Page 65 of 74 FirstFirst ... 15556364656667 ... LastLast
Results 1,281 to 1,300 of 1472
Like Tree1656Likes
Thread: RP Storm Evolution II
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    Default RP Storm Evolution II
    RP Storm Evolution II -1467441
    RP Storm Evolution II -1521037
    I bought this bike a month back from @omer85 as he has done some major experiments on it to make it look this way including engine swap to bigger Thumper (200cc).
    Have upgraded few bits and pieces and will be posting all the moderation I will do on this bike in this thread from now on.
    Bike Received on 16-2-2014 from Islamabad :
    Checked it and pushed it to limits while heading home.
    RP Storm Evolution Part  II -1383216
    RP Storm Evolution Part  II -1383213
    56Teeth One wheelie Sprocket
    RP Storm Evolution II -1389230
    With [Front Visor/Tour Wind Shield]
    RP Storm Evolution II -1389228
    RP Storm Evolution II -1389229
  2. #1281
    patrolvtc's Avatar
    Feb 2011
    193
    3 Post(s)
    Quote Originally Posted by vickytulla View Post
    I installed heated pads on my CG... and they are working brialliant... bilkul wo feelinf ati hai jesay blanket(razayee) lay ker pankha chalay per ati hai.. lol
    You do feel cold brreeze on out side but it stays undercontrol constantly as your hands are warm inside and are kept warm constantly... I can well imagine that this will work even in rainy cold night as well..
    People get amazed when they shake warm hand from a biker who just arrived in cold wind.. and then I have to tell them that the CG has a speciall "Add ON"
    while fitting heated grips:
    RP Storm Evolution II -1641013
    The Final Result:
    RP Storm Evolution II -1641012
    Brother get your bike to nearest Yamaha servis shop ASAP, iska tire kahi say ragar kha rha hai ya phir drum k insde kio cheez ragar kha rahi hai.. zayada nukssan kerwanay say behter hai k check kerwaya jaye..
    Mota tire tu nahi dalwa liya ?
    thanks for your reply vicky bhai... original size is 90/90-18 i installed 100/90-18.... i get it checked from the Yamaha mechanic he serviced the brake checked my chain .... checked the position of the tyre after fitting .... now tyre is heating comparative less ..... bearings are also fine ....
  3. #1282
    RocketScience's Avatar
    Aug 2012
    960
    153 Post(s)
    10 Thread(s)
    Lolzee "Add On"
  4. #1283
    altisdualvvti's Avatar
    May 2012
    21
    1,966
    42 Post(s)
    @RocketScience @vickytulla
    Bros need guidance about the heated grips and pads which one to buy and will it works fine on my 70 battery
    Actually I m confused about what to buy heated pads or grips as I have searched for pads but couldn't find how will it works means will it can fold under the grip. And can we adjust the heat temp I think this option is available with grips and does it also works in isb extreme rain?
    I will appreciate your suggestions.
    Sent from my GFIVE G10 mini using Tapatalk
  5. #1284
    Aug 2012
    960
    153 Post(s)
    10 Thread(s)
    Quote Originally Posted by altisdualvvti View Post
    I am using Heated Pads and they are working well. If you are interested in Heated Grips then Vicky will guide you better.
  6. #1285
    May 2012
    21
    1,966
    42 Post(s)
    Quote Originally Posted by RocketScience View Post
    Thanks for the reply can u tell me how it works it extreme cold weather means how much it heater at its max temp and as u installed it in ignition switch so will it only works when u will kick the bike. And can any electration can install this? Does it have temp control as I saw a button on grips? And last why is so much price difference between grips and pads.
  7. #1286
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    every tire warms up when used.. by "heating" what do you mean ? like heating to level where if makes smell ? or just warms up if it warms up thats nothing to worry about but if it starts to smell then try observing from where if is getting friction... and get that place properly fixed..
    Quote Originally Posted by patrolvtc View Post
  8. #1287
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    The Pads dont have heat control, but they dont over heat nor low heat they heat at a fixed rate.. if its not very cold then soon you feel a need to switch them off ... CD70 battery is enuf for them to be used.
    Yes the pads are folded and tapped properly to fit and wired up with ignition switch to work only when Bike is switched on. The seller guy gave complete guide line and sends details on request too, I also got direction while installing..
    Heated Grips are complete Grip and do have temprature control in them so it can be controled to another level...
    I am using Pads on CG125 and they are working amazing and as they are sealed under the Shrinked covering water cannot enter in them.
    Give him a call and he will explain you all in detaill..
  9. #1288
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    Current State of R.piaggio
    RP Storm Evolution II -1641591
  10. #1289
    May 2012
    21
    1,966
    42 Post(s)
    Thank u bro for this detailed reply so it means the grips are better for me. And do update plz how it will work in rain and r they water proof
    Talking about grips. And what about installations can any electrication can do the job. And how much time it takes to heatup in the morning (first start).
  11. #1290
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    It takes around 20~30seconds untill you will start noticing that Grips are warm and its a pleasurable feeling.. I am using every day.. untill I am half my way the grips are warm enuf and switch it off, then untill office the grips stays warm.
    My office is 12KM/30minutes from home. You can get instructions from the seller how to fit them fool proof here...
  12. #1291
    May 2012
    21
    1,966
    42 Post(s)
    Thanks bro will give seller a call.
  13. #1292
    akhan911's Avatar
    May 2015
    118
    4 Post(s)
    Whats happening Waqar bhai?
  14. #1293
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    more upgrades...
    Ema make it ma monster niG*AA
    RP Storm Evolution II -1641676
    Quote Originally Posted by akhan911 View Post
  15. #1294
    angel82's Avatar
    Nov 2005
    34
    1,002
    6
    284 Post(s)
    6 Thread(s)
    Doomed Again
    Sent from my HUAWEI G7-TL00 using Tapatalk
    https://www.facebook.com/groups/SoberRiders/
  16. #1295
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    Becuase no good story starts with butterfly and sunshines..
    Quote Originally Posted by angel82 View Post
    Doomed Again
  17. #1296
    angel82's Avatar
    Nov 2005
    34
    1,002
    6
    284 Post(s)
    6 Thread(s)
    Waah kya baat kerdi kya baat kerdi
  18. #1297
    patrolvtc's Avatar
    Feb 2011
    193
    3 Post(s)
    nahi vicky bhai no smell but it heats up upto the level where one can't even touch it but now its fine its not getting that much hotter any more thank you once again for your reply
  19. #1298
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    Default Evo II Paiggio making some noise for PBC Boyz!!
    @vickytulla @seen4u and @RocketScience
    RP Storm Evolution II -1651914
    @taha66 @vickytulla @seen4u
    RP Storm Evolution II -1651915
  20. #1299
    akhan911's Avatar
    May 2015
    118
    4 Post(s)
    Waqar bhai isko b photoshop se edit kar k apni pic mey adjust kar leyn
    RP Storm Evolution II -1652147
  21. #1300
    vickytulla's Avatar
    Oct 2009
    8,418
    38
    876 Post(s)
    31 Thread(s)
    awais is this your bike ? ye wohi wheels hai jo mene diye thay ?
    This bike definitely needs a Hot rod engine... kamal lag rahi hai bike...
