Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By alizain5
Thread: RP 70 - Missing problem
    musabs's Avatar
    Jun 2012
    5
    Post RP 70 - Missing problem
    Hi All,
    Need help for my RP 70
    It has missing issue
    Had its tuning one day ago, after that it started missing a lot (in fact missing started after that, before it was OK)
    FYI - had some petrol filled (Rs. 200) from Shell petrol pump near Askari 11, Lahore
    Have gone to same mechanic (the one who did tuning) but still problem not solved
    Any suggestions???
    imrd.rd's Avatar
    Nov 2014
    Chakwal
    26
    256
    2 Post(s)
    plug check krwao
    alizain5's Avatar
    Nov 2013
    Faisalabad
    26
    144
    Check plug and plug wire too. Also check without air filter in clean place. Sometimes blocked air flow also cause missing.
    88azi's Avatar
    Jul 2015
    28
    44
    hello There are alots of factors which cause missing
    1: - Remove air filter and start the bike see if it solves the problem... if the missing is gone than its because of valve(small part in carburetor under floater replace it with new one it will solve missing)
    2: - Check Sparking Plug Clean it with sand paper or replace it with new one
    3: - Remove Plug cap take wire near head kick start just to see if coil is generating enough power if its okay you will see current hitting the metal properly with little tik tik sound (if current is not hitting properly than its coil's or wiring issues mechanics can easily fix it)
    4: - One last thing which most of the mechanics forget/ignore is switch LOL! trust me bro i had some tough time with my RP70's missing i showed to 100s mechanics but none of them figured it out. but one day i was passing by faisal town i saw mechanic shop i stopped by talked with ustad told him about issue i was facing .he removed carburetor checked the jet and floater carburetor was working fine than he remove air filter and start the bike it was missing than he realized that its switch which is causing problem i swear when he remove the switch(removed wires and connect it with eachother) and start bike it was okay no more missing i was shocked he told me that during rain cover meter with plastic to avoid this problem as you can see one small thing cause problem which is very complicated.
    Peace
