Results 1 to 9 of 9
Thread: Transmission fluid for Daihatsu Esse 2011
    capricon92's Avatar
    Apr 2014
    14
    Default Transmission fluid for Daihatsu Esse 2011
    Which transmission fluid and brake oil should i use in my Daihatsu Esse 650cc car??
    tintin1's Avatar
    Jan 2014
    1,841
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    sir. its automatic or manual ?
    Be Addicted To Help Others.
    capricon92's Avatar
    Apr 2014
    14
    Quote Originally Posted by tintin1 View Post
    its automatic
    tintin1's Avatar
    Jan 2014
    1,841
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    Quote Originally Posted by capricon92 View Post
    its automatic
    Sir g your Car has CVT Transmission. Its very good.
    Ideal combination will be as follows
    Engine Oil : ZIC A+ (5w-20)
    Transmission oil: ZIC ATF XP III (For CVT Transmissions)
    Brake Fluide : DOT 4 or DOT 3. Try to look for Dot 4. If not available, then use DOT 3
    If want to go for Liqi Moly then
    Engine Oil : LM oil (5w-20)
    Transmission oil: Top Tech 1400 (For CVT Transmissions)
    capricon92's Avatar
    Apr 2014
    14
    Thanks brother. Please have a look at this sticker which i found under my car hood.
    I used Shell Helix HX7 5w30 engine oil according to this sticker as one of the pakwheelers recommended me.
    capricon92's Avatar
    Apr 2014
    14
    Transmission fluid for Daihatsu Esse 2011 -1510511
    hussain.ahmd's Avatar
    Jun 2014
    Sir capricorn92, you seem to have good knowledge of Esse. Can you please tell me where in Karachi can I get air & oil filters, engine oil, brake fluid, gear/transmission fluid, power steering fluid for Esse? And which ones would be recommended ones?
    Hope to hear from you soon.
    nabeelkhan's Avatar
    Oct 2008
    86
    518
    10 Post(s)
    Please share its drive experience as compared with Mehran/Cuore ?
    faizi91's Avatar
    Jul 2011
    25
    210
    3 Post(s)
    My mira e.s in now 50,000 driven I want too chnge its transmission oil how many liters it require and which company oil should I use and I also want too replace its tyres which company and size best too reduce road noise.Please kindly suggest
