Page 25 of 32 FirstFirst ... 152324252627 ... LastLast
Results 481 to 500 of 621
Like Tree126Likes
Thread: Daihatsu Mira fan club
    swerveut's Avatar
    Sep 2007
    33
    139
    Default Daihatsu Mira fan club
    I am seeing a LOT of this car on the roads these days. Seems like it is becoming very popular among the people in its class (660 cc?). I did not see a club for it, so I have made it here (mods, if this is a repeat, please delete).
    So folks who own a Mira, please post pictures and tell us what you think about this car, how much did you buy it for, what fuel economy it gives you and how you rate it.
    I myself am not a Mira owner, however am very curious about this one.
    Cheers!
  2. #481
    kalia's Avatar
    Jun 2008
    32
    497
    23 Post(s)
    Quote Originally Posted by zeeshan368 View Post
    So what size you finaly installed and feedback?
    Sorry for the late reply. I installed 155/65/13. They are hard to find in a good brand and I do not recommend installing them. A couple of healthy adults at the back and you will have those cringe worthy moments where your car touches the speed bumps and you can't help it.
    Do in pindi as the pindi boyzes do !!
  3. #482
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    yea that's right. I tried to find 155/70R13 but could not, finally got a good used set of original Japanese 145/80R13
    Quote Originally Posted by kalia View Post
  4. #483
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    So today went to cvt oil change. Opened the drain bolt then the chamber. Whole oil drained, took out filter. Cleaned filter and chamber with petrol then fitted back after applying thin layer of silicon. Put a complete 4 liter tin of toyota cvtf tc. The manual says full capacity is 5.7l. But after filling 4 litres the dip stick shows level more than H mark even with the cold car. Car is running fine without any check light or any problem. So shoul i drain some oil to level it on the stick? Whats the proper procedure to check cvt fluid level? Have any one else changed CVT fluied and how much was filled? Thnx.
  5. #484
    whiteangel's Avatar
    Nov 2005
    2,243
    9
    65 Post(s)
    Who changed the oil and why did he open the chamber? Just open the drain bolt and let the oil drain out, measure the quantity that came out and put the same quantity back in. Simple. Why complicate things. And the guy who did the change should have checked the oil level on the dip stick before changing the oil. Now there's no way of telling how much oil came out and how much needed to be put in.
    Now the right thing to do is to follow the dipstick and drain the excess oil.
    Never argue with an idiot, they drag you down to their level and beat you with experience.
  6. #485
    tab001's Avatar
    Nov 2014
    53
    I have changed the CVT oil recently. Mechanic first opened the drain bolt and drain out the oil. Then he opened the chamber and washed and cleaned the chamber cap and oil filter. after all that he placed the filter and sealed the chamber by applying the gasket sealant. and poured the CVT oil and measure it by reading dipstick. He poured 3.5 liters oil (almost that much oil was drained out).
  7. #486
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    How are you reading dip stick? the three dots with C and H are confusing for me and i have to drain some oil to lvel it.. please
    Quote Originally Posted by tab001 View Post
  8. #487
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    So today first fill up after running 377 kms. the average came out is 17.28km/L...Disappointed, i was thinking it above 20.
  9. #488
    kalia's Avatar
    Jun 2008
    32
    497
    23 Post(s)
    I would be happy with CVT doing 17kmpl, especially in the first fill up.
  10. #489
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    ya but i have been driving manual with never less than 20.5km/l...
  11. #490
    kalia's Avatar
    Jun 2008
    32
    497
    23 Post(s)
    Everything has its associated cost. I have read CVT is supposed to be very efficient but I have never found my CVT Mira nearly as efficient or powerful as my brother's older manual Mira.
  12. #491
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    what's the proper way to use S and B?
  13. #492
    whiteangel's Avatar
    Nov 2005
    2,243
    9
    65 Post(s)
    S and B are useful when you are driving in a hilly area.
    S is used while going uphill when u need more power
    B is to be used while descending (when you need engine braking)
  14. #493
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    Noticed there's is no filter inside the AC/cabin filter portion. the sliding strip is there to open the filter but no filter? can i get it from the market? anyone purchased?
  15. #494
    tab001's Avatar
    Nov 2014
    53
    I was confused too with C and H. At that time, they (Mechanics) took reading and stop fillinf more oil when oil reached near to H.
  16. #495
    tab001's Avatar
    Nov 2014
    53
    Quote Originally Posted by whiteangel View Post
    I read somewhere that "S" is useful when your car move (applying acceleration) and stop (applying break and stop the car) frequently.
  17. #496
    tab001's Avatar
    Nov 2014
    53
    Within a city, in Traffic jam conditions, its very good average brother.
  18. #497
    sgg1983's Avatar
    Nov 2012
    126
    5 Post(s)
    Default Mira CVT fluid level?
    dip stick for CVT is so confusing help me read it.
    what should be the correct level? below pic identifies current level CVT fluid, at the nail mark. cold engine.
    Daihatsu Mira fan club -1529194
    Daihatsu Mira fan club -1529195
  19. #498
    whiteangel's Avatar
    Nov 2005
    2,243
    9
    65 Post(s)
    It certainly is confusing. I think the oil level should be between notch 1 and 2 when cold and between notch 2 and 3 when hot. But I'm not sure.
  20. #499
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    how about this? experts can confirm. but this is what i thought.
    Daihatsu Mira fan club -1529540
    My mira has over CVTF as well. should drain as soon as come to know the exact level.
    Daihatsu Mira fan club -1529541
  21. #500
    zeeshan368's Avatar
    Apr 2008
    33
    729
    7 Post(s)
    Hi just a quick question. Mira CVT
    Car makes heeein heeeein sound when accelerated and increase/decreases with increase decrease with the RPM. this sound from engine is in addition to normal sound of the engine. Is this normal sound for CVT? other CVT owners please comment.
Tags for this Thread
