Page 6 of 6 FirstFirst ... 456
Results 101 to 111 of 111
Like Tree81Likes
Thread: Road Prince WeGo 150cc
    syber's Avatar
    Feb 2008
    68
    Default Road Prince WeGo 150cc
    Road Prince WeGo 150cc Supercharged Most Advanced Motorbike of Pakistan -1614804Road Prince WeGo 150cc Supercharged Most Advanced Motorbike of Pakistan -1614805Road Prince WeGo 150cc Supercharged Most Advanced Motorbike of Pakistan -1614806
    RoadPrince WeGoSuperCharged 150cc
    SPECIFICATIONS
    Engine Type : SingleCylinder, 4-Stroke
    Cubic Capacity : 149cc
    Bore and Stroke : 62mm x 49.5mm
    Timing Gear : Single Overhead Cam, 2 Valves
    Starter : Electric
    Lubrication : Dry Sump
    Fuel Supply System : KEIHIN 22mm Carburetor
    Cooling : Forced Air
    Gearbox : 5-Speed
    Clutch : Multi-plate Wet Clutch
    Frame : Single Spar Welded Steel with Pressed SteelReinforcement
    Front Suspension : 37mm Hydraulic Forks
    Rear Suspension : 2 Hydraulic Shock Absorbers withSeparate Canisters,Adjustable Spring Preload
    Front Brake : 240mm Disc with Two Piston Caliper
    Rear Brake : 104mm Drum
    Front Wheel : Aluminium Alloy 17"x2.15"
    Rear Wheel : Aluminium Alloy 17"x2.15"
    Front Tyre : 90/90-17"49S
    Rear Tyre : 110/80-17"57S
    Length : 2000mm
    Width : 760mm
    Wheelbase : 1330mm
    Fuel Tank : 18 Litres
    Homologation : Euro 3
    Keep Calm and Twist the Throttle
  2. #101
    gesherbrum's Avatar
    Jun 2009
    38
    147
    4 Post(s)
    After 1800 Kms the bike is showing its true power, yesterday got 75 to 80 Km/Hour in third gear and it was very quick like 7 to 8 second
  3. #102
    asharab.butt's Avatar
    Mar 2015
    19
    234
    Why cant people understand that just cuz theres a road prince badge doesnt mean its a chinese bike
    Sent from my iPad using PW Forums
  4. #103
    gesherbrum's Avatar
    Jun 2009
    38
    147
    4 Post(s)
    so touched 100 Km/h in third gear at Full RPM :lol:
  5. #104
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by gesherbrum View Post
    Budd more than a month and no update. Not fair
    Sent from my Nexus 5 using Tapatalk
  6. #105
    aa78's Avatar
    Dec 2011
    697
    10 Post(s)
    Now that this bike can be seen at showrooms and on the road (rarely), what kind of resale does it command in the market for couple months old bike?
  7. #106
    f4fraz's Avatar
    Dec 2013
    34
    653
    17 Post(s)
    Guys this bike is more active on facebook than pakwheels.
    Rawalpindi wego
    https://www.facebook.com/Hero-Centre...08913/?fref=ts
    Lahore/General wego
    https://www.facebook.com/groups/134301646918404/
    Lahore wego Gang
    https://www.facebook.com/groups/1661631997487326/
  8. #107
    user-xxx's Avatar
    Aug 2012
    25
    378
    2 Post(s)
    I was comparing some bykes on google , and then i came across the KTM 125. It is equal to CBR 125
    Just wanna share some info:
    KTM Duke 125
    124.7cc, 4 stroke DOHC engine
    15 bhp at 10500 rpm power
    Torque of 12 Nm at 8000 rpm
    6 Speed Manual Transmission
    124.7cc displacement of engine
    280 mm discs at front and 230 mm discs in rear
    110 kmph top speed
    Yamah YBR 125
    10.00 HP
    10.0:1
    54.0 - 54.0
    5-speed
    7.5 kW (10.0PS) @ 7,800 rpm
    9.6 Nm (0.98 kg-m)
    Honda Londa (9.0:1 56.5 - 49.5)
    btw road prince didnt mentioned HP for it. Hamain itna hi P**** samjty han yeh log
    ------------------------------------ALTERATION/MODIFICATION SEPARATE HUMAN FROM BEAST-----------------------------------------
  9. #108
    hamid700's Avatar
    Sep 2013
    55
    Seems like a good bike but expensive ...
    https://www.youtube.com/watch?v=bIHgy0iQX0w
  10. #109
    faizan_jani's Avatar
    Feb 2016
    111
    2 Post(s)
    where to buy spare parts of wego
    i am looking for visior of wego
    AHL GO TO HELL .
  11. #110
    randhawaa's Avatar
    Sep 2015
    9
    Thumbs up Xohail
    i can't understand the problem of Pakistan Nation.
    Honda is providing old , stupid & Obsolete bike since more than 30years but still the demand is the same. Every year , just sticker changed and stupid people says " oh , new model "
    I appreciate Ravi , Yamaha and Road Prince to bring uptomark and uptodate bikes in Pakistan.
    As a part of this change , i sold my CG 125 and purchased Ravi Piaggio. i am also planning to buy WeGo 150.My brother has YBR 125.
    As youngster , i suggest my fellows to appreciate change and repel the old bogus bikes so that our ride also became presentable and world class.
    Sorry in advance if i hurt anyone.
    Xohail
  12. #111
    umerchaudhary's Avatar
    Apr 2007
    32
    1,202
    4 Post(s)
    2 Thread(s)
    Quote Originally Posted by randhawaa View Post
    Xohail
    Bike is nothing without parts availability. Plus Sales and service.
    Before buying check wego parts availability. Because bike is bike and not a disposable item.
Tags for this Thread
