Page 27 of 74 FirstFirst ... 17252627282937 ... LastLast
Results 521 to 540 of 1472
Like Tree1656Likes
Thread: RP Storm Evolution II
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    Default RP Storm Evolution II
    RP Storm Evolution II -1467441
    RP Storm Evolution II -1521037
    I bought this bike a month back from @omer85 as he has done some major experiments on it to make it look this way including engine swap to bigger Thumper (200cc).
    Have upgraded few bits and pieces and will be posting all the moderation I will do on this bike in this thread from now on.
    Bike Received on 16-2-2014 from Islamabad :
    Checked it and pushed it to limits while heading home.
    RP Storm Evolution Part  II -1383216
    RP Storm Evolution Part  II -1383213
    56Teeth One wheelie Sprocket
    RP Storm Evolution II -1389230
    With [Front Visor/Tour Wind Shield]
    RP Storm Evolution II -1389228
    RP Storm Evolution II -1389229
  2. #521
    r1
    r1 is offline
    r1's Avatar
    Mar 2005
    Quetta
    30
    7,084
    6
    187 Post(s)
    11 Thread(s)
    @vickytulla thund agaye hay anti freez dala hay in radiator?
    Dream is not that which you see while sleeping it is something that does not let you sleep.
  3. #522
    LUCK_LIBRA's Avatar
    Sep 2007
    Rahimyar khan
    31
    337
    ravi piaggio owner friends particularly from lahore i need your help unfortunately i broke body cylinder of my bike and i am unable to find it in my city rahim yar khan is it available in lahore ? if yes where can i find body cylinder in lahore.
    thanks in advance
    beee cooool
  4. #523
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by LUCK_LIBRA View Post
    thanks in advance
    body cylinder ??????? kindly elaborate
  5. #524
    LUCK_LIBRA's Avatar
    Sep 2007
    Rahimyar khan
    31
    337
    piston and cylinder body thats what my mechanic told me ... i am bit naive about bikes
    beee cooool
  6. #525
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    cylinder of cg can also be used I think it wil needed to be bored by that not a big issue head and piston you have to find original @vickytulla can help you
  7. #526
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by saboor73 View Post
    sorry don't follow this statement as I have think on it and its quite impossible to use cg chamber/cylinder on rp
  8. #527
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by vickytulla View Post
    if bore is big then mathematically it should lead to different B X S ratio kiya khyal hai ?
    I have seen many cg with 200/250cc bore cylinder with same stoke so I was wondering that if this rickshaw engine have same stoke as cg I will replace my cg's push rod with the one use in these engine as my bike's engines push rod are worn out and AHL push rod are useless very thin
  9. #528
    JUNOON007's Avatar
    Dec 2012
    Sargodha
    28
    1,074
    21 Post(s)
    you are 100% correct also its indicator needs to be adjusted...
    Bro one question kia cg aur piaggio ki engine fitting same hay
  10. #529
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    Quote Originally Posted by r1 View Post
    nahi abhi nahi dala... lahore men December men bhi t-Shirts he chal rhi hotien hai .. so kitni thand hoti hai u can imagine ...
    send me over the pics of the piston/Cylender which he says are faulty or broke, yes its avaiable easily in used new is avaialbe but very expensive just like price of CG orignal cylender.
    cool did you asked them the same question ? what did they said ?
    Quote Originally Posted by JUNOON007 View Post
    unfortunely no...
  11. #530
    LUCK_LIBRA's Avatar
    Sep 2007
    Rahimyar khan
    31
    337
    here is it waqar bhai i need that thing but i need it new ..
    beee cooool
  12. #531
    LUCK_LIBRA's Avatar
    Sep 2007
    Rahimyar khan
    31
    337
    body cylinder pics
    beee cooool
  13. #532
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    i know how this happened.... screw the mechnic..
    body cylinder pics
  14. #533
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    I will let u know about its avaialblity and price...
  15. #534
    LUCK_LIBRA's Avatar
    Sep 2007
    Rahimyar khan
    31
    337
    it was screwed by previous owner ....
    beee cooool
  16. #535
    LUCK_LIBRA's Avatar
    Sep 2007
    Rahimyar khan
    31
    337
    ok waqar bhai and thanks for such favour
    beee cooool
  17. #536
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    got news for you... let me pm
  18. #537
    Site Banned Follow
    Silver_Knife's Avatar
    Jul 2007
    Select City
    8,070
    8
    255 Post(s)
    19 Thread(s)
    @vickytulla possible to get windshield, i think you have one for sale
  19. #538
    CkPiRkAnI's Avatar
    Apr 2013
    Quetta
    29
    300
    23 Post(s)
    2 Thread(s)
    MashAllah Vicky you bike looks great.
    A Good Long Ride Can Clear Your Mind, Restore Your Faith, And Use Up A lot Of Fuel.
  20. #539
    pirates's Avatar
    Nov 2013
    30
    102 Post(s)
    3 Thread(s)
    @vickytulla do you think you have a fastest RP in the town...are you sure????
  21. #540
    vickytulla's Avatar
    Oct 2009
    8,421
    38
    876 Post(s)
    31 Thread(s)
    Quote Originally Posted by Silver_Knife View Post
    I *had* one for sale.... :|
    Quote Originally Posted by CkPiRkAnI View Post
    thanks bro..
