Page 22 of 31 FirstFirst ... 122021222324 ... LastLast
Results 421 to 440 of 603
Like Tree76Likes
Thread: 70 alter - Quest For Top Speed
    imrd.rd's Avatar
    Nov 2014
    Chakwal
    26
    256
    2 Post(s)
    Default 70 alter - Quest For Top Speed
    bahi log aik gear dalta hy 70cc bike main jis ko alter gear khty hain wo kahin sy mily ga aur kitne ka mily ga
    aur bahi log jab bike bahot zeyada vibration karte hoto iska koi hal hy keya
  2. #421
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    Quote Originally Posted by asjdsm View Post
    Carb konsa laga ha and top speed kitni a rahi ha?
    Sent from my Nexus 5 using Tapatalk
    Pz22 top speed kabi check nae ki or na hi muja top speed ka koe craze hai i just want acceleration that how much speed a bike can attain at smaller distance meri measurement thori funny hai lakin jo meter ma reading scale hoti hai usme white colour vali reading jab ek rotation cover karti hai means 7 sa 8 pe jati hai to meri bike itna ma +60 jati hai according to GPS.
    The first step towards knowledge is to know that WE are IGNORANT
  3. #422
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    Quote Originally Posted by Hassan1991 View Post
    Great to hear about your sensible riding.
    Stay safe.
    So the conclusion of the mods is that a cdi and ignition coil swap to 125cc didn't produced any noticeable improvements?
  4. #423
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    Stay safe.
    Thanks
    Yep we can say that but as saboor brother said it has better control on higher rpm for example it doesn't loses power when i goes to higher rpm which i always miss in cdi when i changed to point.
    Still the experiment doesn't end i will increase the petrol then let's see....it burns that petrol or get's over.
  5. #424
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    Thanks
    Yes try raising the jet needle one notch in the c clip..
    If possible try 85mj as that's the biggest size jet available for pz /pc /pb type carbs which all use same main jet..
    Unfortunately no pilot jet for Pz22 other then 32 is available as the thread size is different for the jets of pc carbs used in Honda 70 and chonda 70.
    Thread and physical size of pilot jet of cd 100 is different..
    Pilot jet har type ka carb ka different ha..
    Chorion ka size different hotha ha.
  6. #425
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    Right...
    I will increase the jet notch and also search for 85mj size jet.....and update as soon as possible.
  7. #426
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    Right...
    Raising l needle I'm c clip will give enough insight to begin with.
    Stay safe.
  8. #427
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    Stay safe.
    Okay
  9. #428
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    Stay safe.
    It's already at the last point
    70 alter - Quest For Top Speed - e3eb6d1e5cd588f04b186d2868a3530a
    Now I remember this carb has jet issue because of which me and my father set the notch at the end and some mixture setting to make it work but I forget to bring it back to normal.
  10. #429
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    This is most rich setting.
    I would try 85mj with needle c clip at center.
  11. #430
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    Actually Hero 70 doesn't work right with this carb so we did such setting to make it work no my 70 and install mien carb on Hero whereas there's no sign of mixture running rich.
    I remember I made the hole of main jet bigger not sure may be in this carb or anyother.....when I change the jet I will try setting notch at different positions to get maximum results.
  12. #431
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    Use pod type filter.
    Long ago I had a started a thread about how to effectively install it on chondaz.
    You will forget tuning bike and replacing filter.
    I am still using same pod filter for past four years..
    Your bike will breath a lot easier.
  13. #432
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    Where I can get one?
    I didn't install airfilter.....reason....changing airfilter is the most difficult work to do on a bike for me.I had something in my mind but didn't try yet.I want to either change the direction of the carb or install the pipe in such a way that it's directly towards the front wheel so as fast as I go more air goes in with more pressure.
  14. #433
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    You are in Lahore you can find it at any shop.
    Search my started threads you will find it. That's best for pz22.
    Don't reverse direction of carb.. Forward air pressure is not needed as the cylinder itself create a lot of sucking pressure.
  15. #434
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    But what I ask them to give? Do I say Pot filter dena?
    Okay I search the thread.
    I had searched Jet didn't fine one I will search in mughalpura tomorrow.
    I tried cg 125 coil+cdi on a long route today.A lot of back fires after heating up and bike also heat then usual.From my experience I can say strength of spark is less......so I changed to cd coil +cdi again as tomorrow I'm going on a long route again
  16. #435
    asjdsm's Avatar
    Apr 2009
    30
    3,469
    57 Post(s)
    3 Thread(s)
    It could be due to ignition timing at improper time... So user standard cdi.
    Forgot Desi name for that type of filter.
  17. #436
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    It could also be weak ignition current.
    So what I say to them?
  18. #437
    rashidali4708's Avatar
    Jun 2016
    60
    hehehe,yah to pick hote hy,har bike ki pick alag hote hy,jase kouch bike 1/2/3 gear main aik dam goli ban k jate hain pr 4 gear main shoor kr date hain,isi trh kouch bike ka just 4 gear hota hy phly 3 gear bakwas hote hain,jin k phly 3 gear achy hoty hain wo long py beat ho jate hain
  19. #438
    Jun 2016
    60
    asjdsm bahi pindi main khraad wala pata kr dogy jo pz22 k carb main alteration krta hy
  20. #439
    Jun 2016
    60
    Aur chain gerari set kon c compny ka best hy
    honda
    SAZ
    ya
    CK
    i have SP 2012
  21. #440
    Hassan1991's Avatar
    Mar 2013
    20
    2,270
    37 Post(s)
    Quote Originally Posted by rashidali4708 View Post
    Bhai har 72 or 78 cc bike ka 4 gear braber hota haien logon na khud sprockets ka sath chrr khani ki hoti hai jiski vaja sa koe 4 th gear ma bhi sae chalti hai koe torque chor deti hai.
    Or bhai kitni ka lambi race hoti hai muja bhi btao.
