Page 3 of 3 FirstFirst 123
Results 41 to 54 of 54
Like Tree19Likes
Thread: All motor experts help needed
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    Default All motor experts help needed
    First ALL MOTOR SETUP in Karachi on a motor bike
    Hv installed wisecohi compression alluminium - forged piston 61mm - 13mm pin
    All motor experts help needed -380301
    hi performance racing cam shaft
    All motor experts help needed -380302
    Hi performance 55mm stroker crank
    All motor experts help needed -380303
    cylinder stud kit
    All motor experts help needed -380304
    hv installed titanium valve springs retainer
    bigger intake and exhaust valve
    30mm intake valve
    24.5 exhaust valve
    5mm valve stem
    ceramic coating alluminium cylinder
    kitaco oil pump kit
    All motor experts help needed -380307
    racing CDI with harness
    All motor experts help needed -380306
    Hv installed silver head gaskit 1mm
    but the problem is tht i cant control its knocking increase head gaskit size to 1.5mm but no result then 1.75mm find result so thought knocking is dere becuase of lean fuel so increase the fuel by havng bigger jets first the jet size was 92 then installed 104.. knocking ends in 1st and 2nd gear in 3rd it do little knocking and in 4th when accelarate it it starts knocking..
    Help advice required plz
    My Vehicle is an ALL MOTOR. Seriously, Who needs a turbo when u have a Stupidly Quick Naturally Aspirated Motor???? Real Motors don't need Forced Induction. EG for life
  2. #41
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    ap bolo to mein 62mm ka bhi piston dikha sakta hun 13mm ki pin size par lkn bhai 58mm ka piston chalany kay liyay bara cylinder chahyay aur STRUTS apni jaga say hilanay party hain as 70 ka engine Bore 56 hota hai to 58 kaisy lay kar jaao *** andar phr ur crank wont be tht sufficent to handle the compression of the piston, so wdout crank using big pistons arnt a gud decisn
  3. #42
    FC
    FC is offline
    FC's Avatar
    Sep 2008
    3,376
    13 Post(s)
    Bikes mein to itna agaay chala gaya hun kay aay dekho.. 250cc DOHC 4 Valve Engine
    All motor experts help needed -1094251All motor experts help needed -1094252All motor experts help needed -1094254All motor experts help needed -1094256All motor experts help needed -1094258
  4. #43
    asjdsm's Avatar
    Apr 2009
    30
    3,470
    57 Post(s)
    3 Thread(s)
    tabai ha .. DOHC .. uffffffffffff .. yar kabi 2/3 wheels ka bhi chakar laga lia karo .. our haaaan meray inn massooom sawalon ka bhi koi jawab tho do ... hhahaaa
    Quote Originally Posted by asjdsm View Post
    otri khair ho ..
    updates ?
    oh .. i also got a question .. where u got this high compression 54 mm piston with 13mm wrist pin ?
    and i am using flat top piston in my altered bike .. but its not giving me any reasonable compression at least with the head of 110cc which has bigger combustion chamber .. my current cr is 7.5 or 8 to 1 .. and my current piston is 52.4mm piston ..
    i searched in pindi .. muja jo 52mm - 54mm ki range ma jo piston mil raha thay wo suzuki sprinter 110 ka mil raha tha .. jo zabardast tha compression ka lahaz sa but uska pin 14mm tha ..
    is ka ilawa mujha max 100 ka piston mil raha tha jo 13mm ki wrist pin ka tha .. but wo piston bhoth lamaba tharanaga tha .. koi ajeeb kisam ki shakal ka tha .. konsa ho saktha ha .. ? wo bhi fit tha ..
    yar ya 13mm pin ma koi acha sa piston ha ? kis bike ka ha ?
    and what carb is good i have horrible experince with crown lifan carb (cd 70 wala ) thats very poor carb ..
    and ya jo bend/pipe laga ha carb our head ka beech ma ... iss ka inner dia kitna ha ? does it matches with carb opening ? did u drilled it or stock suzuki gp 100 fit ho jatha ha ?
    and one suggestion .. have u tried velocity stack with ur carb ?
    as ur carb is not having the filter so its mouth is not profiled for max air intake .. try velocity stake .. laikin custom banwana paray ga ..
    and please do visit 2/3 wheels section .. please ..
    oh one buddy who just recently made his bike under ur auspiciousness and posted a thread about that bike has just vanished form teh scen .. plese tell me to do visit that thread and that 3 wheels section .. i will search his name /thread if u forgot him ..
    thanks
  5. #44
    user-xxx's Avatar
    Aug 2012
    25
    378
    2 Post(s)
    cylinder pe cc increase karnay se ride illegal nahi ho jati ?
    matlab documents main bhi to amendment honi chiay ?
    if yes to documents amendment ho jati hy ?
  6. #45
    user-xxx's Avatar
    Aug 2012
    25
    378
    2 Post(s)
    i have a E22 stock head on it . plz tell me if it is good or worse for altering ? or it is a good or bad head performence wise ? just asking as it was discussed above .
  7. #46
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    you need a bigger carb, 4 valve heads breathe quite a lot.
  8. #47
    user-xxx's Avatar
    Aug 2012
    25
    378
    2 Post(s)
    which one ?
    E22 is not 4v .
    its small.
  9. #48
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    that was not meant for you
  10. #49
    asjdsm's Avatar
    Apr 2009
    30
    3,470
    57 Post(s)
    3 Thread(s)
    @FC
    bro need to know something..
    i need a piston that is at least 52.4mm (or greater upto 54mm) and with 13mm gudgeon pin .. or wrist pin AND with domed top .. which bikes piston can fit this spec ?
    i am using one 52.4mm with 13mm wrist pin but its flat top piston and is not making enought compression .. its hardly making 8.5 :1 static compression .. its used in united 100cc bike (which is 110cc class bike)
    i want to increase compression .. how to do it ?
    the closest match that i found is a suzuki sprinter 110 piston which is 53.5mm piston with good top profile for awesome compression ratio but its wrist pin is 14mm ...
    is there a way to install a piston of 14mm wrist pin in con rod having 13mm small end hole ?
    or is there any con rod what is same length as that used in chondas 78 with 14mm small end ? though suzuki sprinter small end is 14mm but i dont konw if it fits in chondas or not .. also i think the suzuki stroke is 48.8mm wheareas chondas stroke is 49.5mm .. so it will be short in length ? any idea ?
    also is the con rod of 125 same in length and big end size as that of chonda 78 ? as both are using same stroke .. 49.5mm ?
  11. #50
    vickytulla's Avatar
    Oct 2009
    8,419
    38
    876 Post(s)
    31 Thread(s)
    yahan lahore men there are few mechnics unsay ye spare parts mil jatay hain ... yuo live in pindi ahve you met omer85 ? If you did you can ask him to contact chitta denters shope guy ... (the one who runs saram biker group) he sure can help you sourcing spares for altered bikes .. hope fully at reasonable price.
    If you ask me how I do? then fracnkly i dont give a damn to any mechnic because alteration is more a hobby I dont alter for heavy racing or wheelies I do it for fun and in order to assemble engine I do it my self with a friends help who is good at assembling engines (he worfs at suzuki) and i usuaally wander misri shah in quad bikes to source spare parts.. on weekends. bilal ganj has very less spares availabel for such kind of mods.
    Beside I am llooking forward to test import some items directly from China.
    @FC
  12. #51
    asjdsm's Avatar
    Apr 2009
    30
    3,470
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by vickytulla View Post
    Your second paragraph seems like I have written it. Same here... Thanks will inshallah discuss with omer
    Sent from my GT-I9300 using Tapatalk 2
  13. #52
    imrd.rd's Avatar
    Nov 2014
    Chakwal
    26
    256
    2 Post(s)
    Bahi muje bike ko alter krna hy bike 2013 model hy aur company super power hy ager ko treeqa bata sakta hy urdu main to is ka thanx hoga,aur saath yah v bata dain kah ap jo method batin gy is say bike kitne speed tak jaye for exmpel 120
  14. #53
    Newbie Follow
    a4abbascool's Avatar
    Oct 2016
    Default Hello...salam
    Quote Originally Posted by FC View Post
    Plzz text me
    I want to talk.
  15. #54
    Newbie Follow
    pwuser148023972278's Avatar
    Nov 2016
    Unhappy alteration of bike
    how i alter my bike superstar 70
