatar
    Jun 2009
    Select City
    8,435
    12 Post(s)
    2 Thread(s)
    Sorry yaar,
    Abhi text parha hai tumhara.
    Seriously yaar mujhe is alteration ke baaray main kuch nahi pata.
    Never been into such kind of mods with bikes so cant debate much on this topic.
    BTW Im still suprised on your level of mods.
    Will be waiting for the pictures of the after market items installed.
    One of the most difficult things in the world is to know how to do something, and to watch without comment, somebody else do it incorrectly.
