Results 1 to 3 of 3
Thread: Required Help on Display Error for Daihatsu Move 2013
    amsoomro's Avatar
    Aug 2007
    39
    Default Required Help on Display Error for Daihatsu Move 2013
    i have a Daihatsu Move 2013 Model car i am driving from 6 months at the moment no issue in the Car all things working fine. But From few week i am noticing one message is coming on my car dashboard information display but not continuously its on and off some times
    the picture of message is below when i translate the message is in google translate its like " Radar Stop 11E" Kindly suggest what is that for Thanks a lot in advance...
    Required Help on Display Error for Daihatsu Move 2013 -1665845
    majmovan's Avatar
    Oct 2012
    25
    Quote Originally Posted by amsoomro View Post
    It is due to bad weather or direct sunlight.
    Please find the below link for move 2015 manual, you can find it on page 289 of the manual, I am also attaching an image you can translate it.
    http://www.daihatsu.co.jp/service/to.../move_1504.pdf
    Thanks.Required Help on Display Error for Daihatsu Move 2013 -1672013
    uzeemujeeb's Avatar
    Dec 2008
    381
    5
    4 Post(s)
    the ignition switch is getting extra hot causing this error to pop. remove ignition switch assembly clean all electrical contacts and spray some in key cylinder with alcohol wait for it to dry and repack
