Page 50 of 74 FirstFirst ... 40484950515260 ... LastLast
Results 981 to 1,000 of 1472
Like Tree1656Likes
Thread: RP Storm Evolution II
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    Default RP Storm Evolution II
    RP Storm Evolution II -1467441
    RP Storm Evolution II -1521037
    I bought this bike a month back from @omer85 as he has done some major experiments on it to make it look this way including engine swap to bigger Thumper (200cc).
    Have upgraded few bits and pieces and will be posting all the moderation I will do on this bike in this thread from now on.
    Bike Received on 16-2-2014 from Islamabad :
    Checked it and pushed it to limits while heading home.
    RP Storm Evolution Part  II -1383216
    RP Storm Evolution Part  II -1383213
    56Teeth One wheelie Sprocket
    RP Storm Evolution II -1389230
    With [Front Visor/Tour Wind Shield]
    RP Storm Evolution II -1389228
    RP Storm Evolution II -1389229
  2. #981
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    https://www.pakwheels.com/forums/sal...an#post4377207
    Quote Originally Posted by azeem.mian1 View Post
    ok Bro Whats method for buying ???
  3. #982
    aliatif777's Avatar
    Jul 2010
    22
    165
    Quote Originally Posted by vickytulla View Post
    actually most of our mechnics dont think out of the box, they just do what there "ustaad" told them to do and beyond that is an illegal zone for them.
    Even if they are CD200 mechnics that means they must have a "REPO" of being an electrician of a Road Master in local mechnics community but how lousy they are that they dont have idea that they can play and Fool the 6v setUp quite easily, here what you need is a 5Wire Rectifire (even though any rectifir can do the Job it only has to regulate AC Current into DC volts) the 3 yellow wires will be harnessed to the stator where as Green and Red or Green and Blue pair will be you Wires goin to battery where Blue/Red will be a =Positive terminal.
    Sir I second your statement regarding thinking out of box, since according to him if I don't swap the whole magnetto I'll never achieve a full charged and will face discharged battery on full load i.e headlight etc. Since I'll be doing the thinking part and lack experience in it, what you just said above means I should opt for a 5 wire rectifier? Is the sazgar one available with 5? I remember using a 3 wire one which was CD 70 in the very beginning suggestion of an ustad, it could not keep the bike start as soon as I disconnected the battery the current 5 wire one keeps it on if I hold the throttle at 1-5k rpm (assuming the rpm). Since I did the voltage test myself as well I got the following reading 12.6 at idle which keeps dropping then if I rev a little it goes towards 12.8-9 and 13.2-5 on full open throttle without anyload. When I install sazgar or any other rectifier will I be able to achieve a higher current? Let's say of 14? Or is my rectifier fine and is the coil causing that?
  4. #983
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    Quote Originally Posted by aliatif777 View Post
    he is right on his part actually, he is not thinking to take the pain to enhance the poser of stator enough to coupe with requirement [Battery Charging + Head Lamp].
    But we can have a better work around...
    Sazgar or i should say CG200 engine always have a 5 wire Rectifier (atleast in all famous cases i.e. meezan, sazgar, stahlco,... bla bla bla)
    It has two Jacks on is a 3 Wire( mostly yellow in color and connects to the 3 wire comming from stator pole which poles ? thats what a Electrician can tell by testing each pole by grounding it to see if its a hot pole or the return pole) and other is a two wire (mostly red+green or blue +green where blue or Red Wire is a positive battery terminal) and it connects to +ve and earth of bike.
    If its already spitting out this good current and still your battery gets drained, if the bike is not idling properly that might be due to setting of point which needs attention it should Idle properly...
    And I would recomend to switch to a LED Type Front beam which are quite common these days have very Good light almost comparable to HID but very low voltage and dont drain batter at all...
    this is kind of a hit and try when you are testing differnt options ... I am not sure about your stators health... ager wo theek hai tu then it should create more current.
    in worst case I must say, CD200 stator has more Coils in it and produces way more amps the 185 stator, if you land a deal in some where around 2~3k only for a complete assembly then it can be a good Idea ...
  5. #984
    aliatif777's Avatar
    Jul 2010
    22
    165
    Thank you so much for all detailed replies buddy and tolerating all the questions. Hats off!
  6. #985
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    Some more SESKI Stuff for my Hot ROD!!!
    RP Storm Evolution II -1550352
    RP Storm Evolution II -1550354
    RP Storm Evolution II -1550355
    RP Storm Evolution II -1550353
  7. #986
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    some orgasmic stuff of @onefifty's Ravi paiggio Storm!
    RP Storm Evolution II -1550357
    RP Storm Evolution II -1550358
    RP Storm Evolution II -1550359
  8. #987
    onefifty's Avatar
    Oct 2013
    155
    20 Post(s)
    Awesome...
    I got the picture now Vicky bhai.
  9. #988
    aliatif777's Avatar
    Jul 2010
    22
    165
    Is the bike getting ready for a another tour?
  10. #989
    Reventon28's Avatar
    Jan 2011
    28
    My RP has done 1200km almost .. When i got tuning on 1000 km, at first it did 110- 112 ( 2 times ) .. But now it goes max 100 .. And needle gets stucked on 100 at high speed, doesnt even moves a millimeter .. :-( .. Idk whats happening .. :-/
  11. #990
    mfaizandawood's Avatar
    Feb 2015
    Gujranwala
    273
    Quote Originally Posted by Reventon28 View Post
    my bike was able to do 120 any time after first tune up and after 2nd one, 110 max and the problem i found was tappet, our mechanics does't use feeler gauge while adjusting them so forced the mechanic to use 0.8mm feeler gauge and right after that bike is back in action
    And a few more things, did ur mechanic done anything to carburetor or have he cleaned the chain properly, do check tire pressure, and at what rpm u change gears and do each speed test in both direction.
  12. #991
    Reventon28's Avatar
    Jan 2011
    28
    Well i dnt knw honestly, but i'll ask him ..
  13. #992
    Site Banned Follow
    Silver_Knife's Avatar
    Jul 2007
    Select City
    8,070
    8
    255 Post(s)
    19 Thread(s)
    Sir, how much those shocks costed? and performance?
  14. #993
    mohsinwahhab's Avatar
    Jul 2013
    26
    1,133
    19 Post(s)
    @vickytulla bro I have a question why mechanic remove the spark plug when adjusting valve clearence? Does spark plug ignite when they spin the flywheel.
  15. #994
    Jul 2013
    26
    1,133
    19 Post(s)
    Kindly share the price of these handle bar I also saw this on olx ad
  16. #995
    Feb 2015
    Gujranwala
    273
    Quote Originally Posted by mohsinwahhab View Post
    removing spark plug does't let the engine create any compression so its easy to rotate flywheel this way and as long as the ignition is off plugs cannot ignite.
  17. #996
    Reventon28's Avatar
    Jan 2011
    28
    Em not satisfied of my 2015 RP Sound .. I'm thinking to put an exhaust .. But em confused thay its sound may burst .. Eg sound of 90s pointer .. Neither i know which exhaust to put on it .. Plz suggest me good bass exhausts with price please ..
    Advance thanks .. :-)
  18. #997
    taha66's Avatar
    Aug 2014
    22
    387
    30 Post(s)
    bro new RP has already a big note exhaust, i dnt think it further needs to be changed, stock is very beautiful
  19. #998
    Jul 2013
    26
    1,133
    19 Post(s)
    Quote Originally Posted by mfaizandawood View Post
    Thanks bro.
  20. #999
    Reventon28's Avatar
    Jan 2011
    28
    Quote Originally Posted by taha66 View Post
    Yes bro it is beauiful indeed .. But em not satisfied with its sound .. Its bit low in my view ..
  21. #1000
    vickytulla's Avatar
    Oct 2009
    8,414
    38
    876 Post(s)
    31 Thread(s)
    3.5k from Mcloead Road. Shop : AK enterprise I suppose.
