Results 1 to 4 of 4
Like Tree3Likes
  • 1 Post By hamikhan
  • 1 Post By adeeljatoi
  • 1 Post By elxlr
Thread: Hi-Speed Motorcycle pick up issue
    safdar.khan's Avatar
    Oct 2014
    Faisalabad
    Default Hi-Speed Motorcycle pick up issue
    aoa,
    I Purchased 0 meter hi-speed china bike. The bike has a issue which still could not be understood by warranty shop, so about that i want some guidance if someone understand my issue. The issue is that when bike run 5-7 kilometers or we put it idol start on stand for about 20 minutes after this the pick up of the bike reduces in sizable position and it takes more accelerator than normal.Further is that if we off the engine for one minute then start it, it becomes like normal.One thing more that after running of 5-7 kilometer if we give throttle then give some missing sound also after one throttle missing eliminate and after restarting it become clear and as i said earlier bike become normal.
    the mechanic also adjusted its tappets and current flow he said all is normal but issue arise continuously.
    Regards.
    hamikhan's Avatar
    Jun 2014
    Other
    1,261
    39 Post(s)
    Check its spark plug or if possible change it with some other bike for testing purpose & also check its air filter from where air get in
    adeeljatoi's Avatar
    Jan 2015
    Multan
    23
    18
    adjust mixture and check air filter. and check the spark plug. and check the carb if there is some water in it then remove the water.
    elxlr's Avatar
    Oct 2015
    254
    3 Post(s)
    Replace the CDI unit. Judging by ur complaint. Its Nothing with the carburetor. Or at least test another CDI unit and if then it gives the same problem. Only then further search more problems.
    Sent from my Phone using PW Forums
