Page 49 of 74 FirstFirst ... 39474849505159 ... LastLast
Results 961 to 980 of 1472
Like Tree1656Likes
Thread: RP Storm Evolution II
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    Default RP Storm Evolution II
    RP Storm Evolution II -1467441
    RP Storm Evolution II -1521037
    I bought this bike a month back from @omer85 as he has done some major experiments on it to make it look this way including engine swap to bigger Thumper (200cc).
    Have upgraded few bits and pieces and will be posting all the moderation I will do on this bike in this thread from now on.
    Bike Received on 16-2-2014 from Islamabad :
    Checked it and pushed it to limits while heading home.
    RP Storm Evolution Part  II -1383216
    RP Storm Evolution Part  II -1383213
    56Teeth One wheelie Sprocket
    RP Storm Evolution II -1389230
    With [Front Visor/Tour Wind Shield]
    RP Storm Evolution II -1389228
    RP Storm Evolution II -1389229
  2. #961
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    Quote Originally Posted by azeem.mian1 View Post
    Waooow , how much cc ? i also want 200cc water cooled for my RP whats estimated cost ?
    RP Storm Evolution II -1549756
  3. #962
    mfaizandawood's Avatar
    Feb 2015
    Gujranwala
    273
    Quote Originally Posted by vickytulla View Post
    rims b a gaay hy k nai??
  4. #963
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    Default Some Goodies for my hoodies
    belkens USB Charger for cell fone/GPS/Navigator what ever ... and Handle Stud and gear shifters...
    RP Storm Evolution II -1549869
    RP Storm Evolution II -1549870
  5. #964
    naseer_jaan's Avatar
    Sep 2012
    Gujrat
    34
    797
    12 Post(s)
    vicky bhi what is the price of this handle bar brace , pls tell
    GO__ HONDA __ GO
  6. #965
    aliatif777's Avatar
    Jul 2010
    22
    165
    If he is that inclined that means he is running short of experience (just thinking) becuase its very easy, there are 3 wires comming from stator coil and if you look at the wire diagram of 185 its a 3phase generator which can produce enough AC type from which a stable Volts from 4 to 18Volts can be created.. t
    The only thing is the rectifier which will regulate it to desired volts, the sazgar rectifier has also the 3 wires and will connect bolt on (might need to replace the male female connector) and the other two (red and green) wires will give a stable 12~16volt for charging.
    and it will al be done without even touching the point system ... as its a separate part of wiring completly..
    You're most probably right about the mechanic, actually talked to two both said the same thing. They only work CD200's I guess that's why. I will try the sazgar rectifier. What's the difference in 3 4 and 5 wire rectifiers? The one I have right now is a five wired one which gives about 13.2 volts without headlight. Someone said I should get at least 14.7 in order to keep the battery charged. These mechanics cause one hell of a confusion with these bikes. But you're a great support. Thanks once again!!
  7. #966
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    actually most of our mechnics dont think out of the box, they just do what there "ustaad" told them to do and beyond that is an illegal zone for them.
    Even if they are CD200 mechnics that means they must have a "REPO" of being an electrician of a Road Master in local mechnics community but how lousy they are that they dont have idea that they can play and Fool the 6v setUp quite easily, here what you need is a 5Wire Rectifire (even though any rectifir can do the Job it only has to regulate AC Current into DC volts) the 3 yellow wires will be harnessed to the stator where as Green and Red or Green and Blue pair will be you Wires goin to battery where Blue/Red will be a =Positive terminal.
    Quote Originally Posted by aliatif777 View Post
  8. #967
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    but do check if your stator is healthy enoug or not if it is already creating only around 13V on max Reving then you might need to rewire it get new/healthy stator coil which atleast creates 14 or more volts..
  9. #968
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    brother 200 for studd and 250 for lever.
    Quote Originally Posted by naseer_jaan View Post
  10. #969
    Sep 2012
    Gujrat
    34
    797
    12 Post(s)
    vicky bhi i need one studd for handle where you purchase ???
    GO__ HONDA __ GO
  11. #970
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    its very common item and can be found on various shops in market bro.. ap chaker ligao ap ko her dosri shop per para howa milay ga.
  12. #971
    Sep 2012
    Gujrat
    34
    797
    12 Post(s)
    okkk brother thanks reply mera next friday ko lahore chakar lage ga to main find karny ki kosish karon ga, aap sirf yeh bata dain k shop waley se kis naam se pata karna hai aur yeh macklord road se mily ga ya bilal gunj se
    GO__ HONDA __ GO
  13. #972
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    fancy handle, handle stick
  14. #973
    Sep 2012
    Gujrat
    34
    797
    12 Post(s)
    very very thanks vicky bhi
    GO__ HONDA __ GO
  15. #974
    azeem.mian1's Avatar
    Nov 2012
    27
    96
    2 Post(s)
    Waqar Bhai Whats Price of this and 200cc , ? can u tell me via PM ?
  16. #975
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    Bro:
    1 - It costs around 25k in 3rd Class qaulity without kit.
    2 - Sazgar Rickshaw Level Quality is 48k with compltet kit.
    3 - Good Quality (Comparable to OEM Manufacturer) is 60k including Complete kit.
    In Open market like MclOed Road or Bikes Auto market Sazgar Engine is 55k without carb, CDI, Rectifier, and list goes on which are expensive to buy sepratly.
  17. #976
    Nov 2012
    27
    96
    2 Post(s)
    [QUOTE=vickytulla;4724841]Bro:
    these rates for 250cc or 200cc which you installed in u r bike ?????
  18. #977
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    too many questins sarkar... take a guess..
  19. #978
    Nov 2012
    27
    96
    2 Post(s)
    Sorry if u Mind
  20. #979
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    I did not mind I just asked you to take a Guess becuase you are asking a same question which I just answered to you a one post before and if you read a little more you will understand it is being asked like a 1000 times already and answer is already there in the very same thread...
    Sorry if u Mind
  21. #980
    Nov 2012
    27
    96
    2 Post(s)
    ok Bro Whats method for buying ???
